Greetings!
My first post, I hope to do it rigth.
I have to send sensed data to Elasticsearch database, with JSON protocol. I’ve found this tutorial
and it looks great, but I uses a WiFi module, and I need to use the Ethernet Shield. So, I’ve been trying to adapt the code from WiFi headers and .cpp to Ethernet directives, but something isn’t working fine. Some functions of WiFi dynamics don’t work just by replacing “WiFiFunction” for “EthernetFunction”
Here is the original code.
- I added the
#include <Ethernet.h>
#include “EthernetUdp.h”
Comented all the “WiFi” parts
Added EthernetUDP Udp;
The last error I have is related to NTP server,
Serial.println("Transmit NTP Request");
// get a random server from the pool
WiFi.hostByName(ntpServerName, ntpServerIP);
Some functions don’t work on both WiFi and Ethernet.
Thanks in advance!
* Simple HTTP get webclient test
#include <ESP8266WiFi.h>
#include <Wire.h>
#include <Adafruit_Sensor.h>
#include <Adafruit_BMP085_U.h>
#include <TimeLib.h>
#include <WiFiUdp.h>
Adafruit_BMP085_Unified bmp = Adafruit_BMP085_Unified(10085);
static const char ntpServerName[] = "us.pool.ntp.org";
// Setup your wifi SSID and password here.
const char* ssid = "CanIGetAWiFi";
const char* password = "n0youCan7";
const int timeZone = 0; // UTC
// Variables needed for NTP
// Elasticsearch needs us to generate timestamps for the data in order to make date histograms in Kibana.
WiFiUDP Udp;
unsigned int localPort = 8888; // local port to listen for UDP packets
time_t getNtpTime();
void printDigits(int digits);
void sendNTPpacket(IPAddress &address);
// This is the IP address, or DNS name of my Elasticsearch instance.
const char* host = "192.168.1.215";
const int port = 9200;
int motion;
// Variables
float temperature;
String timestamp;
time_t start_time;
uint32_t t_ms;
uint32_t start_mills;
String run_mills;
int milis_chars;
delay(100);
// We start by connecting to a WiFi network
Serial.print("Connecting to ");
Serial.println(ssid);
WiFi.begin(ssid, password);
Serial.print(".");
Serial.println("");
Serial.println("WiFi connected");
Serial.println("IP address: ");
Serial.println("Setting up NTP");
Udp.begin(localPort);
Serial.print("Local port: ");
Serial.println(Udp.localPort());
Serial.println("waiting for sync");
setSyncProvider(getNtpTime);
setSyncInterval(300);
start_time = now();
Serial.println("Pressure Sensor Test"); Serial.println("");
/* Initialise the sensor */
if(!bmp.begin())
/* There was a problem detecting the BMP085 ... check your connections */
Serial.print("Ooops, no BMP180 detected ... Check your wiring!");
while(1);
// Measure pressure & temperature from BMP sensor
// Modified from https://learn.adafruit.com/bmp085/using-the-bmp085-api-v2
sensors_event_t event;
bmp.getEvent(&event);
float pressure = event.pressure;
float temperature;
bmp.getTemperature(&temperature);
// Use WiFiClient class to create TCP connections, connect to the Elasticsearch instance.
WiFiClient client;
if (!client.connect(host, port)) {
Serial.println("connection failed");
return;
run_mills = String(millis());
milis_chars = run_mills.length();
// To generate a millisecond unix timestamp, we first get the second timestamp, and add to it, the last three characters of the arduino/relative millisecond timestamp
timestamp = String(now()) + run_mills.charAt(milis_chars-3) + run_mills.charAt(milis_chars-2) + run_mills.charAt(milis_chars-1);
// With such a simple document, we're just going to use a string to generate the JSON to send to Elasticsearch
String data = "{pressure: "+String(pressure)+", temperature: "+String(temperature)+", timestamp: "+ timestamp +"}";
// We can inspect the data being sent over the Serial line, in the Arduino IDE.
Serial.println(data);
// We now create a URI for the request
// This is the index of the Elasticsearch document we're creating
String url = "/weather/reading";
client.print(String("POST ") + url + " HTTP/1.1\r\n" +
// If you're using Shield, you'll need to generate an authentication header
"Content-Length: " + data.length() + "\r\n" +
"\r\n" + data);
// We need this delay in here to give the WiFi Time
delay(50);
// Read all the lines of the reply from server and print them to Serial
while(client.available()){
String line = client.readStringUntil('\r');
Serial.print(line);
/* Copied from https://github.com/PaulStoffregen/Time/blob/master/examples/TimeNTP_ESP8266WiFi/TimeNTP_ESP8266WiFi.ino#L99 */
/*-------- NTP code ----------*/
const int NTP_PACKET_SIZE = 48; // NTP time is in the first 48 bytes of message
byte packetBuffer[NTP_PACKET_SIZE]; //buffer to hold incoming & outgoing packets
time_t getNtpTime()
IPAddress ntpServerIP; // NTP server's ip address
while (Udp.parsePacket() > 0) ; // discard any previously received packets
Serial.print(ntpServerName);
Serial.print(": ");
Serial.println(ntpServerIP);
sendNTPpacket(ntpServerIP);
uint32_t beginWait = millis();
while (millis() - beginWait < 1500) {
int size = Udp.parsePacket();
if (size >= NTP_PACKET_SIZE) {
Serial.println("Receive NTP Response");
Udp.read(packetBuffer, NTP_PACKET_SIZE); // read packet into the buffer
unsigned long secsSince1900;
// convert four bytes starting at location 40 to a long integer
secsSince1900 = (unsigned long)packetBuffer[40] << 24;
secsSince1900 |= (unsigned long)packetBuffer[41] << 16;
secsSince1900 |= (unsigned long)packetBuffer[42] << 8;
secsSince1900 |= (unsigned long)packetBuffer[43];
return secsSince1900 - 2208988800UL + timeZone * SECS_PER_HOUR;
Serial.println("No NTP Response :-(");
return 0; // return 0 if unable to get the time
// send an NTP request to the time server at the given address
// set all bytes in the buffer to 0
memset(packetBuffer, 0, NTP_PACKET_SIZE);
// Initialize values needed to form NTP request
// (see URL above for details on the packets)
packetBuffer[0] = 0b11100011; // LI, Version, Mode
packetBuffer[1] = 0; // Stratum, or type of clock
packetBuffer[2] = 6; // Polling Interval
packetBuffer[3] = 0xEC; // Peer Clock Precision
// 8 bytes of zero for Root Delay & Root Dispersion
packetBuffer[12] = 49;
packetBuffer[13] = 0x4E;
packetBuffer[14] = 49;
packetBuffer[15] = 52;
// all NTP fields have been given values, now
// you can send a packet requesting a timestamp:
Udp.beginPacket(address, 123); //NTP requests are to port 123
Udp.write(packetBuffer, NTP_PACKET_SIZE);
Udp.endPacket();
