There are some great posts about using Arduino Due (I have a Freaduino Due) to read an analogue signal at high frequency.
http://frenki.net/2013/10/fast-analogread-with-arduino-due/
http://forum.arduino.cc/index.php?topic=137635.5
But the situation changed a bit after ARDUINO 1.5.5 BETA 2013.11.28, when wrong initialization for ADC timings was changed.
This is discussed on:
While before this change you could get an notorious decrease in the sampling time from some 38 us (micro seconds) to 1 us. After that I couldn´t get less than 1.5 us.
With this code I get 1 us again:
int x; // read value
Serial.begin(57600); // initialize the serial port:
REG_ADC_MR = 0x10380180; // change from 10380200 to 10380180, 1 is the PREESCALER and 8 means FREERUN
ADC -> ADC_CHER = 0x80; // enable ADC on pin A0
unsigned long t = micros(); // init time an elapsed time, in micro seconds
for(int i = 0; i < 1000; i++) {
// instrucction to measure
while((ADC->ADC_ISR & 0x80)==0); // wait for conversion
x = ADC->ADC_CDR[7]; // read value A0
t = micros() - t - 2; // 2 us is nothing measured time
Serial.print("Time (us) ");
Serial.println( ( (double) t / 1000 ), 6 );
delay(2000);
I´m getting a 1.00 us sample time, That is 1 MHz frequency!.
My small innovation from the links is that I changed the PRESCALAR, from 2 to 1. This is in REG_ADC_MR = 0x10380180. I changed the third digit (right to left) from 2 to 1.
The change from 0 to 8 is to enable FREERUN, that means one sample after the other non stop.
Some comments:
Without any optimization I'm getting an analogRead(0); at 3.32 us (300 KHz)
enabling FREERUN (REG_ADC_MR = 0x10380280;) 1.92 us (520 KHz)
and changing resolution to 12 bits (shouldn´t be the opposite?) (analogReadResolution(12)) 1.80 us (555 KHz)
Then, from Stimmer post (I just coping and pasting his code, I am not sure to understand what he is doing)
ADC -> ADC_MR |= 0x80; // set free running mode on ADC;
I´m getting 1.50 us (667 KHz)
I just check the speed. I didn´t check any measured values so far.
Adios from Buenos Aires
Happy coding
Marcelo
