bolts:
I have made these changes myself to the ISR and it works well. But I have to apply the changes with each IDE release
Can you please describe in detail where you make the change and how you make it, and where do you put your ISR function in the sketch you write to make use of it?
ISR(TIMER0_OVF_vect)
unsigned long m = timer0_millis;
timer0_millis = m;
timer0_overflow_count++;
// New code
TIMER_OVF_Callback();
TIMER0_OVF_Callback would be initialized to point to a null function, and would have an API to set it to an arbitrary user function (just like attachInterrupt().)
It's actually a pretty bad idea. The was ISRs work on AVR, having any function call in your ISR causes a rather large number of additional expensive instructions to be added to save and restore context that is defined by the C ABI as "callee changeable."
