Adapting code for the Adafruit Feather HUZZAH ESP8266
I have a conductive rubber cord that works great with using the FSR code that is meant for the Arduino Uno. I want to use it with the feather so that it can be wireless, and smaller. I am first trying to get it working through the USB cable, before trying to make it wireless. For some reason it only prints this…
Resistance: 0.00 ohms
Force: inf g
Here is the code:
Force_Sensitive_Resistor_Example.ino
Example sketch for SparkFun's force sensitive resistors
  (https://www.sparkfun.com/products/9375)
Jim Lindblom @ SparkFun Electronics
April 28, 2016
Create a voltage divider circuit combining an FSR with a 3.3k resistor.
- The resistor should connect from A0 to GND.
- The FSR should connect from A0 to 3.3V
As the resistance of the FSR decreases (meaning an increase in pressure), the
voltage at A0 should increase.
Development environment specifics:
Arduino 1.6.7
Tried to adapt this code for the Adafruit Feather HUZZAH ESP8266. It's not working...
const int FSR_PIN = 14; // Pin connected to FSR/resistor divider
// Measure the voltage at 3.3V and resistance of your 10k resistor, and enter
// their value's below:
const float VCC = 3.28; // Measured voltage of Ardunio 3.3V line
const float R_DIV = 9788.0; // Measured resistance of 10k resistor
  pinMode(FSR_PIN, INPUT);
  int fsrADC = analogRead(FSR_PIN);
  // If the FSR has no pressure, the resistance will be
  // near infinite. So the voltage should be near 0.
  if (fsrADC != 0) // If the analog reading is non-zero
    // Use ADC reading to calculate voltage:
    float fsrV = fsrADC * VCC / 1023.0;
    // Use voltage and static resistor value to
    // calculate FSR resistance:
    float fsrR = R_DIV * (VCC / fsrV - 1.0);
    Serial.println("Resistance: " + String(fsrR) + " ohms");
    // Guesstimate force based on slopes in figure 3 of
    // FSR datasheet:
    float force;
    float fsrG = 1.0 / fsrR; // Calculate conductance
    // Break parabolic curve down into two linear slopes:
    if (fsrR <= 600)
      force = (fsrG - 0.00075) / 0.00000032639;
      force =  fsrG / 0.000000642857;
    Serial.println("Force: " + String(force) + " g");
    // No pressure detected
I also tried declaring the ADC pin because that’s analog, but the arduino code didn’t like it when it verified.
oops.
