Add a offset to a clock
Hello,
i saw this amazing clock on instructables, but it has cables comming from the top of the clock instead of the bottom. Is there anyway to change the code so it's position is diffrent?
meaning the place where they cables go in becomes "6" instead of "12', a 180 degree offset,
mind you i have 0 experience in writing code, and this code is not mine.
I have asked the creator himself but there has been no communication.
Thank you in advance!
//************* Wol Clock by Jon Fuge ******************************
//************* Declare included libraries ******************************
#include <NTPClient.h>
#include <time.h>
#include <TimeLib.h>
#include <ESP8266WiFi.h>
#include <WiFiUdp.h>
//************* Declare structures ******************************
//Create structure for LED RGB information
struct RGB {
  byte r, g, b;
//Create structure for time information
struct TIME {
  byte Hour, Minute;
//************* Editable Options ******************************
//The colour of the "12" to give visual reference to the top
const RGB Twelve = { 128, 0, 128 }; //purple
//The colour of the "quarters" 3, 6 & 9 to give visual reference
const RGB Quarters = { 64, 0, 40 }; //purple
//The colour of the "divisions" 1,2,4,5,7,8,10 & 11 to give visual reference
const RGB Divisions = { 32, 0, 20 }; //purple
//All the other pixels with no information
const RGB Background = { 1, 3, 10 };//blue
//The Hour hand
const RGB Hour = { 255, 128, 0 };//orange maximum
//The Minute hand
const RGB Minute = { 64, 32, 0 };//orange medium
//The Second hand
const RGB Second = { 32, 16, 0 };//orange dim
// Make clock go forwards or backwards (dependant on hardware)
const char ClockGoBackwards = 0;
//Set brightness by time for night and day mode
const TIME WeekNight = {21, 30}; // Night time to go dim
const TIME WeekMorning = {6, 15}; //Morning time to go bright
const TIME WeekendNight = {21, 30}; // Night time to go dim
const TIME WeekendMorning = {9, 30}; //Morning time to go bright
const int day_brightness = 255;
const int night_brightness = 16;
//Set your timezone in hours difference rom GMT
const int hours_Offset_From_GMT = 1;
//Set your wifi details so the board can connect and get the time from the internet
const char *ssid      = "";    //  your network SSID (name)
const char *password  = ""; // your network password
byte SetClock;
// By default 'time.nist.gov' is used.
WiFiUDP ntpUDP;
NTPClient timeClient(ntpUDP,"time.windows.com" );
// Which pin on the ESP8266 is connected to the NeoPixels?
#define PIN            2 // This is the D5 pin
//************* Declare user functions ******************************
void Draw_Clock(time_t t, byte Phase);
int ClockCorrect(int Pixel);
void SetBrightness(time_t t);
void SetClockFromNTP ();
bool IsDst();
//************* Declare NeoPixel ******************************
Adafruit_NeoPixel pixels = Adafruit_NeoPixel(60, PIN, NEO_GRB + NEO_KHZ800);
//************* Setup function for Wol_Clock ******************************
  pixels.begin(); // This initializes the NeoPixel library.
  Draw_Clock(0, 1); // Just draw a blank clock
  WiFi.begin(ssid, password); // Try to connect to WiFi
  Draw_Clock(0, 2); // Draw the clock background
  while ( WiFi.status() != WL_CONNECTED )
    delay ( 500 ); // keep waiging until we successfully connect to the WiFi
  Draw_Clock(0, 3); // Add the quater hour indicators
  SetClockFromNTP(); // get the time from the NTP server with timezone correction
  timeClient.update(); // get the time from the NTP server
  setTime(timeClient.getEpochTime()); // Set the system yime from the clock
  if (IsDst())
    adjustTime((hours_Offset_From_GMT + 1) * 3600); // offset the system time with the user defined timezone (3600 seconds in an hour)
    adjustTime(hours_Offset_From_GMT * 3600); // offset the system time with the user defined timezone (3600 seconds in an hour)
bool IsDst()
  if (month() < 3 || month() > 10)  return false;
  if (month() > 3 && month() < 10)  return true;
  int previousSunday = day() - weekday();
  if (month() == 3) return previousSunday >= 24;
  if (month() == 10) return previousSunday < 24;
  return false; // this line never gonna happend
//************* Main program loop for Wol_Clock ******************************
