Add character to string
Hello,
I would like to add a character to a string. I tryied this:
  char datarcv;
  String content = "";
  while(Serial3.available())
    datarcv = Serial3.read();
    content.concat(datarcv);
    Serial.println(content);
But It display this (I send: test):
t
e
s
t
How resolve this ?
regards
But, you don't have a string. You have a String. Not the same thing at all.
Why do you expect something else? Serial data arrives sssslllloooowwwwllllyyyy. On every pass through loop, you reset the String to nothing, so it never holds more than one character.
FindL: How resolve this ?
You'd better consider: - the while-loop is running several thousand times per second - Serial is slow, at 9600 baud only one character per millisecond arrives
So if the posted code is within your loop() function (don't know about?), each time the while-loop begins, it finds none or one character in the Serial input buffer, but never more than one.
In a crappy code using string-objects instead of real C-strings, you could make the code even crappier (but working like intended) using "delay" to wait a little bit after the first character had been received:
 char datarcv;
  if (Serial3.available()) // now we have at least one character in the Serial input buffer
    delay(20); // just wait a little bit for more characters to arrive
    while(Serial3.available()) // look for all characters in the input buffer
    Serial.println(content); // and print them all together
