I have a sketch (below) which sends a message to an SD card when an IR beam is broken.
I also have a Real Time Clock attached SDA on 4 and SCL on 5. The clock returns the correct time and date when returning the value in the Serial Com.
How do I add the real time to return as a value on the SD card when the IR beam is broken?
Main sketch
//Based on Example by Tom Igoe
#include <SD.h>
//Set by default for the SD Card Library
//MOSI = Pin 11
//MISO = Pin 12
//SCLK = PIN 13
//We always need to set the CS Pin
int CS_pin = 8;
int pow_pin = 8;
//IR Distance Sensor Pins
int IR1_pin = 0;
float refresh_rate = 0.0;
Serial.println("Initializing Card");
//CS Pin is an output
pinMode(CS_pin, OUTPUT);
//Card will Draw Power from Pin 8, so set it high
pinMode(pow_pin, OUTPUT);
digitalWrite(pow_pin, HIGH);
//check if card is ready
if (!SD.begin(CS_pin))
Serial.println("Card Failure");
return;
Serial.println("Card Ready");
//Read the Configuration information (COMMANDS.txt)
File commandFile = SD.open("COMMANDS.txt");
if (commandFile)
Serial.println("Reading Command File");
float decade = pow(10, (commandFile.available() - 1));
while(commandFile.available())
float temp = (commandFile.read() - '0');
refresh_rate = temp*decade+refresh_rate;
decade = decade/10;
Serial.print("Refresh Rate = ");
Serial.print(refresh_rate);
Serial.println("ms");
Serial.println("Could not read command file.");
return;
int value = analogRead(IR1_pin);
if (value > 375 || value < 300)
Serial.println(value);
delay(500); //wait half a second, then check again.
//Open a file to write to
//Only one file can be open at a time
int IR1_val = Serial.println(value);
File logFile = SD.open("LOG.txt", FILE_WRITE | O_APPEND);
if (logFile)
logFile.println(analogRead(IR1_pin));
logFile.close();
And this is the Real Time sketch I am using.
#include "Wire.h"
#define DS1307_I2C_ADDRESS 0x68 // This is the I2C address
// Arduino version compatibility Pre-Compiler Directives
#if defined(ARDUINO) && ARDUINO >= 100 // Arduino v1.0 and newer
#define I2C_WRITE Wire.write
#define I2C_READ Wire.read
#else // Arduino Prior to v1.0
#define I2C_WRITE Wire.send
#define I2C_READ Wire.receive
#endif
// Global Variables
int command = 0; // This is the command char, in ascii form, sent from the serial port
int i;
long previousMillis = 0; // will store last time Temp was updated
byte second, minute, hour, dayOfWeek, dayOfMonth, month, year;
byte test;
byte zero;
char *Day[] = {"","Sun","Mon","Tue","Wed","Thu","Fri","Sat"};
char *Mon[] = {"","Jan","Feb","Mar","Apr","May","Jun","Jul","Aug","Sep","Oct","Nov","Dec"};
// Convert normal decimal numbers to binary coded decimal
byte decToBcd(byte val)
return ( (val/10*16) + (val%10) );
// Convert binary coded decimal to normal decimal numbers
byte bcdToDec(byte val)
return ( (val/16*10) + (val%16) );
// 1) Sets the date and time on the ds1307
// 2) Starts the clock
// 3) Sets hour mode to 24 hour clock
// Assumes you're passing in valid numbers, Probably need to put in checks for valid numbers.
void setDateDs1307()
second = (byte) ((Serial.read() - 48) * 10 + (Serial.read() - 48)); // Use of (byte) type casting and ascii math to achieve result.
