I have tried to add buttons to this web page by duplicating the existing buttons in the Web page.
However if I click on the duplicate buttons they imitate the existing buttons, and I have tried other methods which were not successful. HTML not my strong side
Is this page expandable?
Thanks to all who have helped with my endeavour`s.
marco_simonetti:
I don't know if is the solution, anyway, you forget to close the tag
opened before the first button.
Close the tag after the second button and try again... let us know.
Thanks for your interest, but the code needs some addition like, /* /?LED=ON\ to /?LED2=ON\ /or something. And prior to that, This must change, / int position = string.indexOf("LED="); // */ I assume. I have tried several ways but no go
At the moment he can't try this snippet, but if you can try it, you can send me output or behaviour of the sketch. Probably you have just try this path.
Hope this helps
Combined client/server code that has several buttons.
//zoomkat 7-03-12, combined client and server
//simple button GET with iframe code
//for use with IDE 1.0
//open serial monitor and send an g to test client and
//see what the arduino client/server receives
//web page buttons make pin 5 high/low
//use the ' in html instead of " to prevent having to escape the "
//address will look like http://192.168.1.102:84 when submited
//for use with W5100 based ethernet shields
//note that the below bug fix may be required
// http://code.google.com/p/arduino/issues/detail?id=605
#include <SPI.h>
#include <Ethernet.h>
byte mac[] = {0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED }; //assign arduino mac address
byte ip[] = {192, 168, 1, 102 }; // ip in lan assigned to arduino
byte gateway[] = {192, 168, 1, 1 }; // internet access via router
byte subnet[] = {255, 255, 255, 0 }; //subnet mask
EthernetServer server(84); //server port arduino server will use
EthernetClient client;
char serverName[] = "checkip.dyndns.com"; // (DNS) zoomkat's test web page server
//byte serverName[] = { 208, 104, 2, 86 }; // (IP) zoomkat web page server IP address
String readString; //used by server to capture GET request
void setup(){
pinMode(5, OUTPUT); //pin selected to control
pinMode(6, OUTPUT); //pin selected to control
pinMode(7, OUTPUT); //pin selected to control
pinMode(8, OUTPUT); //pin selected to control
//pinMode(5, OUTPUT); //pin 5 selected to control
Ethernet.begin(mac,ip,gateway,gateway,subnet);
server.begin();
Serial.println(F("server/client 1.0 test 7/03/12")); // keep track of what is loaded
Serial.println(F("Send an g in serial monitor to test client")); // what to do to test client
void loop(){
// check for serial input
if (Serial.available() > 0)
byte inChar;
inChar = Serial.read();
if(inChar == 'g')
sendGET(); // call client sendGET function
if (client) {
while (client.connected()) {
if (client.available()) {
char c = client.read();
//read char by char HTTP request
if (readString.length() < 100) {
//store characters to string
readString += c;
//Serial.print(c);
//if HTTP request has ended
if (c == '\n') {
Serial.print(readString); //print to serial monitor for debuging
//now output HTML data header
if(readString.indexOf('?') >=0) { //don't send new page
client.println(F("HTTP/1.1 204 Zoomkat"));
client.println();
client.println();
else {
client.println(F("HTTP/1.1 200 OK")); //send new page on browser request
client.println(F("Content-Type: text/html"));
client.println();
client.println(F("<HTML>"));
client.println(F("<HEAD>"));
client.println(F("<TITLE>Arduino GET test page</TITLE>"));
client.println(F("</HEAD>"));
client.println(F("<BODY>"));
client.println(F("<H1>Zoomkat's simple Arduino 1.0 button</H1>"));
// DIY buttons
