add eeprom data to main program
I have a tap tempo sketch that reads eeprom data but I can’t fit the eeprom data on a attiny85,
is it possible to add this eeprom data to my main sketch and read it from there instead?
if so how would I read it from the main program?
main sketch
Sketch uses 1792 bytes (21%) of program storage space. Maximum is 8192 bytes.
Global variables use 47 bytes (9%) of dynamic memory, leaving 465 bytes for local variables. Maximum is 512 bytes.
eeprom data
Sketch uses 1376 bytes (16%) of program storage space. Maximum is 8192 bytes.
Global variables use 1033 bytes (201%) of dynamic memory, leaving -521 bytes for local variables. Maximum is 512 bytes.
Not enough memory; see http://www.arduino.cc/en/Guide/Troubleshooting#size for tips on reducing your footprint.
Error compiling for board ATtiny25/45/85.
relevant parts of main sketch
  // ############### WRITE TO DELAY-MCP (POTCHANGEREQUIRED) ########################
  if (potchangerequired == HIGH)
    for (int i = 0; i < 256; i = i + 5)
      // The loop tries to find two values from the EEPROM, that "surround" current_ms
      pot_low = i;
      pot_high = i + 5;
      EEPROM_readAnything(i, pot_value_low);
      EEPROM_readAnything(i + 5, pot_value_high);
      if (current_ms >= pot_value_low && current_ms < pot_value_high)
        digipot_value = pot_low + (((current_ms - pot_value_low) * 100) / (pot_value_high - pot_value_low) * (pot_high - pot_low)) / 100;
        digitalPotWrite(slaveDelayPin, digipot_value);
        potchangerequired = LOW;
relevant parts of eeprom data
const uint8_t nano_data[] = {
  0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0x26, 0x00, 0xFF, 0xFF, 0x26, 0x4A, 0x00, 0x00, 0x00, 0xCB, 0x5F,
  0x00, 0x00, 0x00, 0xCB, 0x70, 0x00, 0x00, 0x00, 0xCB, 0x85, 0x00, 0x00, 0x00, 0xCB, 0x9A, 0x00,
  0x00, 0x00, 0xCB, 0xAC, 0x00, 0x00, 0x00, 0xCB, 0xC2, 0x00, 0x00, 0x00, 0xCB, 0xD5, 0x00, 0x00,
  0x00, 0xCB, 0xF0, 0x00, 0x00, 0x00, 0xCB, 0x08, 0x01, 0x00, 0x00, 0xCB, 0x22, 0x01, 0x00, 0x00,
  0xCB, 0x3B, 0x01, 0x00, 0x00, 0xCB, 0x56, 0x01, 0x00, 0x00, 0xCB, 0x70, 0x01, 0x00, 0x00, 0xCB,
  0x91, 0x01, 0x00, 0x00, 0xCB, 0xAC, 0x01, 0x00, 0x00, 0xCB, 0xCD, 0x01, 0x00, 0x00, 0xCB, 0xEE,
  0x01, 0x00, 0x00, 0xCB, 0x10, 0x02, 0x00, 0x00, 0xCB, 0x31, 0x02, 0x00, 0x00, 0xCB, 0x56, 0x02,
  0x00, 0x00, 0x37, 0x7F, 0x02, 0x00, 0x00, 0x37, 0xA8, 0x02, 0x00, 0x00, 0x37, 0xD1, 0x02, 0x00,
  0x00, 0x37, 0xF4, 0x02, 0x00, 0x00, 0x37, 0x2B, 0x03, 0x00, 0x00, 0x37, 0x5A, 0x03, 0x00, 0x00,
  0x37, 0x87, 0x03, 0x00, 0x00, 0x37, 0xBD, 0x03, 0x00, 0x00, 0x37, 0xF2, 0x03, 0x00, 0x00, 0x37,
  0x25, 0x04, 0x00, 0x00, 0x37, 0x5E, 0x04, 0x00, 0x00, 0x37, 0x99, 0x04, 0x00, 0x00, 0x37, 0xD7,
  0x04, 0x00, 0x00, 0x37, 0x17, 0x05, 0x00, 0x00, 0x37, 0x56, 0x05, 0x00, 0x00, 0x37, 0x96, 0x05,
  0x00, 0x00, 0x37, 0xDD, 0x05, 0x00, 0x00, 0x37, 0x27, 0x06, 0x00, 0x00, 0x37, 0x71, 0x06, 0x00,
  0x00, 0x37, 0xBD, 0x06, 0x00, 0x00, 0x37, 0x0C, 0x07, 0x00, 0x00, 0x37, 0x5E, 0x07, 0x00, 0x00,
  0x37, 0xB6, 0x07, 0x00, 0x00, 0x37, 0xE9, 0x07, 0x00, 0x00, 0x37, 0xE9, 0x07, 0x00, 0x00, 0x37,
  0x1E, 0x00, 0x00, 0x00, 0x37, 0x4E, 0x00, 0x00, 0x00, 0x37, 0x85, 0x00, 0x00, 0x00, 0x37, 0xB9,
  0x00, 0x00, 0x00, 0xFF, 0x33, 0x00, 0x00, 0x00, 0xFF, 0x43, 0x00, 0x00, 0x00, 0xFF, 0x5C, 0x00,
  0x00, 0x00, 0xFF, 0x6D, 0x00, 0x00, 0x00, 0xFF, 0x81, 0x00, 0x00, 0x00, 0xFF, 0x95, 0x00, 0x00,
  0x00, 0xFF, 0xAE, 0x00, 0x00, 0x00, 0xFF, 0xC2, 0x00, 0x00, 0x00, 0xFF, 0xD7, 0x00, 0x00, 0x00,
  0xFF, 0xF2, 0x00, 0x00, 0x00, 0xFF, 0x0A, 0x01, 0x00, 0x00, 0xFF, 0x29, 0x01, 0x00, 0x00, 0xFF,
  0x41, 0x01, 0x00, 0x00, 0xFF, 0x60, 0x01, 0x00, 0x00, 0xFF, 0x7F, 0x01, 0x00, 0x00, 0xFF, 0x9D,
  0x01, 0x00, 0x00, 0xFF, 0xC0, 0x01, 0x00, 0x00, 0xFF, 0xE4, 0x01, 0x00, 0x00, 0xFF, 0x08, 0x02,
  0x00, 0x00, 0xFF, 0x2F, 0x02, 0x00, 0x00, 0xFF, 0x01, 0x00, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF,
  0xFF, 0xFF, 0x47, 0x00, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0x50, 0x01, 0xFF, 0xFF,
  0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0x92, 0x00, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF,
  0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF,
Tap_Dual_Tiny84.ino (4.43 KB)
write_eeprom.ino (6.47 KB)
Write one sketch to write your data to the EEPROM.
Do not include the data in your main sketch.
Or put the data into PROGMEM.