  time_t t = now(); // Get the current time
  Draw_Clock(t, 4); // Draw the whole clock face with hours minutes and seconds
  if (minute(t) == 0) // at the start of each hour, update the time from the time server
    if (SetClock == 1)
      SetClock = 0;
    delay(200); // Just wait for 0.1 seconds
    SetClock = 1;
//************* Functions to draw the clock ******************************
  if (Phase <= 0)
    for (int i = 0; i < 60; i++)
      pixels.setPixelColor(i, pixels.Color(0, 0, 0)); // for Phase = 0 or less, all pixels are black
  if (Phase >= 1)
      pixels.setPixelColor(i, pixels.Color(Background.r, Background.g, Background.b)); // for Phase = 1 or more, draw minutes with Background colour
  if (Phase >= 2)
    for (int i = 0; i < 60; i = i + 5)
      pixels.setPixelColor(i, pixels.Color(Divisions.r, Divisions.g, Divisions.b)); // for Phase = 2 or more, draw 5 minute divisions
  if (Phase >= 3) {
    for (int i = 0; i < 60; i = i + 15)
      pixels.setPixelColor(ClockCorrect(i), pixels.Color(Quarters.r, Quarters.g, Quarters.b)); // for Phase = 3 or more, draw 15 minute divisions
    pixels.setPixelColor(ClockCorrect(0), pixels.Color(Six.r, Six.g, Six.b)); // for Phase = 3 and above, draw 12 o'clock indicator
  if (Phase >= 4) {
    pixels.setPixelColor(ClockCorrect(second(t)), pixels.Color(Second.r, Second.g, Second.b)); // draw the second hand first
    if (second() % 2)
      pixels.setPixelColor(ClockCorrect(minute(t)), pixels.Color(Minute.r, Minute.g, Minute.b)); // to help identification, minute hand flshes between normal and half intensity
      pixels.setPixelColor(ClockCorrect(minute(t)), pixels.Color(Minute.r / 2, Minute.g / 2, Minute.b / 2)); // lower intensity minute hand
    pixels.setPixelColor(ClockCorrect(((hour(t) % 12) * 5) + minute(t) / 12), pixels.Color(Hour.r, Hour.g, Hour.b)); // draw the hour hand last
  SetBrightness(t); // Set the clock brightness dependant on the time
  pixels.show(); // show all the pixels
//************* Function to set the clock brightness ******************************
  int NowHour = hour(t);
  int NowMinute = minute(t);
  if ((weekday() >= 2) && (weekday() <= 6))
    if ((NowHour > WeekNight.Hour) || ((NowHour == WeekNight.Hour) && (NowMinute >= WeekNight.Minute)) || ((NowHour == WeekMorning.Hour) && (NowMinute <= WeekMorning.Minute)) || (NowHour < WeekMorning.Hour))
      pixels.setBrightness(night_brightness);
      pixels.setBrightness(day_brightness);
  else if ((NowHour > WeekendNight.Hour) || ((NowHour == WeekendNight.Hour) && (NowMinute >= WeekendNight.Minute)) || ((NowHour == WeekendMorning.Hour) && (NowMinute <= WeekendMorning.Minute)) || (NowHour < WeekendMorning.Hour))
//************* This function reverses the pixel order ******************************
  if (ClockGoBackwards == 1)
    return ((60 - Pixel +30) % 60); // my first attempt at clock driving had it going backwards :)
    return (Pixel);
share a link to "this amazing clock on instructables". that will help us make sense of what you are asking for
I think that removing the "+30" in ClockCorrect(int Pixel) should rotate the clock 180 degrees.
sorry for the inconvenience,
here is the instructable link
Thank you John,
i will try removing the +30 and will update you with the result.
I have tried removing the +30, i also changed it to -30 and +15 just to see if there was any effect.
None of the changes did anything.
Oops. They turned that 'feature' off:
To make changes you'll have do it in the 'else' part of:
    return (Pixel);
I think you want to return (Pixel + 30) % 60; to rotate the clock half way.
----I think you want to return (Pixel + 30) % 60; to rotate the clock half way.----
That did it! now the clock works perfectly with the wires sticking from the bottom instead of the top!
Thank you John for your quick replies and help!
Yes it did work for me for a clockwise movement.
But I have a real problem.
I am from India and I am not able to set the time to IST by adding the offset for 5.30.The sketch accepts 5.30 but it does not reflect in the displayed time.The time shown is same for 5 and 5.30.So always this clock shows a 30 minute ahead.Also I like to know how to disable the DSTYour help is highly appreciated.Thanks in advance.
5h30 is 5.5 if you want to do maths
