Add Serial.print to get information
Hello dear friends.
I created a code to make a small relay work 10 times and then turn off.
I need to insert a simple magnetic sensor to check if the relay really worked 10 times!
I have no idea how to put the code to read sensor data (hi and low) end read in Serial Monitor!
Any ideas? Below is the code:
int relay = 6;
const int button = 5;
int buttonState = 1;
void setup(){
pinMode(button, OUTPUT);
pinMode(relay, OUTPUT);
digitalWrite(relayPin, HIGH);
void loop(){
buttonState = digitalRead(button);
if (buttonState == HIGH)
for (int counter=1; counter<11; counter = counter+1){
digitalWrite(relay, LOW);
delay(2000);
digitalWrite(relay, HIGH);
delay(2000);
Any ideas will be appreciated!
Best regards.
digitalRead()
Serial.print()
I don't believe "relayPin" is a valid variable
seems to me you could wire a second relay in series with the relay. the second relay would power an led. just count how many times the led comes on. Or you could wire a relay in parallel with the load on your relay. That relay would send a signal into the controller and you could write code to count how many times the controller receives the signal.
"I need to insert a simple magnetic sensor to check if the relay really worked 10 times!"
What sensor?
Maybe use an opto isolator.
If you just simply want to see if the relay worked 10 times, put 5V to the C pin, and a led with a 220ohm resistor on the NO pin and connect to ground. With a 2sec delay, it shouldn't be difficult to watch it for 20 seconds.
What type of arduino is this?
Delta_G:
Sorry, my msg was deleted before your reply.
Arduino Uno, error:
’serial’ was not declared inthis scope
Below is the code:
#include <SoftwareSerial.h>
int ledPin = 7;
int relayPin = 8;
const int button = 6;
int analogValue;
void setup(){
  pinMode(ledPin, OUTPUT);
  pinMode(button, INPUT);
  pinMode(relayPin,OUTPUT);
  digitalWrite(ledPin,HIGH);
  digitalWrite(relayPin,HIGH);
  serial.begin(9600);
void loop(){
analogValue = analogRead(7);
  for (int counter=1; counter<10; counter = counter+1){
    delay(1500);
    digitalWrite(ledPin, LOW);
    digitalWrite(relayPin, LOW);
    delay(1500);
    digitalWrite(ledPin, HIGH);
    serial.print(analogValue);
Where did I went wrong?
Thanks.
serial.begin(9600);
'serial' was not declared inthis scope
C++ is case sensitive. Try Serial instead.
An UNO doesn't have an analog input 7. What are you trying to do here?
serial.begin(9600);
oops
Worked like a charm!
One last request, how can I implement a LED to tell me if the counter reached "x" cycles?
Relay must turn on & off 10 times. At the end of 10th. cycle, I need to check by looking and an extra LED.
Thank you.
You don't need any indicator. The for loop will only iterate 9 times the way you have it written so the relays will only pulse 9 times. If you change the initial value of the counter in that for loop to 0 then it will pulse 10 times. You could just put a line right after the for loop to light up the led since at that point in the code you will know that it has fired the relay 10 times.
