How would you rather the word wrap worked ?
You could always put the array declaration in another tab so that it was only visible when you choose to see it
Try Alt+z in the IDE edit window
Word wrapping is disabled by default. I guess maybe you pressed that keyboard shortcut by accident (perhaps instead of the commonly used shortcut for "Undo": Ctrl+Z?). If that is something you would like to avoid, you can reassign the keyboard shortcut to something that is unlikely to ever be pressed by accident (e.g., Ctrl+Alt+Shift+Z).
The keyboard shortcuts are customizable by opening the File > Advanced > Keyboard Shortcuts menu. The command name is: "View: Toggle Word Wrap". Hover over it in the "Keyboard Shortcuts" panel and you will see a pencil icon appear to the left side. When you click that icon a dialog will open that allows you to change the keyboard shortcut for the command.
That what happens, when I press Alt+Z a few times.
So than not word wrap.
I've reinstalled arduino IDE and nothing changed.
By the way, it's actually word wrapping text that fills whole editor and wraps to a new line
And if I enable word wrap and set it to 9999 columns, nothing changes
I am able to reproduce it now. I remembered encountering this a long time ago, but earlier when I did an experiment by adding an extremely long line to a sketch, the wrapping didn't occur so I assumed it was fixed since then. But I see now that the wrapping only occurs when you open a sketch that already contains an extremely long line and this is why I couldn't reproduce it earlier.
It seems this behavior is inherited from VS Code (the free open source Eclipse Theia IDE framework used for Arduino IDE is based on VS Code). The reason for the behavior is explained here:
The difference between the Arduino IDE behavior and VS Code is that the wrap can be reverted by pressing the Alt+Z keyboard shortcut in VS Code, but it is impossible to revert the wrap in Arduino IDE. I verified this limitation comes from Theia instead of the Arduino IDE codebase. This means that in order for Arduino IDE to have the unwrapping capability for these lines the following would need to be done:
- Submit feature request to the Theia developers.
- Wait for Theia developers to implement the requested feature.
- Wait for Theia project maintainers to make a new release that contains the requested feature.
- Wait for Arduino IDE developers to update the Theia dependency to the version that has the feature.
As an immediate workaround, I would suggest adding line breaks to split this line into multiple lines that are each less than 10000 characters long (this is the maximum line length before the forced word wrapping behavior kicks in). In the case the array is data for a two dimensional object like an image, this type of formatting can actually make sense from a technical standpoint. The image encoding tool I have experience with actually provides the option to format the generated array this way automatically.
I really want to split lines, but arduino formatter merges them or moves each item on separate line depending on comma at the end of array.
I can reproduce the behavior of putting each element on its own line when a trailing comma is present in the array.
However, I can't reproduce this behavior when I remove the trailing comma:
Please provide a minimal sketch I can use to reproduce this formatting behavior and I'll find a solution for you to prevent it. In the worst case scenario you can add some special comments that will disable formatting of those lines by the IDE's "Auto Format" tool, so there definitely is a way, but I would like to check to see if there is a "cleaner" solution before resorting to that one.
Now I can't reproduce this issue...
May be it was my error or it was in some older versions of Arduino IDE
That could definitely be. The "Auto format" feature of older beta/release candidate versions of Arduino IDE 2.x used the default code formatting configuration of the ClangFormat tool. This configuration was later customized to provide results as close as possible to the formatter tool used by Arduino IDE 1.x.
Anyway, I'm glad it is now allowing bespoke array layouts (so long as you are not set on having a trailing comma).
