ADC reading on PWM line
Hey there,
I am trying to read the CP line on a DIY EVSE project, I got the code from Link. I am trying to read the CP state using the Arduino's A1 pin. The CP circuit is similar to the Fotherja's schematics.
I am printing the values to the serial monitor, the issues is when I try to switch the states by adding a resistance and lowering the pilot voltage, the code do shanges the state but after 1 second it throws "Fault: 4" which is "Voltage_Classification_Fault"
I have altered the voltage classification ranges based on the readings I got from this snippet
    OCR1B = CHARGE_PWM_DUTY;
     while(1)  {
       delay(100);
       Serial.print(Pilot_Low_ADC); Serial.println(", "); Serial.print(Pilot_High_ADC); Serial.print(", ");
Here is the whole code
 *  At Power On:
 *    1) Ensure relays are open, configure PWM and ADC for running in the background
 *    2) Perform GFCI test
 *    3) Enter State_A
 *  Status A: (No vehicle present) CP: DC +12v          -
 *  Status B: When a vehicle is plugged in, a diode and resistor pull the DC +12v down to about +9v. We then start our 1khz PWM signal
 *  Status C: When a vehicle is ready and wants to charge it'll pull the positive side of the PWM down further to 6v (or 3v). This prompts us to close the relays after another GFCI test
 *   We use timer 1 to output generate our PWM/DC voltage
 *   We synchronise our ADC readings to using Timer1 interrupts to read the low and high PWM regions and we continuously read the GFCI ADC
 *   These are the list of faults that we detect:
 *    1) STARTUP GFCI TEST FAIL
 *    2) GFCI DETECT
 *    3) DIODE FAULT
 *    4) VOLTAGE CLASS FAULT
 *    5) START CHARGE GFCI TEST FAIL
 *   Changes:
 *    - 4/5/2022  - Added 4 second WDT reset
 *    - 22/5/2022 - Fixed bug in Timer interrupt which alternates the ADC channels
 *                - changed required successive faults from 100 to 10
 *    - 8/1/2024  - Increased GFCI_FAULT_THRESHOLD from 250 -> 300 because of occasional trips occuring with a Renault Zoe ZE50 2020
// Pin definitions
#define         Relay_1_Pin                 7
#define         Relay_2_Pin                 8
#define         Pilot_PWM_Pin               6
#define         Indicator_LED               13
#define         Pilot_ReadADC_Pin           A1
// State and fault definitions
#define         STATE_A                     1                                   // No EV connected
#define         STATE_B                     2                                   // EV Connected but not charging
#define         STATE_C                     3                                   // Charging
#define         CHARGE_PWM_DUTY             550                                 // Seems to result in 7.4 kW charging rate for me. (Lower numbers = higher duty cycle and charge rates)
#define         _12_VOLTS                   12
#define         _9_VOLTS                    9
#define         _6_VOLTS                    6
#define         _3_VOLTS                    3
#define         _DIODE_FAULT                1
#define         _FAULT                      0
#define         FAIL                        0
#define         PASS                        1
#define         DIODE_FAULT                 4
#define         VOLTAGE_CLASS_FAULT         5
// ADC ranges for classifying voltage levels (923 = 12v and 285 = -12v)
#define         POS_12V_MAX                 911                                 // 12.5V
#define         POS_12V_MIN                 885                                 // 11.5V
#define         POS_9V_MAX                  868                                 // 10V
#define         POS_9V_MIN                  810                                 // 8V
#define         POS_6V_MAX                  789                                 // 7V
#define         POS_6V_MIN                  725                                 // 5V
#define         POS_3V_MAX                  708                                 // 4V
#define         POS_3V_MIN                  656                                 // 2V
#define         NEG_12V_MAX                 327
#define         NEG_12V_MIN                 245
#define         FAULT_COUNT_THRESHOLD       100                                  // We have to have 10 successive trivial faults to trip out.
// Librarys
#include <avr/wdt.h>
// Global variable definitions (Globals are bad - I know!)
volatile int Pilot_Low_ADC;
volatile int Pilot_High_ADC;
volatile byte ADC_Channel = 1;
void Close_Relays();
void Open_Relays();
byte Read_Pilot_Voltage();
void Fault_Handler(byte Fault_type);
  noInterrupts();
  Serial.println("starting up...");
  pinMode(Indicator_LED, OUTPUT);
  // Configure Relay outputs
  Open_Relays();
  // Configue Pin 10 for PWM output 1kHz.
  pinMode(Pilot_PWM_Pin, OUTPUT);
  ICR1 = 1000;        // A 16MHz XO with a 1/8 prescaler and 1/1000 up/down (phase correct) count leads to a 1kHz PWM wave.
