Hi, How can I speed up the ADC? It currently takes about 21.43µs to use analogRead(), and I'd be looking for anyway to speed this up. Thank You!!
int analogPin = A0;
int val;
float timer;
Serial.begin(115200); // setup serial
analogReadResolution(10);
unsigned long y = micros(); // time_1
val = analogRead(analogPin); // read the input pin
//Serial.println(val);
unsigned long x = micros(); // time_2
Serial.println(x-y);
That being said, I'm locked down to 10bits on the ADC (Design Specification). Are there any quicker alternatives to analogRead()?
Are you REALLY using an R4? And have you read the data sheet?
https://www.renesas.com/en/document/dst/ra4m1-group-datasheet?r=1054146
You'd have to check for the Renesas RA4M1 specifically, but virtually all modern microcontrollers can have the ADC output to DMA directly, running in continuous mode. Given the specifications of the controller, you should be able to get around 1MHz sampling rate.
Thank you, I'll look into that.
Yeah, It's an R4. Do you have any suggestions?
Can you try running the adc read in a counted loop - say 100 reads?
Have you contacted the renesas group forum?
Also I wonder if val = analogRead(analogPin); is not the right way to do the analog read.
See here
https://renesas.github.io/fsp/group___a_d_c.html
Sorry for the late replies, I might've solved the issue using this library: GitHub - arduino/ArduinoCore-renesas at 149f78b6490ccbafeb420f68919c381a5bdb6e21