Since I mentioned in passing above the availability of special comments to disable formatting selected portions of the sketch, I'll provide a link to that documentation in case it might be of interest to some future reader of this thread:
Oh I found it...
const uint8_t PROGMEM snowT[] = { // 128x25
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xf8,0x1f,0xf8,0x1f,0xf8,0x1f,0xf8,0x1f,0xf8,0x1f,0xf8,0x1f,0xf8,0x1f,0xf8,0x1f,0xf8,0x1f,0xf8,0x1f,0xf8,0x1f,0xf8,0x1f,0xf8,0x1f,0xf8,0x1f,0xf8,0x1f,0xf8,0x1f,0xf8,0x1f,0xf8,0x1f,0xf8,0x1f,0xf8,0x1f,0xf8,0x1f,0xf8,0x1f,0xf8,0x1f,0xf8,0x1f,0xf8,0x1f,0xf8,0x1f,0xf8,0x1f,0xf8,0x1f,0xf8,0x1f,0xf8,0x1f,0xf8,0x1f,0xf8,0x1f,0xf8,0x1f,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xf8,0x1f,0xf8,0x1f,0xf8,0x1f,0xf8,0x1f,0xf8,0x1f,0xf8,0x1f,0xf8,0x1f,0xf8,0x1f,0xf8,0x1f,0xf8,0x1f,0xf8,0x1f,0xf8,0x1f,0xf8,0x1f,0xf8,0x1f,0xf8,0x1f,0xf8,0x1f,0xf8,0x1f,0xf8,0x1f,0xf8,0x1f,0xf8,0x1f,0xf8,0x1f,0xf8,0x1f,0xf8,0x1f,0xf8,0x1f,0xf8,0x1f,0xf8,0x1f,0xf8,0x1f,0xf8,0x1f,0xf8,0x1f,0xf8,0x1f,0xf8,0x1f,0xf8,0x1f,0xf8,0x1f,0xf8,0x1f,0xf8,0x1f,0xf8,0x1f,0xf8,0x1f,0xf8,0x1f,0xf8,0x1f,0xf8,0x1f,0xf8,0x1f,0xf8,0x1f,0xf8,0x1f,0xf8,0x1f,0xf8,0x1f,0xf8,0x1f,0xf8,0x1f,0xf8,0x1f,0xf8,0x1f,0xf8,0x1f,0xf8,0x1f,0xf8,0x1f,0xf8,0x1f,0xf8,0x1f,0xf8,0x1f,0xf8,0x1f,0xf8,0x1f,0xf8,0x1f,0xf8,0x1f,0xf8,0x1f,0xf8,0x1f,0xf8,0x1f,0xf8,0x1f,0xf8,0x1f,0xf8,0x1f,0xf8,0x1f,0xf8,0x1f
,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0x00,0x00,0x00,0x00,0xf8,0x1f,0xf8,0x1f,0xf8,0x1f,0xf8,0x1f,0xf8,0x1f,0xf8,0x1f,0xf8,0x1f,0xf8,0x1f,0xf8,0x1f,0xf8,0x1f,0xf8,0x1f,0xf8,0x1f,0xf8,0x1f,0xf8,0x1f,0xf8,0x1f,0xf8,0x1f,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xf8,0x1f,0xf8,0x1f,0xf8,0x1f,0xf8,0x1f,0xf8,0x1f,0xf8,0x1f,0xf8,0x1f,0xf8,0x1f,0xf8,0x1f,0xf8,0x1f,0xf8,0x1f,0xf8,0x1f,0xf8,0x1f,0xf8,0x1f,0xf8,0x1f,0xf8,0x1f,0xf8,0x1f,0xf8,0x1f,0xf8,0x1f,0xf8,0x1f,0xf8,0x1f,0xf8,0x1f,0xf8,0x1f,0xf8,0x1f,0xf8,0x1f,0xf8,0x1f,0xf8,0x1f,0xf8,0x1f,0xf8,0x1f,0xf8,0x1f,0xf8,0x1f,0xf8,0x1f,0xf8,0x1f,0xf8,0x1f,0xf8,0x1f,0xf8,0x1f,0xf8,0x1f,0xf8,0x1f,0xf8,0x1f,0xf8,0x1f,0xf8,0x1f,0xf8,0x1f,0xf8,0x1f,0xf8,0x1f,0xf8,0x1f,0xf8,0x1f,0xf8,0x1f,0xf8,0x1f,0xf8,0x1f,0xf8,0x1f,0xf8,0x1f,0xf8,0x1f,0xf8,0x1f,0xf8,0x1f,0xf8,0x1f,0xf8,0x1f,0xf8,0x1f,0xf8,0x1f,0xf8,0x1f,0xf8,0x1f,0xf8,0x1f,0xf8,0x1f
,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0x00,0x00,0x00,0x00,0x00,0x00,0xf8,0x1f,0xf8,0x1f,0xf8,0x1f,0xf8,0x1f,0xf8,0x1f,0xf8,0x1f,0xf8,0x1f,0xf8,0x1f,0xf8,0x1f,0xf8,0x1f,0xf8,0x1f,0xf8,0x1f,0xf8,0x1f,0xf8,0x1f,0xf8,0x1f,0xf8,0x1f,0xf8,0x1f,0xf8,0x1f,0xf8,0x1f,0xf8,0x1f,0xf8,0x1f,0xf8,0x1f,0xf8,0x1f,0xf8,0x1f,0xf8,0x1f,0xf8,0x1f,0xf8,0x1f,0xf8,0x1f,0xf8,0x1f,0xf8,0x1f,0xf8,0x1f,0xf8,0x1f,0xf8,0x1f,0xf8,0x1f,0xf8,0x1f,0xf8,0x1f,0xf8,0x1f,0xf8,0x1f,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00
,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xf8,0x1f,0xf8,0x1f,0xf8,0x1f,0xf8,0x1f,0xf8,0x1f,0xf8,0x1f,0xf8,0x1f,0xf8,0x1f,0xf8,0x1f,0xf8,0x1f,0xf8,0x1f,0xf8,0x1f,0xf8,0x1f,0xf8,0x1f,0xf8,0x1f,0xf8,0x1f,0xf8,0x1f,0xf8,0x1f,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff
,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff
,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff
,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xd7,0xbf,0xd7,0xbf,0xd7,0xbf,0xd7,0xbf,0xd7,0xbf,0xd7,0xbf,0xd7,0xbf,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff
,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xd7,0xbf,0xd7,0xbf,0xd7,0xbf,0xd7,0xbf,0xd7,0xbf,0xd7,0xbf,0xd7,0xbf,0xd7,0xbf,0xd7,0xbf,0xd7,0xbf,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xd7,0xbf,0xd7,0xbf,0xd7,0xbf,0xd7,0xbf,0xd7,0xbf,0xd7,0xbf,0xd7,0xbf,0xd7,0xbf,0xd7,0xbf,0xd7,0xbf,0xd7,0xbf,0xd7,0xbf,0xd7,0xbf,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff
,0xff,0xff,0xff,0xff,0xff,0xff,0xd7,0xbf,0xd7,0xbf,0xd7,0xbf,0xd7,0xbf,0xd7,0xbf,0xd7,0xbf,0xd7,0xbf,0xd7,0xbf,0xd7,0xbf,0xd7,0xbf,0xd7,0xbf,0xd7,0xbf,0xd7,0xbf,0xd7,0xbf,0xd7,0xbf,0xd7,0xbf,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xd7,0xbf,0xd7,0xbf,0xd7,0xbf,0xd7,0xbf,0xd7,0xbf,0xd7,0xbf,0xd7,0xbf,0xd7,0xbf,0xd7,0xbf,0xd7,0xbf,0xd7,0xbf,0xd7,0xbf,0xd7,0xbf,0xd7,0xbf,0xd7,0xbf,0xd7,0xbf,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xd7,0xbf,0xd7,0xbf,0xd7,0xbf,0xd7,0xbf,0xd7,0xbf,0xd7,0xbf,0xd7,0xbf,0xd7,0xbf,0xd7,0xbf,0xd7,0xbf,0xd7,0xbf,0xd7,0xbf,0xd7,0xbf,0xd7,0xbf,0xd7,0xbf,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xd7,0xbf
,0xff,0xff,0xd7,0xbf,0xd7,0xbf,0xd7,0xbf,0xd7,0xbf,0xd7,0xbf,0xd7,0xbf,0xd7,0xbf,0xd7,0xbf,0xd7,0xbf,0xd7,0xbf,0xd7,0xbf,0xd7,0xbf,0xd7,0xbf,0xd7,0xbf,0xd7,0xbf,0xd7,0xbf,0xd7,0xbf,0xd7,0xbf,0xd7,0xbf,0xd7,0xbf,0xd7,0xbf,0xd7,0xbf,0xd7,0xbf,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xd7,0xbf,0xd7,0xbf,0xd7,0xbf,0xd7,0xbf,0xd7,0xbf,0xd7,0xbf,0xd7,0xbf,0xd7,0xbf,0xd7,0xbf,0xd7,0xbf,0xd7,0xbf,0xd7,0xbf,0xd7,0xbf,0xd7,0xbf,0xd7,0xbf,0xd7,0xbf,0xd7,0xbf,0xd7,0xbf,0xd7,0xbf,0xd7,0xbf,0xd7,0xbf,0xd7,0xbf,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xd7,0xbf,0xd7,0xbf,0xd7,0xbf,0xd7,0xbf,0xd7,0xbf,0xd7,0xbf,0xd7,0xbf,0xd7,0xbf,0xd7,0xbf,0xd7,0xbf,0xd7,0xbf,0xd7,0xbf,0xd7,0xbf,0xd7,0xbf,0xd7,0xbf,0xd7,0xbf,0xd7,0xbf,0xd7,0xbf,0xd7,0xbf,0xd7,0xbf,0xd7,0xbf,0xd7,0xbf,0xd7,0xbf,0xd7,0xbf,0xd7,0xbf,0xd7,0xbf,0xd7,0xbf,0xd7,0xbf,0xd7,0xbf,0xd7,0xbf,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xd7,0xbf,0xd7,0xbf
,0xd7,0xbf,0xd7,0xbf,0xd7,0xbf,0xd7,0xbf,0xd7,0xbf,0xd7,0xbf,0xd7,0xbf,0xd7,0xbf,0xd7,0xbf,0xd7,0xbf,0xd7,0xbf,0xd7,0xbf,0xd7,0xbf,0xd7,0xbf,0xd7,0xbf,0xd7,0xbf,0xd7,0xbf,0xd7,0xbf,0xd7,0xbf,0xd7,0xbf,0xd7,0xbf,0xd7,0xbf,0xd7,0xbf,0xd7,0xbf,0xd7,0xbf,0xd7,0xbf,0xd7,0xbf,0xd7,0xbf,0xd7,0xbf,0xd7,0xbf,0xd7,0xbf,0xd7,0xbf,0xd7,0xbf,0xd7,0xbf,0xd7,0xbf,0xd7,0xbf,0xd7,0xbf,0xd7,0xbf,0xd7,0xbf,0xd7,0xbf,0xd7,0xbf,0xd7,0xbf,0xd7,0xbf,0xd7,0xbf,0xd7,0xbf,0xd7,0xbf,0xd7,0xbf,0xd7,0xbf,0xd7,0xbf,0xd7,0xbf,0xd7,0xbf,0xd7,0xbf,0xd7,0xbf,0xd7,0xbf