minute = (byte) ((Serial.read() - 48) *10 + (Serial.read() - 48));
hour = (byte) ((Serial.read() - 48) *10 + (Serial.read() - 48));
dayOfWeek = (byte) (Serial.read() - 48);
dayOfMonth = (byte) ((Serial.read() - 48) *10 + (Serial.read() - 48));
month = (byte) ((Serial.read() - 48) *10 + (Serial.read() - 48));
year= (byte) ((Serial.read() - 48) *10 + (Serial.read() - 48));
Wire.beginTransmission(DS1307_I2C_ADDRESS);
I2C_WRITE(zero);
I2C_WRITE(decToBcd(second) & 0x7f); // 0 to bit 7 starts the clock
I2C_WRITE(decToBcd(minute));
I2C_WRITE(decToBcd(hour)); // If you want 12 hour am/pm you need to set
// bit 6 (also need to change readDateDs1307)
I2C_WRITE(decToBcd(dayOfWeek));
I2C_WRITE(decToBcd(dayOfMonth));
I2C_WRITE(decToBcd(month));
I2C_WRITE(decToBcd(year));
Wire.endTransmission();
// Gets the date and time from the ds1307 and prints result
void getDateDs1307()
// Reset the register pointer
I2C_WRITE(zero);
Wire.requestFrom(DS1307_I2C_ADDRESS, 7);
// A few of these need masks because certain bits are control bits
second = bcdToDec(I2C_READ() & 0x7f);
minute = bcdToDec(I2C_READ());
hour = bcdToDec(I2C_READ() & 0x3f); // Need to change this if 12 hour am/pm
dayOfWeek = bcdToDec(I2C_READ());
dayOfMonth = bcdToDec(I2C_READ());
month = bcdToDec(I2C_READ());
year = bcdToDec(I2C_READ());
if (hour < 10)
Serial.print("0");
Serial.print(hour, DEC);
Serial.print(":");
if (minute < 10)
Serial.print("0");
Serial.print(minute, DEC);
Serial.print(":");
if (second < 10)
Serial.print("0");
Serial.print(second, DEC);
Serial.print(" ");
Serial.print(Day[dayOfWeek]);
Serial.print(", ");
Serial.print(dayOfMonth, DEC);
Serial.print(" ");
Serial.print(Mon[month]);
Serial.print(" 20");
if (year < 10)
Serial.print("0");
Serial.println(year, DEC);
Wire.begin();
zero=0x00;
if (Serial.available()) { // Look for char in serial que and process if found
command = Serial.read();
if (command == 84 || command == 116) { //If command = "Tt" Set Date
setDateDs1307();
getDateDs1307();
Serial.println(" ");
else if (command == 82 || command == 114) { //If command = "Rr" Read Date ... BBR
getDateDs1307();
else if (command == 81 || command == 113) { //If command = "Qq" RTC1307 Memory Functions
delay(100);
if (command == 49) { //If command = "1" RTC1307 Initialize Memory - All Data will be set to
// 255 (0xff). Therefore 255 or 0 will be an invalid value.
Wire.beginTransmission(DS1307_I2C_ADDRESS); // 255 will be the init value and 0 will be considered
// an error that occurs when the RTC is in Battery mode.
I2C_WRITE(0x08); // Set the register pointer to be just past the date/time registers.
for (i = 1; i <= 24; i++) {
I2C_WRITE(0Xff);
delay(10);
I2C_WRITE(0x21); // Set the register pointer to 33 for second half of registers. Only 32 writes per connection allowed.
for (i = 1; i <= 33; i++) {
I2C_WRITE(0Xff);
delay(10);
getDateDs1307();
Serial.println(": RTC1307 Initialized Memory");
else if (command == 50) { //If command = "2" RTC1307 Memory Dump
getDateDs1307();
Serial.println(": RTC 1307 Dump Begin");
I2C_WRITE(zero);
Wire.requestFrom(DS1307_I2C_ADDRESS, 32);
for (i = 0; i <= 31; i++) { //Register 0-31 - only 32 registers allowed per I2C connection
test = I2C_READ();
Serial.print(i);
Serial.print(": ");
Serial.print(test, DEC);
Serial.print(" : ");
Serial.println(test, HEX);
I2C_WRITE(0x20);
for (i = 32; i <= 63; i++) { //Register 32-63 - only 32 registers allowed per I2C connection
test = I2C_READ();
Serial.print(i);
Serial.print(": ");
Serial.println(" RTC1307 Dump end");
Serial.print("Command: ");
Serial.println(command); // Echo command CHAR in ascii that was sent
command = 0; // reset command
delay(100);
How do I combine it all to one sketch?
