Add an authorization section to this code
Hello,
I use an Arduino Mega and a SIM800L device. From the mobile phone I send SMS commands to turn on a light.
The code used is:
#include <gprs.h>
#include <softwareserial.h>
#define TIMEOUT    5000
#define LED_PIN    13
bool ledStatus;
GPRS gprs;
  while(!Serial);
  Serial.println("Starting SIM800 SMS Command Processor");
  gprs.preInit();
  while(0 != gprs.init()) {
      Serial.print("init error\r\n");
  //Set SMS mode to ASCII
  if(0 != gprs.sendCmdAndWaitForResp("AT+CMGF=1\r\n", "OK", TIMEOUT)) {
    ERROR("ERROR:CNMI");
    return;
  //Start listening to New SMS Message Indications
  if(0 != gprs.sendCmdAndWaitForResp("AT+CNMI=1,2,0,0,0\r\n", "OK", TIMEOUT)) {
    return;
  Serial.println("Init success");
//Variable to hold last line of serial output from SIM800
char currentLine[500] = "";
int currentLineIndex = 0;
//Boolean to be set to true if message notificaion was found and next
//line of serial output is the actual SMS message content
bool nextLineIsMessage = false;
  //Write current status to LED pin
  digitalWrite(LED_PIN, ledStatus);
  //If there is serial output from SIM800
  if(gprs.serialSIM800.available()){
    char lastCharRead = gprs.serialSIM800.read();
    //Read each character from serial output until \r or \n is reached (which denotes end of line)
    if(lastCharRead == '\r' || lastCharRead == '\n'){
        String lastLine = String(currentLine);
        //If last line read +CMT, New SMS Message Indications was received.
        //Hence, next line is the message content.
        if(lastLine.startsWith("+CMT:")){
          Serial.println(lastLine);
          nextLineIsMessage = true;
        } else if (lastLine.length() > 0) {
          if(nextLineIsMessage) {
            //Read message content and set status according to SMS content
            //Begin Section
            if(lastLine.indexOf("LED ON") >= 0){
              ledStatus = 1;
            } else if(lastLine.indexOf("LED OFF") >= 0) {
              ledStatus = 0;
            //Section End
        //Clear char array for next line of read
        for( int i = 0; i < sizeof(currentLine);  ++i ) {
         currentLine[i] = (char)0;
      currentLine[currentLineIndex++] = lastCharRead;
Please advise me how to add an authorization section to this code.
The LED on / off command to be executed only if the message has been sent from a specific phone number.
I tried to extract the sender number and compare it to a preset number but I did not succeed.
I've been using Arduino for a short time, I'm not an expert. I've decided to post my question here after I've been looking for information about string comparison, SMS extraction, and more in the last six months.
Thank you
I am not the best coder, but there is nothing in your code to compare the numbers.
If you receive a sms, what is the output your are getting from the module?
My ideea:
Extract sender number from CMT response and compare with a number declared in the begining of code.
Using If statement if numbers are same executing code between
//Start Section
//End Section
else do nothing.
Sounds like a good plan to me.
