after having some problems measuring analog voltages with an Arduino Nano in my application I made a test setup:
An Arduino Nano, powered by the USB connection, is continuously reading an analog voltage and outputting the value read on Serial Monitor.
Curcuit:
- the output of a reference voltage chip is connected to Vref of the Nano; reference voltage = 2.46 V
- a potentiometer between Gnd and 5V output of the Nano provides a variable voltage to A3.
- a voltmeter is connected to A3
Code:
int V_batt;
int i;
setup {
analogReference(EXTERNAL);
while (1) {
V_batt=0;
for (i=0; i<16; i++) {
V_bat += analogRead(A3);
delay(1);
V_batt = (V_batt + 8)>>4;
Serial.print("V=");
Serial.println(V_batt);
With this simple test setup I varied the analog input via the potentiometer and made a table with several different voltages at A3 and the values of V_batt on the Serial Monitor.
With the reference voltage of Vref=2.46 V the formula V_A3*1023/V_batt=Vref should always verify that Vref=2.46. But this never is true! My measurements are resulting in varying values of Vref=2.48 ... 2.82 V (mean value 2.7258).
The values are varying because the voltmeter only has a resolution of 10 mV. That's ok.
But I cannot find an explanation for the high mean value of computed Vref. The ADC seems to see 2.7258 V at the Vref pin instead of 2.46 V.
Has anybody an explanation?
