adapting code from the SensorBox for a Sparkfun mux breakout
I am trying out the max demo and want to connect an arduino to it using the Analog/Digital MUX Breakout board from Sparkun ( http://www.sparkfun.com/products/9056 )and Andrew Benson’s SensorBox.
I cant get it working and was hoping someone could correct my code below, which is modified from his that uses the older 4051 multiplexer. Any ideas what I am doing wrong in the code?
// Code for multiplexing Analog inputs and getting all the others into MaxMSP
//Andrew Benson
//http://pixlpa.com
char analogValue[96];//array of analog values
char current=0;//current position of analog value in array
int digVal;//digital pins bits are packed into a single variable
char imask = 128;//index bytes start with 1
char theEnd = 255;//byte to signal message end to Max patch
//set multiplexer control pins
#define mpinA 5
#define mpinB 6
#define mpinC 7
#define mpinD 8
//bit-packed truth tables per pin CHANGED for THE SPARKFUN BOARD:   http://www.sparkfun.com/products/9056
char mpinAmask[8] = {LOW,HIGH,LOW,HIGH,LOW,HIGH,LOW,HIGH};
char mpinBmask[8] = {LOW,LOW,HIGH,HIGH,LOW,LOW,HIGH,HIGH};
char mpinCmask[8] = {LOW,LOW,LOW,LOW,HIGH,HIGH,HIGH,HIGH};
char mpinDmask[8] = {HIGH,LOW,HIGH,LOW,HIGH,LOW,HIGH,LOW};
//select analog channels to multiplex
char is_muxPIN[6] = {1,0,0,0,0,0};//currently just uses A0. change to multiplex other inputs
char muxcount;//variable to store the number of multiplexed inputs
void setup(void) {
  digVal=0;
  muxcount=0;
  for (int i = 0;i<6;i++){
    muxcount+=is_muxPIN[i];
  for (int i = 2;i<14;i++){
    digitalWrite(i,HIGH);//enable pullups
  if(muxcount>0){
    pinMode(mpinA,OUTPUT);
    pinMode(mpinB,OUTPUT);
    pinMode(mpinC,OUTPUT);
    pinMode(mpinD,OUTPUT);
  while (establishContact()==0){delay(100);}  //wait for 99 byte
//uses serial.write() to avoid needless symbol creation in MaxMSP
  digVal=0; //reset digital value to 0
  //read digital pins
  for (int i = 0;i<11;i++){
    if(muxcount>0){
      if((i!=mpinA)&&(i!=mpinB)&&(i!=mpinC)) digVal |= (digitalRead(i+2)<<i);
    else digVal |= (digitalRead(i+2)<<i);
  //read analog pins
  for (int g = 0;g<6;g++){
    packValue(g);
  char total = current+1;
  sendOFF(total);//send everything to Max
  current=0;//reset analog value counter
  delay(10);//wait 10 milliseconds
  //see if someone tried to turn us off:
  if(establishContact()==1) {
    while(establishContact()==0) {delay(100);}//go into idle mode
void sendOFF(char total){
  //Send analog values in the format 0x81 a1 a2.....0xFF
  Serial.write(imask|1);
  for (int i = 0;i<total;i++){
      Serial.write(analogValue[i]);
  Serial.write(theEnd);//ends analog stream
  Serial.write((imask|2));
  Serial.write((digVal&127));
  Serial.write(digVal>>7);
  Serial.write(theEnd);//ends digital message
//read an analog pin and then pack into low/high bytes
void packValue(int index) {
    if(is_muxPIN[index]==1) muxAnalog(index);
    else regAnalog(index);
char establishContact(void){
    if (Serial.available() > 0) {
      char checkup = Serial.read();
      if (checkup==99) return 1;
      else return 0;
    else return 0;
//function for handling multiplexed analog reading
void muxAnalog(char index){
    for (int f=0;f<8;f++){
        //set the multiplex control pins
        digitalWrite(mpinA,mpinAmask[f]);
        digitalWrite(mpinB,mpinBmask[f]);
        digitalWrite(mpinC,mpinCmask[f]);
        delayMicroseconds(50);//allow analog signal to settle
        regAnalog(index);
void regAnalog(char index) {
      int tempA = analogRead(index);
      analogValue[current]=tempA & 127;
      current++;
      analogValue[current] = (tempA>>7);
      current++;
