I am creating an automated greenhouse system using an SD Shield to log the data from the sensors. I have everything hooked up and functioning, but continue to get false readings from the Adafruit's Stemma soil & moisture sensor due to electrical interference from our additional power supplies.
To resolve this issue, we have implemented an array that will be analyzed to only display the greatest value recorded every few loops.
void dataAcquisition(){
int i;
int n;
airTempVal=dht.readTemperature()*9.0/5.0+32.0; //converted from degrees C to F
humidityVal=dht.readHumidity();
lightVal=analogRead(lightSensorPin);
soilTempVal=ss.getTemp()*9.0/5.0+32.0; //converted from degrees C to F
for(i=0;i<3;i++){
moistArray[i]=ss.touchRead(0);
moistVal=moistArray[0];
n=i; //i is currently the number of elements in the array
for(i=1;i<n+1;i++){
if(moistArray[i]>moistVal){
moistVal=moistArray[i];
Unfortunately, now the SD Shield is not initializing. I have tested some different delays (2ms, 2s, 6s, and 60s) but it does nothing to resolve the issue except add to the time that the serial monitor will display the shield has not initialized.
Below is the complete code for reference.
//Libraries
#include <DHT.h> //DHT sensor
#include <SPI.h> //SD card
#include <SD.h> //SD card
#include <Adafruit_seesaw.h> //moisture sensor
//input pin intializiation
const int dhtPin=2; //temperature and humidity sensor pin
const int lightSensorPin=0;
//output pin intializiation
const int valvePin=3;
const int fanPin=4;
//sd card intializiation
File sensorDataFile;
//actuation tracking
bool actuatedValve=0; //will track if the plants have been watered recently
bool actuatedFan=0; //will track if the plants used a fan recently
//value initializations
float airTempVal=0;
float humidityVal=0;
int lightVal=0;
float soilTempVal=0;
uint16_t moistVal=0;
int minutes=60*1000; //minutes converted to ms
int hours=60*60*1000; //hourss converted to ms
uint16_t moistArray[]={0,0,0};
//sensor initializations
#define DHTPIN 2 //what pin the DHT sensor is connected to
#define DHTTYPE DHT22
DHT dht(DHTPIN,DHTTYPE);
Adafruit_seesaw ss;
pinMode(dhtPin,INPUT);
pinMode(lightSensorPin,INPUT);
pinMode(valvePin,OUTPUT);
pinMode(fanPin,OUTPUT);
dht.begin();
while (!ss.begin(0x36)) {
Serial.println("Moisture sensor initialization failed."); //wait for moisture sensor to connect
while (!Serial) {
Serial.println("Serial port initialization failed."); ; //wait for serial port to connect
if (!SD.begin(10)) { //wait for SD shield to connect
Serial.println("SD card initialization failed.");
while (1); //while(1) is an infinite loop, it ends when SD intialization succeeds
sensorDataFile=SD.open("data.txt", FILE_WRITE);
sensorDataFile.println("Air Temp Sensor, Humidity Sesnor, Light Sensor, Soil Temp Sensor, Soil Moisture");
sensorDataFile.close();
dataAcquisition();
dataLogging();
//valveTest(); //debugging or testing the valve and relay module
valveActuation();
//fanTest(); //debugging or testing the fan and relay module
fanActuation();
serialPrintData(); //debugging
//waterDelay();
delay(15*minutes); //15 minute delay
//delay(6000);
int i;
int n;
for(i=0;i<3;i++){
for(i=1;i<n+1;i++){
void dataLogging() {
sensorDataFile=SD.open("data.txt",FILE_WRITE);
if(sensorDataFile){
sensorDataFile.print(" ");
sensorDataFile.print(airTempVal);
sensorDataFile.print(" , ");
sensorDataFile.print(humidityVal);
sensorDataFile.print(lightVal);
sensorDataFile.print(soilTempVal);
sensorDataFile.println(moistVal);
}else{
Serial.println("error opening data.txt"); //debugging
void valveActuation() {
if(moistVal<825){
digitalWrite(valvePin, LOW); // The relay is active low, so it turns on when we set the pin to LOW which opens the valve
delay(2000); //how long should we water the plant or garden?
digitalWrite(valvePin, HIGH);
actuatedValve=1;
}else {
actuatedValve=0;
void fanActuation(){
if(humidityVal>85){ //FIX ME (what should the humidity threshold be)
digitalWrite(fanPin,LOW); //The relay is active low, so the fan turns on when we set the pin to LOW
actuatedFan=1;
}else{
digitalWrite(fanPin,HIGH);
actuatedFan=0;
void waterDelay() {
if(actuatedValve==0){ //not watered recently
if(airTempVal>85){ //not watered recently & hot
if(lightVal>600){ //not watered recently & hot & bright
delay(1*hours);
Serial.println(5000); //debugging
}else{ //not watered recently & hot & not bright
delay(2*hours);
Serial.println(6000); //debugging
}else{ //not watered recently & not hot
if(lightVal>600){ //not watered recently & not hot & bright
delay(3*hours);
Serial.println(7000); //debugging
}else{ //not watered recently & not hot & not bright
delay(4*hours);
Serial.println(8000); //debugging
}else { //was watered recently
if(airTempVal>85){ //was watered recently & hot
if(lightVal>600){ //was watered recently & hot & bright
delay(5*hours);
Serial.println(1000); //debugging
}else{ //was watered recently & hot & not bright
delay(6*hours);
Serial.println(2000); //debugging
}else{ //was watered recently & not hot
if(lightVal>600){ //was watered recently & not hot & bright
delay(7*hours);
Serial.println(3000); //debugging
}else{ //was watered recently & not hot & not bright
delay(8*hours);
Serial.println(4000); //debugging
void valveTest(){
digitalWrite(valvePin,LOW); //The relay is active low, so the valve opens when we set the pin to LOW
delay(2000);
digitalWrite(valvePin,HIGH);
delay(6000);
void fanTest(){
delay(6000);
delay(6000);
void serialPrintData(){
Serial.print(airTempVal);
Serial.print(" ");
Serial.print(humidityVal);
Serial.print(" ");
Serial.print(lightVal);
Serial.print(" ");
Serial.print(soilTempVal);
Serial.print(" ");
Serial.print(moistVal);
Serial.print(" ");
Serial.println(actuatedValve);
Serial.print(" ");
Serial.println(actuatedFan);
LIGHT SENSOR INFO: Reading of...
less than 10 is dark
10 to 200 is dim
200 to 500 is light
500 to 800 is bright
greater than 800 is very bright
MOISTURE SENSOR INFO: Reading of...
air is around 350
dry soil is around 768
slightly wet soil is around 1016
moist soil is around 1017
very moist soil is around 1017
soaked soil is around 1017
(these soil readings were constant for loose and compact soil)
DHT SENSOR INFO: Temperature conversion formulas...
F=(C)*(9/5)+32
C=(F-32)*(5/9)
THANKS FOR ANY HELP!
