Add for loop in if statements
I am working on a project about controlling led bands with brainwave values. When I add the led's program into the if, the program goes into a dead loop.
  setColor();
  read_serial_data();
  if(attention>10&attention<50){
      for (int i=0; i < NUMPIXELS; i++) {
    // pixels.Color takes RGB values, from 0,0,0 up to 255,255,255
    pixels.setPixelColor(i, pixels.Color(redColor, greenColor, blueColor));
    // This sends the updated pixel color to the hardware.
    pixels.show();
    // Delay for a period of time (in milliseconds).
    delay(delayval);
How should I go about changing this code?
Thanks
void loop(){
  setColor();
  read_serial_data();
  if (attention > 10 & attention < 50) {
    for (int i = 0; i < NUMPIXELS; i++) {
    pixels.show();
    delay(delayval);
& does a bitwise AND
&& does a logical AND
I suspect that you are using the wrong one
What does that look like?
What does setColor() do?
How long is 'delayval'?
Hi,johnwasser
This is my entire program. The program stops when the if statement is met and the serial monitor no longer prints any data.
#define PIN 7         // input pin Neopixel is attached to
#define NUMPIXELS      12 // number of neopixels in strip
Adafruit_NeoPixel pixels = Adafruit_NeoPixel(NUMPIXELS, PIN, NEO_GRB + NEO_KHZ800);
int delayval = 100; // timing delay in milliseconds
int redColor = 0;
int greenColor = 0;
int blueColor = 0;
#define BAUDRATE 57600
#define DEBUGOUTPUT 0
int   generatedChecksum = 0;
byte  checksum = 0;
byte  payloadLength = 0;
byte  payloadData[32] = {0};
byte signalquality = 0;
byte attention = 0;
byte meditation = 0;
  Serial.begin(BAUDRATE);
  pixels.begin();
byte ReadOneByte()
  int ByteRead;
  while(!Serial.available());
  ByteRead = Serial.read();
  return ByteRead;
//读取串口数据
void read_serial_data()
    if(ReadOneByte() == 0xAA)
        payloadLength = ReadOneByte();
        if(payloadLength == 0x20)
          for(int i = 0; i < payloadLength; i++)
            payloadData[i] = ReadOneByte();
            generatedChecksum += payloadData[i];
          checksum = ReadOneByte();
          generatedChecksum = (~generatedChecksum)&0xff;
          if(checksum == generatedChecksum)
            signalquality = 0;
            attention = 0;
            signalquality = payloadData[1];
            attention = payloadData[29];
            meditation = payloadData[31];
            #if !DEBUGOUTPUT
            Serial.print("SignalQuality: ");
            Serial.print(signalquality, DEC);
            Serial.print("Attation: ");
            Serial.print(attention, DEC);
            Serial.print("Meditation: ");
            Serial.print(meditation, DEC);
            Serial.print("\n");
            #endif
void loop(){
  setColor();
  read_serial_data();
    pixels.show();
    delay(delayval);
void setColor(){
  redColor = random(0, 255);
  greenColor = random(0,255);
  blueColor = random(0, 255);
Did you do as suggested in post #3?
Put a serial print at the bottom of loop() and perhaps elsewhere to see if it actually "stops".
I have tried to replace for loop with serial print,like this:
  serial.print("test done")
it works. So I guess the problem is that the for loop is used in the if statement
I see that you still have a single & in that if statement. Is that deliberate ?
You still have this mistake:
Change that line to:
if (attention > 10 && attention < 50) {
