I would really like to use my new Adafruit 0.96" OLED display with my brand new Arduino Nano 33 BLE board. I had no trouble connecting the Display to a normal Arduino Nano and the Adafruit ItsyBitsy M0, but it fails to compile on the new Arduino Nano 33 BLE. I know that the Nano 33 BLE uses a different chipset, and guess that's causing the problem.
One of the required includes for the OLED display is: #include <Adafruit_ImageReader.h>
If I try to compile with a basically blank sketch and just the include, it throws a long list of errors:
In file included from /Users/chris/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/arm-none-eabi/include/sys/_default_fcntl.h:200:0,
from /Users/chris/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/arm-none-eabi/include/sys/fcntl.h:4,
from /Users/chris/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/arm-none-eabi/include/fcntl.h:1,
from /Users/chris/Documents/Arduino/libraries/SdFat-master/src/FatLib/FatApiConstants.h:30,
from /Users/chris/Documents/Arduino/libraries/SdFat-master/src/FatLib/FatFile.h:36,
from /Users/chris/Documents/Arduino/libraries/SdFat-master/src/FatLib/ArduinoFiles.h:33,
from /Users/chris/Documents/Arduino/libraries/SdFat-master/src/FatLib/FatLib.h:27,
from /Users/chris/Documents/Arduino/libraries/SdFat-master/src/SdFat.h:33,
from /Users/chris/Documents/Arduino/libraries/Adafruit_SPIFlash/src/Adafruit_SPIFlash.h:35,
from /Users/chris/Documents/Arduino/libraries/Adafruit_ImageReader_Library/Adafruit_ImageReader.h:19,
from /Users/chris/Documents/Arduino/Test/Test.ino:4:
/Users/chris/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/arm-none-eabi/include/sys/stat.h:27:8: error: redefinition of 'struct stat'
struct stat
In file included from /Users/chris/Library/Arduino15/packages/arduino/hardware/mbed/1.1.2/cores/arduino/mbed/platform/mbed_error.h:28:0,
from /Users/chris/Library/Arduino15/packages/arduino/hardware/mbed/1.1.2/cores/arduino/mbed/rtos/Queue.h:28,
from /Users/chris/Library/Arduino15/packages/arduino/hardware/mbed/1.1.2/cores/arduino/mbed/rtos/Mail.h:28,
from /Users/chris/Library/Arduino15/packages/arduino/hardware/mbed/1.1.2/cores/arduino/mbed/rtos/rtos.h:33,
from /Users/chris/Library/Arduino15/packages/arduino/hardware/mbed/1.1.2/cores/arduino/mbed/mbed.h:23,
from /Users/chris/Library/Arduino15/packages/arduino/hardware/mbed/1.1.2/cores/arduino/Arduino.h:32,
from sketch/Test.ino.cpp:1:
/Users/chris/Library/Arduino15/packages/arduino/hardware/mbed/1.1.2/cores/arduino/mbed/platform/mbed_retarget.h:500:8: note: previous definition of 'struct stat'
struct stat {
And after that there are lots of warnings about multiple libraries being found:
Multiple libraries were found for "Adafruit_ImageReader.h"
Used: /Users/chris/Documents/Arduino/libraries/Adafruit_ImageReader_Library
Multiple libraries were found for "Adafruit_SPITFT.h"
Used: /Users/chris/Documents/Arduino/libraries/Adafruit_GFX_Library
Multiple libraries were found for "SPI.h"
Used: /Users/chris/Library/Arduino15/packages/arduino/hardware/mbed/1.1.2/libraries/SPI
Multiple libraries were found for "Adafruit_SPIFlash.h"
Used: /Users/chris/Documents/Arduino/libraries/Adafruit_SPIFlash
Multiple libraries were found for "SdFat.h"
Used: /Users/chris/Documents/Arduino/libraries/SdFat-master
exit status 1
Error compiling for board Arduino Nano 33 BLE.
The exact same errors are thrown if I compile with: #include <Adafruit_SPIFlash.h>
Is there some way to fix this? I am not sure where the error lies... with the Adafruit libraries or the Nano 33 BLE core libraries (which admittedly are much newer and untested). I feel like an #IFDEF (or equivalent) around the re-declared "struct stat" could solve it, but this is outside my wheelhouse.
Thank you.
