Adding 1602 display to Gsm SHield+Arduino Uno rev3
Hi to all,
currently i have arduino uno with gsm shield working perfectly. I integrated a button (using pin 6 for buttonpin) and when the button is pressed (HIGH) i am making a voice call.
The skech
#include <GSM.h>
#define PINNUMBER ""
// initialize the library instance
GSM gsmAccess; // include a 'true' parameter for debug enabled
GSMVoiceCall vcs;
const int buttonPin = 6;     // the number of the pushbutton pin
const int ledPin =  13;      // the number of the LED pin
int buttonState = 0;         // variable for reading the pushbutton status
  // initialize the LED pin as an output:
  pinMode(ledPin, OUTPUT);
  // initialize the pushbutton pin as an input:
  pinMode(buttonPin, INPUT);
  // initialize serial communications
  //Serial.begin(9600);
 // Serial.println("SMS Messages Sender");
  // connection state
  boolean notConnected = true;
  // Start GSM shield
  // If your SIM has PIN, pass it as a parameter of begin() in quotes
  while(notConnected)
    if(gsmAccess.begin(PINNUMBER)==GSM_READY)
      notConnected = false;
      Serial.println("Not connected");
 // Turn 13 pin led - READY ON
     digitalWrite(ledPin, HIGH);
 // Serial.println("GSM initialized");
   buttonState = digitalRead(buttonPin);
if (buttonState == HIGH) {
    // turn LED on:
  if(vcs.voiceCall("MY_number_stays_here"))
          // Turn Free LED OFF]
          digitalWrite(ledPin, LOW);
          //Serial.println("Call Established. Enter line to end");
          // Wait for some input from the line
          while(vcs.getvoiceCallStatus()==TALKING);
          // And hang up
          vcs.hangCall();
        // TURN FREE LED ON AGAIN after call finished
       // Serial.println("Call Finished");
My question is can i use LCD display and connect (wire) the pins as shown Here , but to connect directly on top of the GSM shield not at the arduino as shown in the picture.
As i see now i am using pins 3,6,5V and GND and in this picture - to connect LCD we have noting to do with pins 3 and 6 , so can i be sure that there will not be a problem??..short circuit , using same pin…or something like that?
Thanks
You cannot use pin 3. Pin 3 is used by GSM shield to receive information from Arduino board.
Thanks for the answer . then if i use another pin instead of pin 3 for the 1602 LCD screen, will everything work correctly?
LCD 1602 is using pins 2,3,4,5,11,12 , but if i change pin3 to with one of the pins (7,8,9,10) will this work? At the moment i think pins 7,8,9,10 are free i am not using them but not sure if GSM shield is not...?
Any other help? Is it only this - not to use pin 3 by the 1602 LCD screen? Nothing else to take care of? What about pins 2 and 7 ? as i see the also play role with the gsm shield?
pin 2 & 3 used by modem rx/tx pin 7 used for power modem you can use all other pins. I used the Analog A0-A5 pins to connect 1602 on modem shield. Works fine.
Did you add micro and Loudspeaker? How ???
