Adaptación modbus a arduino mega
Hola gente,
Estoy intentando hacer una comunicación modbus entre mi arduino mega y el pc. Lo que estoy intentando es utilizar el pc como master y el arduino como cliente.
He visto que hay una librería SimpleModbusSlave.h y tratando de ejecutar ese ejemplo, intuyo que tengo que hacer la adaptación de los pines para mi mega, pero si la comunicación la hace atreves del puerto serie-usb para que esta utilizando una entrada analógica.
no lo entiendo si algún se le ocurre que hace que me lo comente please.
adjunto código
#include <SimpleModbusSlave.h>
   SimpleModbusSlaveV10 supports function 3, 6 & 16.
   This example code will receive the adc ch0 value from the arduino master.
   It will then use this value to adjust the brightness of the led on pin 9.
   The value received from the master will be stored in address 1 in its own
   address space namely holdingRegs[].
   In addition to this the slaves own adc ch0 value will be stored in
   address 0 in its own address space holdingRegs[] for the master to
   be read. The master will use this value to alter the brightness of its
   own led connected to pin 9.
   The modbus_update() method updates the holdingRegs register array and checks
   communication.
   Note:
   The Arduino serial ring buffer is 64 bytes or 32 registers.
   Most of the time you will connect the arduino to a master via serial
   using a MAX485 or similar.
   In a function 3 request the master will attempt to read from your
   slave and since 5 bytes is already used for ID, FUNCTION, NO OF BYTES
   and two BYTES CRC the master can only request 58 bytes or 29 registers.
   In a function 16 request the master will attempt to write to your
   slave and since a 9 bytes is already used for ID, FUNCTION, ADDRESS,
   NO OF REGISTERS, NO OF BYTES and two BYTES CRC the master can only write
   54 bytes or 27 registers.
   Using a USB to Serial converter the maximum bytes you can send is
   limited to its internal buffer which differs between manufactures.
#define  LED 31
// Using the enum instruction allows for an easy method for adding and
// removing registers. Doing it this way saves you #defining the size
// of your slaves register array each time you want to add more registers
// and at a glimpse informs you of your slaves register layout.
//////////////// registers of your slave ///////////////////
enum
  // just add or remove registers and your good to go...
  // The first register starts at address 0
  ADC_VAL,
  PWM_VAL,
  HOLDING_REGS_SIZE // leave this one
  // total number of registers for function 3 and 16 share the same register array
  // i.e. the same address space
unsigned int holdingRegs[HOLDING_REGS_SIZE]; // function 3 and 16 register array
  /* parameters(HardwareSerial* SerialPort,
                long baudrate,
 unsigned char byteFormat,
                unsigned char ID,
                unsigned char transmit enable pin,
                unsigned int holding registers size,
                unsigned int* holding register array)
  /* Valid modbus byte formats are:
     SERIAL_8N2: 1 start bit, 8 data bits, 2 stop bits
     SERIAL_8E1: 1 start bit, 8 data bits, 1 Even parity bit, 1 stop bit
     SERIAL_8O1: 1 start bit, 8 data bits, 1 Odd parity bit, 1 stop bit
     You can obviously use SERIAL_8N1 but this does not adhere to the
     Modbus specifications. That said, I have tested the SERIAL_8N1 option
     on various commercial masters and slaves that were suppose to adhere
     to this specification and was always able to communicate... Go figure.
     These byte formats are already defined in the Arduino global name space.
  modbus_configure(&Serial, 9600, SERIAL_8N2, 1, 2, HOLDING_REGS_SIZE, holdingRegs);
  // modbus_update_comms(baud, byteFormat, id) is not needed but allows for easy update of the
  // port variables and slave id dynamically in any function.
  modbus_update_comms(9600, SERIAL_8N2, 1);
  pinMode(LED, OUTPUT);
  // modbus_update() is the only method used in loop(). It returns the total error
  // count since the slave started. You don't have to use it but it's useful
  // for fault finding by the modbus master.
  modbus_update();
  holdingRegs[ADC_VAL] = analogRead(A0); // update data to be read by the master to adjust the PWM
  analogWrite(LED, holdingRegs[PWM_VAL]>>2); // constrain adc value from the arduino master to 255
  /* Note:
     The use of the enum instruction is not needed. You could set a maximum allowable
     size for holdinRegs[] by defining HOLDING_REGS_SIZE using a constant and then access
     holdingRegs[] by "Index" addressing.
     I.e.
     holdingRegs[0] = analogRead(A0);
     analogWrite(LED, holdingRegs[1]/4);
Yo no entiendo tu pregunta.
El Mega usara un max485 a traves del puerto serie que elijas, tienes Serial1,2, y 3 si quieres dejar Serial para monitoreo. Además debes usar algun pin pera elegir el modo Tx o Rx del MAX485. No recuerdo si la librería lo asigna o puedes hacerlo por tu cuenta. No lo veo en el ejemplo (que has posteado con un tag equivocado. El tag que debes usar es </>)
hasta ahi bien, pero te falta incluir otro punto para que se comunique con el mega.
Hola surbyte,primeramente darte las gracias por contestar.
Tienes razón me he explicado un poco así así, mi idea es conectar el mega con un mbed BLE nano (para nosotros un ARM Cortex M0), estos los quiero conectar mediante el protocolo modbus y el mbed actuaría como maestro y el arduino actuaría como esclavo leyendo un valor analógico guardando en un registro para que cuando el mbed pregunte mega devuelve el dato.
Con este sistema lo que pretendo un simular un sistema real y montar un "entorno de desarrollo". Por eso mi idea era implantar el modbus esclavo en el Arduino comprobar que funcionase con el soft del pc y después implementarlo con el mbed. Pero he visto que así no lo puedo hacer, porque la comunicación modbus la hace a traves del puerto serie(usb) del mega y el arduino-mbed seria conectarlos mediantes entradas y salidas digitales.
Entonces, mi pregunta es para implementarlo ya que la idea es implementar el modbus RTU yo podría a ambos conectarlos
Arduino | mbed
TX --> RX
RX <-- TX
mediante salidas/entradas digitales y simular así una conexión RS232. Habría que modificar mucho el programa en arduino.
un saludo
kondrag:
Arduino | mbed
TX --> RX
RX <-- TX
un saludo
Sobre el ble nano nunca lo use, pero es muy simple conectar un arduino como slave a una PC por USB.
Te dejo un enlace de algo que hice hace algun tiempo
