Add secondary integer for couting values
Hi, I'm Alexander, I'm an Arduino UNO and C++ beginner.
I'm stuck trying to add a secondary integer for counting values. I suspect that the issue is within the first if statement in the loop.
I have two integers, one for Home and one for Away. Would anyone happen to pinpoint how I can add my secondary integer (Away) within or at least as a member of this if statement?
 if (currentHomeState != previousHomeState) {
    previousHomeState = currentHomeState;
    if (currentHomeState == On) {
      if ( (msec - msecLst) > Interval)  {
        msecLst = msec;
        numberOfGoals++;
The complete program below:
  Program for the 1960s Panco Mini-Match tabletop soccer game.
#include <SSD1320_OLED.h>
// Initialize the display with the following pin connections.
SSD1320 flexibleOLED(10, 9); //10 = CS, 9 = RES
// Define constants for home and away team.
const int Home = A1;
const int Away = A2;
// Define constants for LED pins.
const int LED_1 = 7;    // Pin 7 connected to a LED, turns HIGH when away team score.
const int LED_2 = 8;  // Pin 8 connected to a LED, turns HIGH when home team score.
enum { Off = HIGH, On = LOW };
#define Interval  1000
// Initalize and define states for the goal sensors.
int currentHomeState = 0, previousHomeState = 0;
int currentAwayState = 0, previousAwayState = 0;
int numberOfGoals = 0;
unsigned long msecLst = 0;
  //Run once
  //Initilize the display
  flexibleOLED.begin(160, 32);  //Display is 160 wide, 32 high
  flexibleOLED.clearDisplay();  //Clear display and buffer
  //Display Home score
  flexibleOLED.setContrast(255);
  flexibleOLED.setFontType(2); //7-segment display style characters, 10x16-pixels each.
  flexibleOLED.setCursor(45, 7);
  flexibleOLED.print(numberOfGoals);
  //Display Away score
  flexibleOLED.setCursor(95, 7);
  flexibleOLED.display();
  pinMode(Home, INPUT_PULLUP);
  pinMode(LED_1, OUTPUT);
  unsigned long msec = millis ();
  //Run repeatedly
  currentHomeState = digitalRead(Home);
  currentAwayState = digitalRead(Away);
        msecLst = msec;
        numberOfGoals++;
        Serial.println (numberOfGoals);
        flexibleOLED.setCursor(45, 6);
        digitalWrite(LED_1, HIGH);
        delay(250);
        digitalWrite(LED_1, LOW);
      if (numberOfGoals == 5) {
        delay(250);
        delay(250);
        delay(250);
        delay(250);
        delay(250);
        delay(250);
        delay(250);
        delay(250);
        numberOfGoals = 0;
        delay(250);
      if (numberOfGoals == 0) {
        flexibleOLED.clearDisplay(); // Clear display and buffer
        Serial.println (0);
Now, I might be totally wrong after all, that would be good to know as well, but any help or guidance would be highly appreciated :slightly_smiling_face:
seems like you need a sub-function that can process home or away given some state (use arrays)
@gcjr thanks a lot. I will read more about sub-functions and Arrays to see if this can solve the matter :slightly_smiling_face:
