Add timestamp during compile
Hi there,
Is it possible to put some kind of macro in an include file to add a timestamp in the code during compilation.
Tnx in avance,
grtz Jan
The compiler does that afaik... I can't remember the variable names right now.
edit: DATE TIME
For instance:
  Serial.begin (115200) ;
  Serial.print (__DATE__) ;
  Serial.print (" ") ;
  Serial.println (__TIME__) ;
You'd be better off with
  Serial.print (F(__DATE__)) ;
  Serial.println (F(__TIME__)) ;
Thanks for the quick response, I will try this this evening.!
Grtz Jan
One that I use, also tells what IDE and Arduino you're using.
  Serial.print(__FILE__ " " __DATE__ " " __TIME__);
  Serial.print("  IDE "); Serial.println(ARDUINO);
