Adding a millis timer to individual LED's in CASE loop
I am working on a esp32 project where I am trying to light up a series of LED's based on a button press. I got most of it working But I am having trouble getting each of the LED's to turn off after 2 seconds.
Rules are:
  1. If the button is pressed "Switch LED1 ON for 2 seconds"
  2. If the button is Pressed again while LED1 is still on then "Switch LED2 ON for 2 seconds and keep LED1 ON as long as LED2 is on"
  3. If the button is Pressed again while LED-02 is on "Switch LED3 ON for 2 seconds and Keep LED1 and LED2 ON for as long as LED3 is on"
4, Any Button press resets the timer for all 3 LED's
  1. If no new button presses are received within 2 seconds then clear all LED's and wait for new button press
Here is my code so far. All help will be appreciated. Thank you.
const byte buttonPin = 7;  // Button Pin
const byte led1Pin = 2;    // LED1  Pin
const byte led2Pin = 3;    // LED2  Pin
const byte led3Pin = 4;    // LED3  Pin
const byte nodesNum = 2;
unsigned long onPeriod = 2500;
int led1State = LOW;
int led2State = LOW;
int led3State = LOW;
byte hasState = 0;
  // initialize the button pin as a input:
  pinMode(buttonPin, INPUT_PULLUP);
  pinMode(led1Pin, OUTPUT);
  pinMode(led2Pin, OUTPUT);
  pinMode(led3Pin, OUTPUT);
  checkActivation();
void checkActivation() {
  boolean BTState = digitalRead(buttonPin);  // Current Button State
  static boolean prevBTState = HIGH;         // Previous Button State
  static unsigned long timer = 0;
  unsigned long interval = 20;
  if (millis() - timer >= interval) {
    timer = millis();
    BTState = digitalRead(buttonPin);  // Get Button Press
    if (BTState != prevBTState)        // Compare Button State
      if (BTState == LOW)  // If State Change Add to counter ++
        hasState++;  // Check Current state is LOW - State Changed from off to on:
        if (hasState > nodesNum) {
          hasState = 0;
        switch (hasState) {
          case 0:
            digitalWrite(led3Pin, HIGH);
            Serial.println("LED3 On");
          case 1:
            digitalWrite(led1Pin, HIGH);
            Serial.println("LED1 On");
          case 2:
            digitalWrite(led2Pin, HIGH);
            Serial.println("LED2 On");
      prevBTState = BTState;  // Save Button State
what should happen if the button is pressed and LED1 is off but LED2 is still on
  • Bad habits, boolean is true, false :roll_eyes:
So 2 seconds after the LAST button press - everything should reset to OFF
While LED2 is on it should keep LED 1 on.
Same goes for - While LED 3 is on it should keep LED 1 and 2 on.
I am pretty new to coding -
Thank you for the tip.. I will change them to true false
Could the first button pressed also be the last button pressed? Can buttons be pressed 100 times?
  • Use type byte
  • Also, always show us a schematic and good images of actual wiring
Yes, If no new press is received within 2 seconds then it stops and waits.
Okay. Every button sets the timer to 2000ms.
so if LED2 is turned on, don't turn LED1 off after 2 seconds.
also new to specifying requirements. requirements often take the square (!!) of the man-hour/day/week/months to actually do the coding
Correct - Triggering a Button press resets the timer for all LED states.
I will update the requirements to be more concise.
more precise .... "complete, correct and unambiguous"
Read your description, looked at the top of your sketch for the pin #s and typed this out, which seems to match your description (debounce is quick & dirty):
const unsigned buttonPin = 7;
const unsigned led1Pin = 2;
const unsigned led2Pin = 3;
const unsigned led3Pin = 4;
typedef enum {
   ALL_LEDS_OFF,
   LED1_ON,
   LED1_LED2_ON,
   LED1_LED2_LED3_ON
} LedState;
LedState ledState = ALL_LEDS_OFF;
unsigned long ledOnTime = 2000;
unsigned long ledWasTurnedOnTime = 0;
bool buttonPressed() {
   byte currentbuttonState;       // HIGH for inactive, LOW for active
   static byte lastButtonState = HIGH;
   static byte buttonState = HIGH;
   static unsigned long changeDetected = 0;
   const unsigned buttonDebounceDelay = 50;   // 50ms debounce
   bool result = false;
   currentbuttonState = digitalRead(buttonPin);
   if( currentbuttonState != lastButtonState ) {
      changeDetected = millis();
   if( changeDetected && millis() - changeDetected > buttonDebounceDelay ) {
      if( currentbuttonState != buttonState ) {
         buttonState = currentbuttonState;
         // buttonPressed is true when buttonPin is low and debounced
         result = buttonState == LOW;
       changeDetected = 0;
   lastButtonState = currentbuttonState;
   return result;
void setup(void) {
void loop(void) {
   switch( ledState ) {
      case ALL_LEDS_OFF:
         if( buttonPressed() ) {
            ledWasTurnedOnTime = millis();
            ledState = LED1_ON;
      case LED1_ON:
         if( millis() - ledWasTurnedOnTime > ledOnTime ) {
            digitalWrite(led1Pin, LOW);
         } else if( buttonPressed() ) {
            ledState = LED1_LED2_ON;
      case LED1_LED2_ON:
            digitalWrite(led2Pin, LOW);
            ledState = LED1_LED2_LED3_ON;
      case LED1_LED2_LED3_ON:
            digitalWrite(led3Pin, LOW);
Thank you for this. Never even thought of doing it this way.
