Hi, I have a temperature controlled relay, I would like to add some security so I wont fry the heater that is connected to the relay by turning it on or off too often.
For example if the relay is set to turn on if the temp is less than 20C I actually want to wait until it has dropped to 19.5 (0.5C buffer temp) before it actually turn on. I think my below pseudo code will work (not tested), but it seem clumsy using nested if statements, I would learn to write better code. Can it be made neater/smarter, often I feel i make it harder than it need to be. Any suggestions or comments?
Some pseudo code
// Check temp every 15 second
void checkTemp()
If (temp < 20C turn on relay)
Actually only turn relay on when temp has dropped to 19.5C
if(temp < 19.5)
relayOn();
// Do nothing - wait until temp is 19.5 - relayOff()
else {
relayOff();
A difference between turn on temperature and turn off is called hysteresis.
if( temp < 19.5) // set turn on
relayOn();
else if( temp > 21.5) // set turn off
relayOff();
As groundFungus notes, hysteresis is important to prevent "chattering" at a single switchpoint in systems like this.
You can also add temperature sensor checks, a maximum run time and cool-off time etc...
#define SET_POINT (float)20.0
#define LOW_HYST (float)-0.50
#define HIGH_HYST (float)+0.75
#define HTR_OFF 0
#define HTR_ON 1
#define MAX_HEATER_ON 600000L //10-min cont. run time max
#define HTR_PAUSE_TIME 600000L //10-min rest after max-out
//if the sensor is shorted or open, what does it read?
#define ERROR_LOW (float)-40.0
#define ERROR_HIGH (float)+80.0
relayOff();
checkTemp();
void checkTemp()
unsigned long
timeNow;
static unsigned long
timerHeater;
static byte
stateHeater = HTR_OFF;
//read the temperature and filter it
fTemp = getTemp();
filtTemp = filterTemp( fTemp ); //could be a lag filter (e.g.)
//check for sensor errors
if( (filtTemp <= ERROR_LOW) || (filtTemp >= ERROR_HIGH) )
//temp sensor may be faulty
//force heater off and let user know somehow
lightErrorLED();
relayOff();
return;
switch( stateHeater )
case HTR_OFF:
if( filtTemp <= (SET_POINT - LOW_HYST ) )
//lower target temp; turn heater on
relayOn();
timerHeater = millis();
stateHeater = HTR_ON:
}//if
case HTR_ON:
if( (millis()-timerHeaterOn) > MAX_HEATER_ON )
//heater has been running too long...let it cool
relayOff();
stateHeater = HTR_PAUSE;
}//if
else if( filtTemp >= (SET_POINT + HIGH_HYST ) )
//upper target temp reached; turn it off
relayOff();
}//if
case HTR_PAUSE:
//if heater was on too long, give it a chance to
//cool before allowing it to run again
if( (millis() - timerHeater) < HTR_PAUSE_TIME )
return;
//after pause, return to the normal state machine
}//switch
}//checkTemp
Thanks guys that was really helpful! Hysteresis, think its my new work of the day!
