Adding a delay to this code.
I’m using The 28-BYJ48 Even comes with Breakout using ULN2003 As a Motor driver chip.
Specification for this Motor " And you can download datasheet from the attachment "
Rated voltage ? 5VDC
Number of Phase 4
Speed Variation Ratio 1/64
Stride Angle 5.625° /64
Frequency 100Hz
DC resistance 50?±7%(25?)
Idle In-traction Frequency > 600Hz
Idle Out-traction Frequency > 1000Hz
In-traction Torque >34.3mN.m(120Hz)
Self-positioning Torque >34.3mN.m
Friction torque 600-1200 gf.cm
Pull in torque 300 gf.cm
Insulation grade A
I’m using it with the Uno.
I simply want the motor to follow the position of the potentiometer.
In the code that I’ve copied from this forum - turns the motor in the direct of the knob but the motor doesn’t stop when I stop turning the knob.
Here’s a link to what I’m using.
[http://www.instructables.com/id/BYJ48-Stepper-Motor/l
Here’s the code:
int Pin0 = 8;
int Pin1 = 9;
int Pin2 = 10;
int Pin3 = 11;
int _step = 0;
boolean dir = true;
int motorSpeed = 0;     //variable which I have tried to vary
int potPin = 2; 	//pot connected to A2
int potValue = 0;
const int X = 10, Ydeadzone = 3; // slack for pot values
 pinMode(Pin0, OUTPUT);
 pinMode(Pin1, OUTPUT);
 pinMode(Pin2, OUTPUT);
 pinMode(Pin3, OUTPUT);
void loop(){
  potValue = analogRead(potPin);
  Serial.println(potValue);
  if (potValue < 442 +- X){              //~center for my pot
    motorSpeed = (potValue/15 + 5);  //pot mapped to motor but dont seem to get any different speeds by changing these
    clockwise();
  else {
    motorSpeed = ((906-potValue)/15 + 5);
    counterclockwise();
void clockwise()
switch(_step){
   case 0:
     digitalWrite(Pin0, LOW);
     digitalWrite(Pin1, LOW);
     digitalWrite(Pin2, LOW);
     digitalWrite(Pin3, HIGH);
   case 1:
     digitalWrite(Pin2, HIGH);
   case 2:
     digitalWrite(Pin3, LOW);
   case 3:
     digitalWrite(Pin1, HIGH);
   case 4:
   case 5:
     digitalWrite(Pin0, HIGH);
     case 6:
   case 7:
   default:
 if(dir){
   _step++;
 }else{
   _step--;
 if(_step>7){
   _step=0;
 if(_step<0){
   _step=7;
 delay(1);
void counterclockwise ()
 switch(_step){
 case 0:
case 1:
case 2:
case 3:
case 4:
case 5:
case 6:
case 7:
default:
 if(dir){
   _step++;
 }else{
   _step--;
 if(_step>7){
   _step=0;
 if(_step<0){
   _step=7;
 delay(1);
[Antonio_lopez949@yahoo.com]
Thanks…Antonio
Inventing syntax hasn’t worked for anyone else. What makes you think you are special?
Why should it? You are using the value from the potentiometer to set the speed of the motor, not the position.
I don't see anywhere that the motorSpeed is being used?
And use the AccelStepper library and save yourself all that step code.
...R