  TCCR1A = 0b00100010;
  TCCR1B = 0b00010010;                                                          // Timer 1 configured for PWM Phase correct with OC1B enabled non inverting and a 1/8 prescaler
  TIMSK1 = 0b00100001;                                                          // Enable Interrupts when timer counter at top and bottom (ie. middle of the PWM high and low sections)
  OCR1B = 0;        // Output +12v DC on the pilot
  // Configure ADC Module
  ADMUX = B01000000;                                                            // Set V_Ref to be AVcc, Set channel to A0
  ADCSRA = B10001111;                                                           // Enable ADC, Enable conversion complete interrupt, set 128 Prescaler -> ADC Clk = 125KHz
  // Enable Watch Dog
  //wdt_enable(WDTO_4S);
  //wdt_reset();
  interrupts();
  // Perform GFCI test
    // OCR1B = CHARGE_PWM_DUTY;
     //while(1)  {
       //delay(100);
       //Serial.print(Pilot_Low_ADC); Serial.println(", "); Serial.print(Pilot_High_ADC); Serial.print(", ");
  // Ready to start main loop
  Serial.println("Starting in State A");
  static byte Current_State = STATE_A;
  static byte PVC;
  //wdt_reset();
  delay(10);
  PVC = Read_Pilot_Voltage();                                                   // PVC = Pilot Voltage Classification
  // ---- Fault detection --------------------------------------------------------------------------------
  if(PVC == _DIODE_FAULT)
    Fault_Handler(DIODE_FAULT);
  if(PVC == _FAULT)
    Fault_Handler(VOLTAGE_CLASS_FAULT);
  // ---- Main State machine logic -----------------------------------------------------------------------
  switch (Current_State)  {
    case STATE_A:
      if(PVC == _9_VOLTS or PVC == _6_VOLTS or PVC == _3_VOLTS)  {
        digitalWrite(Indicator_LED, HIGH);
        Serial.println("State B");
        Current_State = STATE_B;
    case STATE_B:
      if(PVC == _12_VOLTS)  {
        OCR1B = 0;
        digitalWrite(Indicator_LED, LOW);
        Serial.println("State A");
      else if(PVC == _6_VOLTS or PVC == _3_VOLTS)  {
          Serial.println("State C");
          Close_Relays();
          Current_State = STATE_C;
    case STATE_C:
      if(PVC == _12_VOLTS or PVC == _9_VOLTS)  {
        Open_Relays();
  static int Fault_Count = 0;
  static int Previous_Value = _12_VOLTS;
  Serial.print("Pilot Low: "); Serial.println(Pilot_Low_ADC);
  Serial.print("Pilot High: "); Serial.println(Pilot_High_ADC);
  // Here we take the Pilot voltages and classfy them into states
  if((Pilot_Low_ADC > NEG_12V_MIN and Pilot_Low_ADC < NEG_12V_MAX) or OCR1B == 0) {
    if(Pilot_High_ADC > POS_12V_MIN and Pilot_High_ADC < POS_12V_MAX) {
      Previous_Value = _12_VOLTS; Fault_Count = 0;
      return(_12_VOLTS);
    else if(Pilot_High_ADC > POS_9V_MIN and Pilot_High_ADC < POS_9V_MAX) {
      Previous_Value = _9_VOLTS; Fault_Count = 0;
      return(_9_VOLTS);
    else if(Pilot_High_ADC > POS_6V_MIN and Pilot_High_ADC < POS_6V_MAX) {
      Previous_Value = _6_VOLTS; Fault_Count = 0;
      return(_6_VOLTS);
    else if(Pilot_High_ADC > POS_3V_MIN and Pilot_High_ADC < POS_3V_MAX) {
      Previous_Value = _3_VOLTS; Fault_Count = 0;
      return(_3_VOLTS);
    else {
    // The measured voltage is out of any expected range. We call this a fault condition
      Fault_Count++;
      if(Fault_Count > FAULT_COUNT_THRESHOLD)
        return(_FAULT);
        return(Previous_Value);
  else  {
    // Diode fault - the negative PWM should always be -12v, if it's not we have a diode missing fault!
    Fault_Count++;
        return(_DIODE_FAULT);
  Open_Relays();
  OCR1B = 0;
  Serial.print("FAULT: "); Serial.print(Fault_type);
  while(1) {
    delay(100);
    delay(100);
    //wdt_reset();
void Close_Relays()
  pinMode(Relay_1_Pin, OUTPUT); pinMode(Relay_2_Pin, OUTPUT);
  digitalWrite(Relay_1_Pin, HIGH); digitalWrite(Relay_2_Pin, HIGH);
void Open_Relays()
  digitalWrite(Relay_1_Pin, LOW); digitalWrite(Relay_2_Pin, LOW);
// This code runs when the PWM signal is in the middle of its low period
ISR(TIMER1_OVF_vect)
  static byte selector = 0;
  if(ADCSRA & 0b01000000)                                                       // If the ADC is still performing a conversion (it shouldn't be) then return
    return;
  else  {
    ADMUX = B01000001;
    ADCSRA |= B01000000;
    ADC_Channel = 0;
    selector = 1;
// This code runs when the PWM signal is in the middle of its high period
ISR(TIMER1_CAPT_vect)
    return;
  else  {
    ADMUX = B01000001;
    ADC_Channel = 1;
    selector = 1;
// Interrupt service routine for ADC conversion complete
ISR(ADC_vect)
  unsigned char adcl = ADCL;
  unsigned char adch = ADCH;
  switch(ADC_Channel)  {
    case 0:
      Pilot_Low_ADC = (adch << 8) | adcl;
    case 1:
      Pilot_High_ADC = (adch << 8) | adcl;
You are probably the only person in the world who knows what you are writing about. So providing more information, links, schematics, etc. will certainly encourage people to look at your problem and respond.
