ADC Sampling Rate
Hey everyone, I'm a Mech. Eng. student so i don't understand a lot of this computer "stuff." To be blunt I have a variable PhotoDiode sensor with a max output of 17MHz and min of 12.5kHz depending on the setting. The ATMEGA328 specs say it can sample at 20MHz, which I know won't be enough for the max setting (aliasing will occur) but will probably be fine for the other settings. The problem is the Arduino Nano 3.0 (w/ATMEGA328) specs say the analogRead function can only process at 10,000 samples/sec, which I think is 10kHz. So does this mean that the Arduino Nano can't be used at all for A/D conversion of the PhotoDetector or will it just store the input sample data until it can convert the data?
Sorry but I can tell from your questions.
No it can't that is the clock maximum speed not the sampling rate. And an arduino only runs at 16 MHz.
That is probably the rate at which it CAN be used at not what it WILL be used at, the actual frequency you get out depends on how fast the light is flickering.
Yes that is true for all arduinos.
No, I think you are misunderstanding the nature of electronics, what exactly do you want to do?
Thanks for the response! I'm trying to set up an Arduino Nano 3.0 to read a Photodectector and also have the Arduino Nano export that data to an external storage device. The light passing over the photodetector will not be moving at any speed near the kilo hertz range so detection in the MHz range is not necessary, I just want to know what ADC setting I should write into the code to avoid aliasing but still have accurate data.
From analogRead() - Arduino Reference
It takes about 100 microseconds (0.0001 s) to read an analog input, so the maximum reading rate is about 10,000 times a second.
As you are talking about aliasing then you are getting some sort of data out of the changing light level. It helps if we know what you are doing so we can spot any snags you have missed. For example is it an optical pickup for a guitar?