,0xd7,0xbf,0xd7,0xbf,0xd7,0xbf,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xd7,0xbf,0xd7,0xbf,0xd7,0xbf,0xd7,0xbf,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xd7,0xbf,0xd7,0xbf,0xd7,0xbf,0xd7,0xbf,0xd7,0xbf,0xd7,0xbf,0xd7,0xbf,0xd7,0xbf,0xd7,0xbf,0xd7,0xbf,0xd7,0xbf,0xd7,0xbf,0xd7,0xbf,0xd7,0xbf,0xd7,0xbf,0xd7,0xbf,0xd7,0xbf,0xd7,0xbf,0xd7,0xbf,0xd7,0xbf,0xd7,0xbf,0xd7,0xbf,0xd7,0xbf,0xd7,0xbf,0xd7,0xbf,0xd7,0xbf,0xd7,0xbf,0xd7,0xbf,0xd7,0xbf,0xd7,0xbf,0xd7,0xbf,0xd7,0xbf,0xd7,0xbf,0xd7,0xbf,0xd7,0xbf,0xd7,0xbf,0xd7,0xbf,0xd7,0xbf,0xd7,0xbf,0xd7,0xbf,0xd7,0xbf,0xd7,0xbf,0xd7,0xbf,0xd7,0xbf,0xd7,0xbf,0xd7,0xbf,0xd7,0xbf
,0xd7,0xbf,0xd7,0xbf,0xd7,0xbf,0xd7,0xbf,0xd7,0xbf,0xd7,0xbf,0xd7,0xbf,0xd7,0xbf,0xd7,0xbf,0xd7,0xbf,0xd7,0xbf,0xd7,0xbf,0xd7,0xbf,0xd7,0xbf,0xd7,0xbf,0xd7,0xbf,0xd7,0xbf,0xd7,0xbf,0xd7,0xbf,0xd7,0xbf,0xd7,0xbf,0xd7,0xbf,0xd7,0xbf,0xd7,0xbf,0xd7,0xbf,0xd7,0xbf,0xd7,0xbf,0xd7,0xbf,0xd7,0xbf,0xd7,0xbf,0xd7,0xbf,0xd7,0xbf,0xd7,0xbf,0xd7,0xbf,0xd7,0xbf,0xd7,0xbf,0xd7,0xbf,0xd7,0xbf,0xd7,0xbf,0xd7,0xbf,0xd7,0xbf,0xd7,0xbf,0xd7,0xbf,0xd7,0xbf,0xd7,0xbf,0xd7,0xbf,0xd7,0xbf,0xd7,0xbf,0xd7,0xbf,0xd7,0xbf,0xd7,0xbf,0xd7,0xbf,0xd7,0xbf,0xd7,0xbf,0xd7,0xbf,0xd7,0xbf,0xd7,0xbf,0xd7,0xbf,0xd7,0xbf,0xd7,0xbf,0xd7,0xbf,0xd7,0xbf,0xd7,0xbf,0xd7,0xbf,0xd7,0xbf,0xd7,0xbf,0xd7,0xbf,0xd7,0xbf,0xd7,0xbf,0xd7,0xbf,0xd7,0xbf,0xd7,0xbf,0xd7,0xbf,0xd7,0xbf,0xd7,0xbf,0xd7,0xbf,0xd7,0xbf,0xd7,0xbf,0xd7,0xbf,0xd7,0xbf,0xd7,0xbf,0xd7,0xbf,0xd7,0xbf,0xd7,0xbf,0xd7,0xbf,0xd7,0xbf,0xd7,0xbf,0xd7,0xbf,0xd7,0xbf,0xd7,0xbf,0xd7,0xbf,0xd7,0xbf,0xd7,0xbf,0xd7,0xbf,0xd7,0xbf,0xd7,0xbf,0xd7,0xbf,0xd7,0xbf,0xd7,0xbf,0xd7,0xbf,0xd7,0xbf,0xd7,0xbf,0xd7,0xbf,0xd7,0xbf,0xd7,0xbf,0xd7,0xbf,0xd7,0xbf,0xd7,0xbf,0xd7,0xbf,0xd7,0xbf,0xd7,0xbf,0xd7,0xbf,0xd7,0xbf,0xd7,0xbf,0xd7,0xbf,0xd7,0xbf,0xd7,0xbf,0xd7,0xbf,0xd7,0xbf,0xd7,0xbf,0xd7,0xbf,0xd7,0xbf,0xd7,0xbf,0xd7,0xbf,0xd7,0xbf,0xd7,0xbf,0xd7,0xbf,0xd7,0xbf
EDIT: Output from here: Convert picture to C code array
