ADC Voltage Reading
Hello all!
Please I am very new to this Arduino.
In the code bellow, I want the output become high when it gets to 3v and stays high unless its value is decreased to 2.5V
The Led comes on at 3V and goes off immediately it goes below 3V
int sensorPin = A0; // select the input pin for the potentiometer
int ledPin = 3; // select the pin for the LED
int sensorValue = 0; // variable to store the value coming from the sensor
// declare the ledPin as an OUTPUT:
pinMode(ledPin, OUTPUT);
// read the value from the sensor:
sensorValue = analogRead(sensorPin);
sensorValue = sensorValue * 5/1023 ; //its convert digital value back into voltage
// turn the ledPin on
if(sensorValue <=2.5 )
digitalWrite(ledPin, LOW);
if(sensorValue >= 3 )
digitalWrite(ledPin, High);
Thanks
Use code tags ("</>" button) when posting code.
If you want to use units of fractional Volts (like 2.5 V) then sensorValue must be a float variable, and you must do floating point calculations to end up with Volts, e.g.
float sensorValue = 0.0; // variable to store the value coming from the sensor
sensorValue = sensorValue * 5.0/1024.0 ; //convert digital value into voltage
Note: the correct divisor is 1024.0, not 1023.0.
Maybe better to work with A/D values.
2.5volt on an Uno is an A/D value of 2.5/5 * 1024 = 512, and 3volt is an A/D value of 3/5 * 1024 = ~614.
if (sensorValue > 614) digitalWrite(ledPin, HIGH);
Or turn it into a state machine, so the LED pin is written to only once (not that important).
Leo..
const byte sensorPin = A0;
const byte ledPin = 3;
boolean ledState;
int sensorValue;
  if (sensorValue > 615 && ledState == LOW)
    ledState = HIGH;
  if (sensorValue < 512 && ledState == HIGH)
    ledState == LOW;
Ok thanks for your help. I will follow your directives when I get back home.
Thanks in advance.
Ok I have modified the code as directed and it worked, Being new to the Arduino things, I am curios to learn it. I have added LedPin_2 to the code and it also worked but I ran into trouble trying to add on/off delay to only first "LedPin_1"so that it will delay for the specified milliseconds before of or off.
The delay is working on the two Pins but if I remove the delay and put it only on LedPin_2, it worked on it without affecting LedPin_1
Please, how can I do it so the delay will function on a specified pin (Pins) only?
Thanks.
int sensorPin_2 = A1; // select the input pin_2 for the potentiometer
int LedPin_1 = 3; // select the pin for the LED
int ledPin_2 = 13; // select the pin for the LED_2
 pinMode(LedPin_1, OUTPUT); // declare the ledPin as an OUTPUT:
 pinMode(ledPin_2, OUTPUT); // declare the ledPin_2 as an OUTPUT:
 if(sensorValue >= 3.0 )
 delay (15000);
 digitalWrite (LedPin_1, HIGH);  // turn the LedPin_1 on
 if(sensorValue <= 2.5 )
 delay (15000);
 digitalWrite(LedPin_1, LOW);   // turn the LedPin_1 off
 if(sensorValue >= 3.2 )
 digitalWrite(ledPin_2, HIGH);  // turn the ledPin_2 on
 if(sensorValue <= 3.0 )
 digitalWrite(ledPin_2, LOW);   // turn the ledPin_2 off
Don't use delay(), use millis() instead.
Ok, to apply this Millis(), I will enter the numeric value of the time in the closed brackets.
Millis(500)
Ok thanks, I will check it out
@jremington, the link you provided through millis() explains it all! I think I have learned a lot from there.
Thanks so much for your elaboration and the time it took you to write such tutorial.
Thanks.
Nick Gammon wrote that tutorial. Glad it was helpful!
Yeah! Later saw that! Thanks!
