Adding a particular character into array
Hello
I need to add a '#' into each data of array. but i've no idea how to do so as i did many ways to accomplish that first time i read the 48 bytes adc value from 24 analog sensor (2 bytes for each) and store the value in a variable. Then I need to display each of them into textbox in the desktop app i made with VB.
here adc reading code which goes well if i send all of the data without any addition character
while (Serial1.available())
        for (indexReply=0; indexReply<24; indexReply++)
            thisByteReply = Serial1.read();
            value[indexReply] = thisByteReply;
            if (indexReply>=23)
               Serial.write(value, indexReply); //directly send all of 'value' with 24 in length
then i have to send all of the values through serial with character '#' added exactly between each of the 24 data. lets say all of the sensor give full adc 10bit value which is 1023, so the data i want to send will be like this :
1023#1023#1023#1023#1023#10231023#1023#1023#1023....#1023
so that the desktop app i made can parse and display each of them in textbox correctly. I have some trial and nothing of them runs well, such this :
String sign = "#";
String objectSent = sign + value[indexReply=0] + sign + . . .+ value[indexReply=23]; //consider the variable written 24 times
Serial.print(objectSent);
kindly please assist me some help i really appreciate
What does that mean? Arrays have elements.
Which array do you want to store the '#'s in?
Why do you think you need to do this? You are sending binary data. You KNOW that there are 2 bytes per value. You do NOT need separators between the bytes.
i need that separation sign so that my GUI can parse each of them. each of them need to be displayed in certain textbox in GUI while the GUI recognize each of them by "#". what i supposed to do, i did some conversion but the results display random value
all of the value stored in value[indexReply] with indexReply starts from 0-23. this variable that i need to separate with that sign while sending to PC
Is the VB program expecting binary data or ASCII data ?
Why use Strings ?
for (int x = 0; x < NUMBER_OF_ARRAY_ELEMENTS; x++)
  Serial.print(value[x]);
  Serial.print("#");
i've tried that before by using this code :
void storeDisplay()
            thisByteIndexReply[indexReply] = thisByteReply;
        for (int i=0; i<23; i++)
        Serial.print(thisByteIndexReply[i]);
        Serial.print("#");
    indexReply = 0;
and i got this results :
49#255#255#255#255#255#255#255#255#255#255#255#255#255#255#255#255#255#255#255#255#255#255#10#13#49#10#13#49#10#13#49#10#13#49#10#13#49#10#13#49#10#13#49#10#13#49#10#13#49#10#13#49#10#13#49#10#13#49#10#13#49#10#13#49#10#13#49#10#49#10#13#49#10#13#49#10#13#49#10#13#49#10#13#49#10#13#49#10#13#49#10#
here is the declaration of variable on VB that will be parsed :
Delegate Sub Receivedata(ByVal
49#255#255#255#255#255#255#255#255#255#255#255#255#255#255#255#255#255#255#255#255#255#255#10#13#49#10#13#49#10#13 and so on
49 is the ASCII code for '1' 10 is the ASCII code for linefeed 13 is the ASCII code for carriage return
I don't know enough about VB to know what it expects to receive
