Adc input frequency
Hi I am totally newbie I have simple question what is the input frequency for each adc prescaler
// sampling rate is [ADC clock] / [prescaler] / [conversion clock cycles]
  // for Arduino Uno ADC clock is 16 MHz and a conversion takes 13 clock cycles
  //ADCSRA |= (1 << ADPS2) | (1 << ADPS0);    // 32 prescaler for 38.5 KHz
  ADCSRA |= (1 << ADPS2);                     // 16 prescaler for 76.9 KHz
  //ADCSRA |= (1 << ADPS1) | (1 << ADPS0);    // 8 prescaler for 153.8 KHz
Thanks in advance
These comments explain the calculation of sample rate. Sample frequency in Hz is 1/(sample time in seconds).
So prescaler 153.8 khz the input frequency = 153.8/13 ....11.830 khz or what?
Sampling rate = ADC clock / prescaler / conversion clock cycles
For example, with a prescaler of 32 the sampling rate is, 16MHz/32/13 = 38.462 kHz
and the ADC clock is 500kHz
Is that clear?
Yes clear and thank you
The ADC 500khz clock came from 16 mhz /32 ?
So I can use in your example 38.4khz input frequency on ADC pin ?
@jafal
38.4kHz is the sampling frequency.
The maximum frequency you can sample is always 1/2 of the sampling frequency
The the max input frequency on the ADC pin is 38.4kHz / 2 = 19.2kHz
Thanks a lot everything is clear
You are welcome
Have a nice day!