client.println(F("Pin5"));
client.println(F("<a href=/?on2 target=inlineframe>ON</a>"));
client.println(F("<a href=/?off3 target=inlineframe>OFF</a>
client.println(F("Pin6"));
client.println(F("<a href=/?on4 target=inlineframe>ON</a>"));
client.println(F("<a href=/?off5 target=inlineframe>OFF</a>
client.println(F("Pin7"));
client.println(F("<a href=/?on6 target=inlineframe>ON</a>"));
client.println(F("<a href=/?off7 target=inlineframe>OFF</a>
client.println(F("Pin8"));
client.println(F("<a href=/?on8 target=inlineframe>ON</a>"));
client.println(F("<a href=/?off9 target=inlineframe>OFF</a>
client.println(F("Pins"));
client.println(F(" <a href=/?off2468 target=inlineframe>ALL ON</a>"));
client.println(F(" <a href=/?off3579 target=inlineframe>ALL OFF</a>
// mousedown buttons
client.println(F("<input type=button value=ON onmousedown=location.href='/?on4;' target=inlineframe>"));
client.println(F("<input type=button value=OFF onmousedown=location.href='/?off5;' target=inlineframe>"));
client.println(F(" <input type=button value='ALL OFF' onmousedown=location.href='/?off3579;' target=inlineframe>
// mousedown radio buttons
client.println(F("<input type=radio onmousedown=location.href='/?on6;' target=inlineframe>ON</>"));
client.println(F("<input type=radio onmousedown=location.href='/?off7; target=inlineframe'>OFF</>"));
client.println(F(" <input type=radio onmousedown=location.href='/?off3579;' target=inlineframe>ALL OFF</>
// custom buttons
client.print(F("<input type=submit value=ON target=inlineframe style=width:100px;height:45px onClick=location.href='/?on8;'>"));
client.print(F("<input type=submit value=OFF target=inlineframe style=width:100px;height:45px onClick=location.href='/?off9;' target=inlineframe>"));
client.print(F(" <input type=submit value='ALL OFF' target=inlineframe style=width:100px;height:45px onClick=location.href='/?off3579;' target=inlineframe>"));
client.println(F("<IFRAME name=inlineframe style='display:none'>"));
client.println(F("</IFRAME>"));
client.println(F("</BODY>"));
client.println(F("</HTML>"));
delay(1);
//stopping client
client.stop();
///////////////////// control arduino pin
if(readString.indexOf('2') >0)//checks for 2
digitalWrite(5, HIGH); // set pin 5 high
Serial.println("Led 5 On");
if(readString.indexOf('3') >0)//checks for 3
digitalWrite(5, LOW); // set pin 5 low
Serial.println("Led 5 Off");
if(readString.indexOf('4') >0)//checks for 4
digitalWrite(6, HIGH); // set pin 6 high
Serial.println("Led 6 On");
if(readString.indexOf('5') >0)//checks for 5
digitalWrite(6, LOW); // set pin 6 low
Serial.println("Led 6 Off");
if(readString.indexOf('6') >0)//checks for 6
digitalWrite(7, HIGH); // set pin 7 high
Serial.println("Led 7 On");
if(readString.indexOf('7') >0)//checks for 7
digitalWrite(7, LOW); // set pin 7 low
Serial.println("Led 7 Off");
if(readString.indexOf('8') >0)//checks for 8
digitalWrite(8, HIGH); // set pin 8 high
Serial.println("Led 8 On");
if(readString.indexOf('9') >0)//checks for 9
digitalWrite(8, LOW); // set pin 8 low
Serial.println("Led 8 Off");
//clearing string for next read
readString="";
void sendGET() //client function to send and receive GET data from external server.
if (client.connect(serverName, 80)) {
Serial.println(F("connected"));
client.println(F("GET / HTTP/1.1"));
client.println(F("Host: checkip.dyndns.com"));
client.println(F("Connection: close"));
client.println();
else {
Serial.println(F("connection failed"));
while(client.connected() && !client.available()) delay(1); //waits for data
while (client.connected() || client.available()) { //connected or data available
Serial.print(c);
Serial.println(F("disconnecting."));
Serial.println(F("=================="));
client.stop();
