I would like to add another serial USB port to my Mega R3 board, so I can talk to the PC via 2 x USB ports (or more!) simultaneously.
My searching / the reference leads me to the fact that I need a USB to Serial adaptor.
Having googled for such devices, I have turned up cables and what not, but am not sure where to start. A shield would be nice, but I am happy to cobble something together if someone could point to a web page or schematic or...
Is this something unusual I want to do? I have not managed to find a single example of someone doing this to take advantage of the Mega's 4 serial ports.
mikroe-483 at mouser.com
http://www.mouser.com/ProductDetail/mikroElektronika/MIKROE-483/?qs=%2fha2pyFaduhQ%2frcyPs7PmGdeFG1B7qIuGl16liNH8Zb3mCcKALPhoQ%3d%3d
I think this is the lowest priced FTDI based USB/Serial module going - $8.75, dowm from $10.95 (which was also the lowest).
Connect Tx to Rx1, Rx to Tx1, Gnd to Gnd. Device is powered from PC. Your mega is powered from whatever.
Lots of other USB/Serial adapters out, any will do the same.
I build these into designs to skip the hassle of soldering that little part:
Space on lower right is for one of these, if offboard adapter is not used:
This board also uses one:
I could solder in a header and plug it into the Mega’s header directly for Rx/Tx, but access to ground from that position is going to be tricky - do you have any advice there?
