Add Meter to Serial Monitor options
Processing.com has a Meter (analog and digital) library that will work with an Arduino. Similar example code to use with Serial. How can this be incorporated into the IDE 2 interface to be used the same as the Serial Plotter?
Hi @BKujawa. Thanks for your interest in the Arduino IDE 2.x!
There is no need to integrate it. Your Processing sketches run independently of the Arduino IDE, and even if the Arduino IDE is not open at all.
The only thing needed is that the Arduino board is communicating with the Processing sketch over the serial port, which is exactly the same regardless of which Arduino IDE you are using.
Thank you for your time and answer. That will work. Just thought it might be more convenient.
