Add string to array
Hi
I want to add the following string
version = "v1.00";
to
char msg [] = "Arduino" + version;
How should I write the expression
Hello and welcome :slight_smile:
There are few functions that you can use,
For adding at the end of a char array (what you want to do), use strcat
For advanced formatting, use sprintf
I want to
'char msg [] " shall include the value
Arduino v1.00
Well I gave you 2 ways to make it, now click on the links and study :stuck_out_tongue:
I can not get it to work
Can you give me an example?
Please
What have you tried?
What type is version?
The msg array does not have room for more characters.
If it did, as in:
char msg[80] = "Hello, ";
and the part you wanted to append to it was properly defined, as in:
char add[] = "world!";
then
strcat(msg, add);
would do the trick. After that call, msg contains "Hello, world!".
I have the line:
char msg [] = "The temperature is";
and want to add a string variable
float temperature = getTemp ();
the result I will have
char msg [] = "Temperature is: 24.5";
Use dtostrf to convert the float into a char array.
char msg[24] = "Temperature is: ";
char temperatureStr[7];
dtostrf( temperature, 0, 1, temperatureStr );
strcat( msg, temperatureStr );
or
char msg[24];
dtostrf( temperature, 0, 1, msg );
sprintf( msg, "Temperature is: %s", msg );
There is another solution:
char msg[24];
sprintf( msg, "Temperature is: %.1f", temperature );
But this requires that you do some modifications: install this in \hardware\tools\avr\avr\lib (make a backup of that lib folder, and then extract and replace files).
Hi
Sorry I have not heard of me
It works well
