Add different atmel chip to Arduino
Hi folks,
I am working in a project using an AT90PWM chip. I am wondering what I should do in order to get this chip supported on Arduino.
I would also like to know how to get rid of the bootloader for once. Even on the 328's I never managed to fully get them working without the bootloader. I reckon the fuse settings set the chip to look for code where the bootloader should be and obviously there's nothing there. The other thing with the bootloader is that I don't want the fuses to get changed at upload time.
Greatfull for any tips/suggestions
In order to add a board to arduino there are some stepto be taken
Make sure you have a Hardware folder in [User]/Arduino
This older can have subfolders
The Hardware folders contains a boards.txt file
This file can have multiple entries, each entry follows this example:
attiny84-8.name=ATtiny84 (internal 8 MHz clock)
attiny84-8.bootloader.low_fuses=0xe2
attiny84-8.bootloader.high_fuses=0xdf
attiny84-8.bootloader.extended_fuses=0xff
attiny84-8.upload.maximum_size=8192
attiny84-8.build.mcu=attiny84
attiny84-8.build.f_cpu=8000000L
attiny84-8.build.core=arduino:arduino
attiny84-8.build.variant=tiny14
The .variant= in the last line refers to a folder ./variants/tiny14
This folder contains a pins_arduino.h which maps arduino pin numbers to port pins
