ADC read value causes servos to twitch
Hello i am building a robotic arm and i have most of the project complete when i powered it up today i saw a problem that i could not see during testing ... the servos are twitching a lot.
I use an ADS1115 to read the joystick positions and then devide the value to get a range of 0-1024.
I have no idea how to solve the twitching of the servos and if there is another less messy way.
I will post my code below in a pastebin link due to the 9000 characters restriction of the forum.
The function that reads the adc is read_controls()
and the function that drives the servo is drive_servo()
the code seems a bit messy as a whole and a bit simplified because i tried to get it as simple as i could and then fix it up later. Also i work in tabs so that is why it may seem long i use functions to bind all the pieces together.
Edit : I corrected the drive_servo function to remove the claw servo from it due to the use of the separate claw servo function.
Anyway thank you in advance.
http://forum.arduino.cc/index.php/topic,148850.0.html
Attach it as a ino file to your next post.
What model Arduino are you using?
Why aren't you using the Arduino on board AtoD?
You could have a problem with the timer/interupt that the two libraries may use.
Try SoftwareServo library.
https://playground.arduino.cc/ComponentLib/Servo
Tom.. :slight_smile:
Here are the .ino files.
I do not use the onboard ADC because i need a 4 wire connection between the controller (which has the joysticks on) and the mcu
I use this ADC ADS1115 and this servo controller from adafruit Pwm I2C module and the board is a Arduino Nano
So that all my peripherals communicate using the I2C protocol with the mcu
Edit : Also from what i see when i power the arm is that the problem lies within my code in the servo delay variable the motors are working but they are making fast moves.
Arm_sketch_v10.7.ino (1.26 KB)
drive_claw.ino (332 Bytes)
drive_servo.ino (11 KB)
drive_stepper.ino (501 Bytes)
home_stepper.ino (286 Bytes)
read_controls.ino (1.41 KB)
variables.h (1.14 KB)
