Adding a 5 second time delay to a standard on off push button sketch
Good day
i am fairly new to this programming and is now moving in to this direction.
i have found a standard sketch for switching a light on with a single push button.
and would like to know if if it is possible to add a second output tu a relay that only last 5 seconds then switch that particular relay off but the light stil stay on?
this is the sketch i am currently using for the pushbutton relay and would like to add another relay that only stay on for 5 seconds
  • switch
  • Each time the input pin goes from LOW to HIGH (e.g. because of a push-button
  • press), the output pin is toggled from LOW to HIGH or HIGH to LOW. There's
  • a minimum delay between toggles to debounce the circuit (i.e. to ignore
  • noise).
int inPin = 2; // the number of the input pin
int outPin = 13; // the number of the output pin
int state = HIGH; // the current state of the output pin
int reading; // the current reading from the input pin
int previous = LOW; // the previous reading from the input pin
// the follow variables are long's because the time, measured in miliseconds,
// will quickly become a bigger number than can be stored in an int.
long time = 0; // the last time the output pin was toggled
long debounce = 200; // the debounce time, increase if the output flickers
pinMode(inPin, INPUT);
pinMode(outPin, OUTPUT);
reading = digitalRead(inPin);
// if the input just went from LOW and HIGH and we've waited long enough
// to ignore any noise on the circuit, toggle the output pin and remember
// the time
if (reading == HIGH && previous == LOW && millis() - time > debounce) {
if (state == HIGH)
state = LOW;
state = HIGH;
time = millis();
digitalWrite(outPin, state);
previous = reading;
Look at this example to get ideas:
//Blink without Delay skeleton
//4 examples demonstrated
//LED wiring options
//Depending which way your LEDs are wired, uncomment the next line.
//#define PlusEqualsON
#ifdef PlusEqualsON
//wired so +5V turns LED ON
#define ledON  HIGH
#define ledOFF LOW
#else
//wired so +5V turns LED OFF
#define ledON  LOW
#define ledOFF HIGH
#endif
//switch wiring options
//Depending which way your switches are wired, uncomment the next line.
#define PushEqualsLOW
#ifdef PushEqualsLOW
//pushing the switch makes pin LOW
#define Pushed   LOW
#define Released HIGH
#else
//pushing the switch makes pin HIGH
#define Pushed   HIGH
#define Released LOW
#endif
unsigned long currentMillis;
unsigned long pin13Millis;
unsigned long pin12Millis;
unsigned long pin11Millis;
unsigned long SwitchMillis;
//if these are not changed in the sketch, they can be const
unsigned long debounceMillis = 100UL;     //100ms
unsigned long ledOnTime      = 5*1000UL;  //5 seconds
byte laststartSwitchState    = HIGH;
byte buttonState             = HIGH;
byte counter                 = 0;
//the following are enable/disable flags
//some of these might not be used in this sketch
boolean flag13 = true;
boolean flag12 = true;
boolean flag11 = true;
boolean flag10 = true;
const byte startSwitch = 2; //pushed = LOW
const byte testSwitch  = 3; //pushed = LOW
  digitalWrite(13,ledOFF);
  pinMode(13, OUTPUT);
  digitalWrite(12,ledOFF);
  pinMode(12, OUTPUT);
  digitalWrite(11,ledOFF);
  pinMode(11, OUTPUT);
  digitalWrite(10,ledOFF);
  pinMode(10, OUTPUT);
  pinMode(startSwitch, INPUT_PULLUP); //pushed = LOW
  pinMode(testSwitch,  INPUT_PULLUP); //pushed = LOW
} //  >>>>>>>>>>>>>> E N D  O F  s e t u p ( ) <<<<<<<<<<<<<<<<<
  //save the current time
  currentMillis = millis();
  //************************************* E x a m p l e  1
  //toggle pin 13 every 200mS
  //has 200ms or more gone by?
  if (currentMillis - pin13Millis >= 200UL)
    //code here runs every 200ms
    //get ready for next iteration
    pin13Millis = pin13Millis + 200UL;
    //toggle pin 13
    digitalWrite(13,!digitalRead(13));
  //************************************* E x a m p l e  2
  //at power up, pin 12 LED goes ON, after 3 seconds goes OFF and stays OFF
  //could be used as a powerup reset signal
  if (flag12 == true && currentMillis - pin12Millis <= 3000UL)
    //code here runs for 3 seconds after power up, then stops
    digitalWrite(12,ledON);
    //disable further pin 12 control
    flag12 = false;
  //************************************* E x a m p l e  3
  //if testSwitch is pushed and released
  //pin 11 LED goes ON for 5 seconds, then goes OFF
  buttonState = digitalRead(testSwitch);
  //are we are allowed to check the switch and is it pressed?
  if(flag11 == true && buttonState == Pushed)
    //enable timing of LED on pin 11
    flag11 = false; //false --> timing is enabled
    //turn LED ON
    digitalWrite(11,ledON);
    //record the time LED turned ON
    pin11Millis = currentMillis;
  //are we allowed and is it time to control pin 11
  if (flag11 == false && currentMillis - pin11Millis >= ledOnTime)
    //if enabled, code here runs after ledOnTime ms goes by
    //allow switch press detection again
    flag11 = true; //true --> switch monitoring is enabled
  //************************************* E x a m p l e  4
  //is it time to check the switches?
  //in particular, pushing startSwitch will turn ON/OFF (toggle) an output pin 10
  if (currentMillis - SwitchMillis >= debounceMillis)
    //code here runs every debounceMillis ms
    //get ready for the next iteration
    SwitchMillis += debounceMillis;
    //go and check the switches
    checkSwitches();
  //put other non-blocking stuff here
} //  >>>>>>>>>>>>>> E N D  O F  l o o p ( ) <<<<<<<<<<<<<<<<<
//                      F U N C T I O N S
//****************** c h e c k S w i t c h e s ( ) *********************
//switches are checked every debounceValue milli seconds
//no minimum switch press time is validated with this code (i.e. No glitch filter)
void checkSwitches()
  //re-usable for all the switches
  boolean thisState;
  //************************************* E x a m p l e  Push ON push OFF (toggle)
  //check if this switch has changed state
  thisState = digitalRead(startSwitch);
  if (thisState != laststartSwitchState)
    //update the switch state
    laststartSwitchState = thisState;
    //this switch position has changed so do some stuff
    //"HIGH condition code"
    //switch went from LOW to HIGH
    if(thisState == HIGH)
      //Do some HIGH switch stuff here
    //"LOW condition code"
    //switch went from HIGH to LOW
      //Do some LOW switch stuff here
      digitalWrite(10, !digitalRead(10));
      //print number of pushes
      counter++;
      Serial.println(counter);
  } //END of startSwitch code
  //similar code for other switches goes here
} //END of checkSwitches()
//                      E N D  O F  C O D E
The beginner's guide to millis() shows how to do non-blocking timing. Record, in a variable!, the time that the button was pushed and actuate the relay. Every time through loop() check the current millis() versus the recorded mllis() and when the difference is greater than or equal to 5000 turn the relay off.