keep it simple
const byte PinBut     = A1;
      byte butState;
const byte PinLeds [] = { 10, 11, 12 };
      int  Nled       = sizeof(PinLeds);
enum { Off = HIGH, On = LOW };
int  idx;
bool tmr;
const unsigned long MsecPeriod = 2000;
      unsigned long msec0;
void
loop (void)
    unsigned long msec = millis ();
    if (tmr && msec - msec0 >= MsecPeriod)  {
        idx = 0;
        tmr = false;
        for (int n = 0; n < Nled; n++)
            digitalWrite (PinLeds [n], Off);
        Serial.println ("reset");
    byte but = digitalRead (PinBut);
    if (butState != but)  {
        butState  = but;
        delay (20);                     // debounce
        if (LOW == but && idx < Nled)  {
            digitalWrite (PinLeds [idx++], On);
            msec0 = msec;
            tmr   = true;
            Serial.println (idx);
void
setup (void)
    Serial.begin (9600);
    pinMode (PinBut, INPUT_PULLUP);
    butState = digitalRead (PinBut);
    for (int n = 0; n < Nled; n++)  {
        pinMode      (PinLeds [n], OUTPUT);
No problem. Literally just pounded it out. Updated the buttonPressed routine to get rid of the delay; must stop now! :slight_smile:
Thank you for this as well. I am spending some time going through it to understand it better. I need to incorporate this portion into a larger sketch I am working on that uses a lora signal to trigger it.
yes! try to undestand it
  • Another iteration. :nerd_face:
// https://forum.arduino.cc/t/adding-a-millis-timer-to-individual-leds-in-case-loop/1307035
#define LEDon              HIGH   //PIN---[220R]---A[LED]K---GND
#define LEDoff             LOW
#define PRESSED            LOW    //+5V---[Internal 50k]---PIN---[Switch]---GND
#define RELEASED           HIGH
#define CLOSED             LOW    //+5V---[Internal 50k]---PIN---[Switch]---GND
#define OPENED             HIGH
#define ENABLED            true
#define DISABLED           false
const byte buttonPin     = 7;    // Button Pin LOW = pushed
const byte heartbeatLED  = 13;
bool LEDonFlag           = DISABLED;
byte lastButtonPin       = RELEASED;
byte hasState            = 0;
unsigned long heartbeatTime;
unsigned long switchTime;
unsigned long LEDsOFFTime;
//                                           s e t u p ( )
  digitalWrite(led1Pin, LEDoff);
  digitalWrite(led2Pin, LEDoff);
  digitalWrite(led3Pin, LEDoff);
  pinMode(heartbeatLED, OUTPUT);
} //END of   setup()
//                                           l o o p ( )
  //========================================================================  T I M E R  heartbeatLED
  //is it time to toggle the heartbeat LED ?
  if (millis() - heartbeatTime >= 250ul)
    //restart this TIMER
    heartbeatTime = millis();
    //toggle the heartbeat LED
    digitalWrite(heartbeatLED, digitalRead(heartbeatLED) == HIGH ? LOW : HIGH);
  //========================================================================  T I M E R  switches
  //is it time to check our switches ?
  if (millis() - switchTime >= 50ul)
    //restart TIMER
    switchTime = millis();
    checkSwitches();
  //========================================================================  T I M E R  LEDsOFF
  //is it time to turn OFF LEDs ?
  if (LEDonFlag == ENABLED && millis() - LEDsOFFTime >= 2000ul)
    //we are finished with tihis TIMER
    //get ready for the next sequence
    hasState = 0;
} //END of   loop()
//                                   c h e c k S w i t c h e s ( )
void checkSwitches()
  byte pinState;
  //========================================================================  buttonPin
  pinState = digitalRead(buttonPin);
  //has this switch changed state ?
  if (lastButtonPin != pinState)
    //update to this new state
    lastButtonPin = pinState;
    //did this switch go pressed/closed ?
    if (pinState == PRESSED)
      switch (hasState)
        case 0:
          LEDonFlag = ENABLED;
          //restart TIMER
          LEDsOFFTime = millis();
          digitalWrite(led1Pin, LEDon);
        case 1:
          //restart TIMER
        case 2:
          //restart TIMER
      hasState++;
      //we only have 3 machine states  0, 1, 2
        hasState = 0;
  } //END of mySwitch1.pin
  //========================================================================  Next Switch
} //END of   checkSwitches()
