Adding a LCD display to project , not enough pins on arduino (see Frtitzing pic)
Hey guys , im wondering how i could go about adding a lcd display to my project. As you can see in the attachment pin2 and pin13 are already in use (Project is a wire loop game, when the red and green wires at the top touch buzzer sounds and add 1 to counter).
My question is how could i go about adding a display ? Relativlely new to to this but i know that lcd requires all the output pins and leaves me with 4 unused input pins.
Can the tX and Rx pins be used for output to the piezo ?
Thanks in advance !!
You seem to have enough pins for an LCD.
You can also use the analogue pins as digital pins.
Leo..
I2C for display?
Wawa:
Leo..
LOL as i said im a beginner. Thanks for clearing that up! So obvious now
Wawa:
Leo..
same number as how many licks it takes to get the center of a tootsie roll tootsie pop.
dave-in-nj:
Oh goodie ! Haven't seen/heard that commercial for a while mr owl :slight_smile:
As for the LCD, you really only need 6 wires (not counting the power/ground/backlight). Check out the Adafruit tutorials - they show how to hook one up. Of course if you use and LCD with i2c that takes even less wires (but increases the cost a bit).
you can get a serial to parallel interface that mounts to the LCD. that interface takes power and 2 pins (A4 and A5) and sends data to the LCD over the I2C bus.
