I thought I would share the following code. It shows the peak-to-peak noise that's on the Vref pin of the AVR. I wrote it to get a sense for the noise because I needed to make somewhat accurate measurements. This code works with both the Uno and Leonardo boards and possibly others.
#if defined(USBCON)
ADMUX = _BV(REFS0) | _BV(MUX4) | _BV(MUX3) | _BV(MUX2) | _BV(MUX1);
#else
ADMUX = _BV(REFS0) | _BV(MUX3) | _BV(MUX2) | _BV(MUX1);
#endif
delay(2); // Wait for Vref to settle
uint16_t min_reading=1023;
uint16_t max_reading=0;
uint16_t reading;
if (millis() % 1000) {
ADCSRA |= _BV(ADSC); // start convertion
loop_until_bit_is_clear(ADCSRA,ADSC);
reading = ADCL;
reading |= ADCH<<8;
min_reading = min(min_reading, reading);
max_reading = max(max_reading, reading);
Serial.print ("Vref noise: ");
Serial.print ((max_reading - min_reading) * 4.88);
Serial.println(" mV");
min_reading=1023;
max_reading=0;
delay(1);
