Add a ESP32Cam to another ESP32 transfer files
Need some idea of where to start. Wanting to add a ESP32Cam to another ESP32 board.
Both boards (esp32-cam-ai-thinker) and TSim 7600 (which as a ESP32 onboard). Essentially I want to be take photos from the ESP32Cam and send via the TSIM but they are connected. So whats the best way to go?
  1. Connect both via wireless? transfer from ESP32Cam to TSIM SD? If so site will not have any access points so the TSIM and ESP32Cam need to connect to each other
  2. Connect both via wireless? transfer from ESP32Cam SD to TSIM SD? If so how to transfer?
  3. Connect physically? Dont see how...
  4. Other ie web server, ftp?
Open to any and all ideas before I start to go down a rabbit whole
So you want to send picture over mobile network? When you take picture on ESP32CAM you have it stored in buffer. Should be easy to transfer the buffer contents via Serial to TSim. Another solution is to see if you can connect camera to TSim if you have all the camera pins available (long shot)
Thanks T-SIM7600G-H has serial TX and RX
So it would be good to enable it as if onboard but also to have 1-2 external additional cameras some how connected (ESP-Now?) writing photos to SD then transferring to TSIM SD then I can send via 4/5G TXD/RXD as these are different to the Modem TX/RX.
ESP32CAM has SD and T-SIM7600G-H also has a SD.
Can I Serial to TSim via the TXD/RXD as they dont seem to be used.
Here I use FTP to transfer an image from a ESP32 cam to another thingy.
#include "sdkconfig.h" // used for log printing
#include "esp_system.h"
#include "freertos/FreeRTOS.h" //freeRTOS items to be used
#include "freertos/task.h"
#include "certs.h"
#include "esp_camera.h"
#include "soc/soc.h"           // Disable brownout problems
#include "soc/rtc_cntl_reg.h"  // Disable brownout problems
#include "driver/rtc_io.h"
#include <WiFi.h>
#include <WiFiClient.h>
#include "ESP32_FTPClient.h"
WiFiClient wifiClient; // do the WiFi instantiation thing
ESP32_FTPClient ftp (ftp_server, ftp_user, ftp_pass, 5000, 2);
void IRAM_ATTR WiFiEvent(WiFiEvent_t event)
  switch (event) {
    case SYSTEM_EVENT_STA_CONNECTED:
      log_i("Connected to WiFi access point");
    case SYSTEM_EVENT_STA_DISCONNECTED:
      log_i("Disconnected from WiFi access point");
    case SYSTEM_EVENT_AP_STADISCONNECTED:
      log_i("WiFi client disconnected");
    default: break;
} // void IRAM_ATTR WiFiEvent(WiFiEvent_t event)
  WRITE_PERI_REG(RTC_CNTL_BROWN_OUT_REG, 0); //disable brownout detector
  if ( configInitCamera() )
    xTaskCreatePinnedToCore( capturePhoto_sendFTP, "capturePhoto_sendFTP", 20000, NULL, 3, NULL, 1 );
    log_i( "camera failed to initilize. Quitting programed operations." );
} // void setup()
void capturePhoto_sendFTP( void *pvParameters )
  TickType_t xLastWakeTime    = xTaskGetTickCount();
  const TickType_t xFrequency = 100; //delay for mS
  for (;;)
    log_i( "tick");
    if ( WiFi.status() == WL_CONNECTED )
      camera_fb_t * fb = NULL; // pointer
      fb = esp_camera_fb_get();
      if (!fb)
        log_i( "Camera capture failed" );
        ftp.OpenConnection(); // try open FTP
        if ( ftp.isConnected() )
          //try send file ftp
          ftp.ChangeWorkDir( ftp_path );
          // Delete existing file, create the new file, and send the image to the file
          ftp.DeleteFile( ftp_file_name );
          ftp.InitFile( ftp_file_type ); //"Type I"
          ftp.NewFile( ftp_file_name );
          ftp.WriteData( (unsigned char *)fb->buf, fb->len );
          ftp.CloseFile();
          ftp.CloseConnection();
        esp_camera_fb_return(fb); //return the frame buffer back to the driver for reuse
      log_i( "In capturePhoto_sendFTP found WiFi not connected ");
      connectToWiFi();
    vTaskDelayUntil( &xLastWakeTime, xFrequency );
  vTaskDelete( NULL );
} //void capturePhoto_sendFTP( void *pvParameters )
void configureCameraSettings()
  sensor_t * s = esp_camera_sensor_get(); //see certs.h for more info
  s->set_brightness(s, -1);     // -2 to 2 **************************
  s->set_contrast(s, 0);       // -2 to 2
  s->set_saturation(s, 0);     // -2 to 2
  s->set_special_effect(s, 0); // 0 to 6 (0 - No Effect, 1 - Negative, 2 - Grayscale, 3 - Red Tint, 4 - Green Tint, 5 - Blue Tint, 6 - Sepia)
  s->set_whitebal(s, 1);       // 0 = disable , 1 = enable
  s->set_awb_gain(s, 1);       // 0 = disable , 1 = enable
  s->set_wb_mode(s, 0);        // 0 to 4 - if awb_gain enabled (0 - Auto, 1 - Sunny, 2 - Cloudy, 3 - Office, 4 - Home)
  s->set_exposure_ctrl(s, 1);  // 0 = disable , 1 = enable
