Adding a button switch to do 3 functions
Noob just starting out. I'm trying to add a button switch to do 3 functions on my project, power off, press once and first half of a group of leds turns on, press again and all leds are on, 3rd press all leds are off. Here's the syntax:
const int buttonPin = 2;
int mode = 0;
int previousButtonstate = 0;
unsigned long previousTime = 0;
unsigned long currentTime = 0;
unsigned long elapsedTime = 0;
int led1 = 9;
int led2 = 10;
int led3 = 11;
int brightness1 = 0;
int brightness2 = 0;
int brightness3 = 255;
int currentState = 0;
int stateSwapMillis = 200;
int loopDelay = 5;
int fadeAmount = 255 / (stateSwapMillis / loopDelay);
pinMode(buttonPin, INPUT);
pinMode(led1, OUTPUT);
pinMode(led2, OUTPUT);
pinMode(led3, OUTPUT);
currentTime = millis();
buttonState = digitalread(buttonPin);
if 9buttonState == HIGH && previousButtonSte == LOW) {
mode == (mode = 1) % 3;
if ( mode == 0 ) {
// mod state is off
} else if ( mode == 1 ) {
// turn on main exterior and interior lights
else if ( mode == 2 ) {
// turn on emergency lights
analogWrite(led1, brightness1);
analogWrite(led2, brightness2);
analogWrite(led3, brightness3);
previosButtonState = buttonState;
elapsedTime += (currentTime - previousTime);
if ( elapsedTime >= stateSwapMillis ) {
currentState = (currentState + 1) % 3;
elapsedTime = 0;
adjustBrightnesses();
delay(loopDelay);
previousTime = currentTime;
void adjustBrightnesses() {
if ( currentState == 0 ) {
brightness1 += fadeAmount;
brightness2 = 0;
brightness3 -= fadeAmount;
} else if ( currentState == 1 ) {
brightness1 -= fadeAmount;
brightness2 += fadeAmount;
brightness3 = 0;
} else if ( currentState == 2 ) {
brightness1 = 0;
brightness2 -= fadeAmount;
brightness3 += fadeAmount;
Welcome to the forum.
http://forum.arduino.cc/index.php/topic,148850.0.html .
Then look down to item #7 about how to post your code.
It will be formatted in a scrolling window that makes it easier to read.
Please not a Fritzy picture.
How have you got your button wired?
If between the input pin and 5V, have you got a 10k pulldown resistor between the input and gnd?
If between the input pin and gnd, have you got a 10k pullup resistor between the input and 5V?
Thanks… Tom…
Correcting obvious syntax error should be your first step...if 9buttonState == HIGH && previousButtonSte == LOW) {...that nine is probably a ( right...
Are your == and = mixed up here?
J-M-L:
And previousButtonSte is probably previousButtonState ?
When you're having compile errors it's a good idea to post complete error listing. That way we're less likely to miss something.
Steve
If you just want your LEDs ON/OFF, you have a lot of extra code in there...
Also, based on your code, you will need an external pull-down resistor on that button
int mode = 0;
int previousButtonState = 0;
const int led1 = 9;
const int led2 = 10;
const int led3 = 11;
  int buttonState = digitalRead(buttonPin);
  if (buttonState == HIGH && previousButtonState == LOW) {
    previousButtonState = buttonState;
    mode = (mode + 1) % 3;
    if ( mode == 0 ) {
      // off
      digitalWrite(led1, LOW);
      digitalWrite(led2, LOW);
      digitalWrite(led3, LOW);
      // half on
      digitalWrite(led1, HIGH);
      // all on
      digitalWrite(led2, HIGH);
      digitalWrite(led3, HIGH);
