ADC 2 channels simultaneously ?@ Arduino DUE
Hi there I would like to use 2 ADC ports simultaneous. Do I have to use a special keyword to let my Due that my data shall be read in a simultaneous way ? If it dosent work would you please tell me if my included code will work correcty to get the data from two ports using my Arduino due ADC ? Thanks in advance
float volt= 3.3/1024; // 3.3 volt / 2^10= 1024 for 10 bit resolution
  analogReadResolution(10); // Max 12 Bit for Arduino due
  float sensorValue_1 = analogRead(A0);// my first sensorvalue
    float sensorValue_2 = analogRead(A1);// my second sensorvalue
  float voltage_1 = sensorValue_1 * volt;
   float voltage_2 = sensorValue_2 * volt;
  Serial.println ("Voltage Sensor__1"voltage_1);
  Serial.println ("Voltage Sensor__2"voltage_2);
  delay(500) ;
There is only one ADC channel in the Due so you can't read them both simultaneously. There is seldom any need to anyway.
Put that in setup not in the loop function.
You are free to add your own sample/hold circuitry before the Due to achieve synchronous sampling.
But why? Is this some high end phase-detector?
Funday I could debug auto analog audio. Now I can record two channels audio with decent quallty. It's recording is play able with lantop,but built in dac plays only one channel. I need help to play that audio in stereo mode. Can any one help in this regard. I use standard auto analog audio sd recording from github from arduino ide. Thanks in advance for any help. If any one need to know I will send the debug . My email is sishudalwinder8@gmail.com. Thanks