  s->set_aec2(s, 0);           // 0 = disable , 1 = enable
  s->set_ae_level(s, 0);       // -2 to 2
  s->set_aec_value(s, 300);    // 0 to 1200
  s->set_gain_ctrl(s, 1);      // 0 = disable , 1 = enable
  s->set_agc_gain(s, 0);       // 0 to 30
  s->set_gainceiling(s, (gainceiling_t)0);  // 0 to 6
  s->set_bpc(s, 0);            // 0 = disable , 1 = enable
  s->set_wpc(s, 1);            // 0 = disable , 1 = enable
  s->set_raw_gma(s, 1);        // 0 = disable , 1 = enable
  s->set_lenc(s, 1);           // 0 = disable , 1 = enable
  s->set_hmirror(s, 0);        // 0 = disable , 1 = enable
  s->set_vflip(s, 0);          // 0 = disable , 1 = enable
  s->set_dcw(s, 1);            // 0 = disable , 1 = enable
  s->set_colorbar(s, 0);       // 0 = disable , 1 = enable
} //void configureCameraSettings()
bool configInitCamera()
  camera_config_t config = {}; // Stores the camera configuration parameters
  config.ledc_channel = LEDC_CHANNEL_0;
  config.ledc_timer   = LEDC_TIMER_0;
  config.pin_d0       = GPIO_NUM_5; //Y2
  config.pin_d1       = GPIO_NUM_18; //Y3
  config.pin_d2       = GPIO_NUM_19; //Y4
  config.pin_d3       = GPIO_NUM_21; //Y5
  config.pin_d4       = GPIO_NUM_36; //Y6
  config.pin_d5       = GPIO_NUM_39; //Y7
  config.pin_d6       = GPIO_NUM_34; //Y8
  config.pin_d7       = GPIO_NUM_35; // Y9
  config.pin_xclk     = GPIO_NUM_0; //XCLK
  config.pin_pclk     = GPIO_NUM_22; //PCLK
  config.pin_vsync    = GPIO_NUM_25; //VSSYNC
  config.pin_href     = GPIO_NUM_23; // HREF
  config.pin_sscb_sda = GPIO_NUM_26; //SIOD
  config.pin_sscb_scl = GPIO_NUM_27; //SIOC
  config.pin_pwdn     = GPIO_NUM_32; //PWDN
  config.pin_reset    = -1; //RESET
  config.xclk_freq_hz = 20000000;
  config.pixel_format = PIXFORMAT_JPEG; //assuming default is has PSRAM
  config.frame_size = FRAMESIZE_UXGA; // FRAMESIZE_ + QVGA|CIF|VGA|SVGA|XGA|SXGA|UXGA
  config.jpeg_quality = 10; //0-63 lower number means higher quality
  config.fb_count = 2;
  // Initialize the Camera
  esp_err_t err = esp_camera_init(&config);
  if (err != ESP_OK) {
    log_i("Camera init failed with error 0x%x", err);
    return false;
    configureCameraSettings();
    return true;
} //void configInitCamera()
void connectToWiFi()
  int TryCount = 0;
  while ( WiFi.status() != WL_CONNECTED )
    TryCount++;
    WiFi.disconnect();
    WiFi.begin( SSID, PASSWORD );
    vTaskDelay( 4000 );
    if ( TryCount == 10 )
      ESP.restart();
  WiFi.onEvent( WiFiEvent );
void loop() {}
Thanks that's great one question is " Connected to WiFi access point" means I would need a AP. I need the solution to be as minimal as possible and devices connect to each other hopefully without a wireless access point.
Silly question,
Modem Serial is
TX 27
RX 26
(technically is this Serial2?)
TXD G01001 Serial TX (is this Pin 1?)
RXD G01003 Serial RX (is this Pin 3?)
void setup(){
  //Serial.begin(Baud Rate, Data Protocol, Txd pin, Rxd pin);
  Serial.begin(115200);                                                     // Define and start serial monitor
  // 115200,256000,512000,962100
  Serial2.begin(962100, SERIAL_8N1); //Receiver_Txd_pin, Receiver_Rxd_pin); // Define and start Receiver serial port
  myTransfer.begin(Serial2);
This code here Transfer pictures from ESP32-CAM to ESP32 via serial - #58 by Power_Broker is another example like the FTP one you added above.
ESP32 CAM flashed with the TX Code and I see it writing to a FTDI programmer where we swap RX and TX board, wired as below
Added to the ESP32CAM to T-SIM7600(ESP32) so am I swapping TX-TX and RX-RX?
TXD G01001 Serial TX -> ESP32CAM TX
RXD G01003 Serial RX ->ESP32CAM RX
// Set serial for debug console (to the Serial Monitor, default speed 115200)
#define SerialMon Serial
// Set serial for AT commands (to the module)
#define SerialAT Serial1
Which is the following on the TSIM7600
#define MODEM_TX            27
#define MODEM_RX            26
#define RXD2                1
#define TXD2                3
Serial2.begin(962100, SERIAL_8N1,TXD2,RXD2);
So in the case of the FTDI programmer where we swap RX - TX and TX - RX but adding a ESP32Cam to a ESP32 TX to TX and RX to RX.
What are TXD and RXD? Can I use serial2 to transfer a image from ESP32Cam TXD/RXD (GPIO 1/3) to TSIM7600 TXD/RXD (GPIO 1/3)?
Whats the different between TX/RX and TXD/RXD?
 U0UXD is used to communicate with the ESP32 for programming and during reset/boot.
 U1UXD is unused and can be used for your projects. Some boards use this port for SPI Flash access though
 U2UXD is unused and can be used for your projects
