Adding a second interrupt
I have a board set up with two sets of traffic light, Green Yellow Red and an additional Green for a turn signal. I plan to use a 3 button function. 1st button interrupts sequence for the North turn arrow (second green light) to come on and blink then resumes sequence. This part works fine with the following code. When I try to add the second button to do the same thing with the East light, I get errors every way I try. The 3rd button will interrupt for both red lights to blink but I am focused on getting the 2nd one working first. Any suggestions?
const int maindelay = 1000;
const byte red = 0;                     //first column in array signal is red
const byte amber = 1;                   //second column in array signal is amber
const byte green = 2;                   //third column in array signal is green
const byte totalcolours = 3;            //there are red, amber and green
const byte north = 0;                   //first row in array signal is north
const byte east = 1;                    // second row in array signal is east
const byte totalsignals = 2;
const int signal[totalsignals][totalcolours] ={
 { 6, 5, 4},
 { 10, 9, 8}
byte signalID = 0;                      // the number of the "active" signal
//turn arrow variables and constants
volatile byte TurnRequest = 0;
const byte Button = 2;
const byte Button2 = 3;
const byte Arrow2 = 11;
const byte Arrow1 = 7;
 //set up serial output
 // set up the signals
 for (byte i = 0; i < totalsignals; i++)         //cycle through the signals
   for (byte j = 0; j < totalcolours; j++)       //cycle through the colours
     pinMode(signal[i][j],OUTPUT);               //set the pins as outputs
     Serial.print("setting pin ");
     Serial.print( signal[i][j]);
     Serial.println(" as output");
 //set the signals to an initial state
   digitalWrite(signal[i][color=red],HIGH);            //light all the red lights
   Serial.print("setting signal ");
   Serial.print( i);
   Serial.println( " to red");
 //set up the turn arrow and signal
 Serial.println("setting up turn lights");
 pinMode(Button,INPUT);                          //set the button as an input
 digitalWrite(Button, HIGH);                     //inturrupt for North
 pinMode(Arrow1,OUTPUT);                         //Set the North turn light as an output
 pinMode(Button2,INPUT);                         //set the button2 as an input
 digitalWrite(Button2, HIGH);                    //inturrupt for East
 pinMode(Arrow2,OUTPUT);                         //Set the East turn light as an output
 attachInterrupt(0, ArrowButton, CHANGE);
 attachInterrupt(0, ArrowButton2, CHANGE);
 if(signalID < totalsignals)
   //make sure a valid signal is the active one.
   settogreen(signalID);                    //turn the signal called signalID to green
   delay(maindelay*2);
   settored(signalID);                      //turn the lights back to red
   delay(maindelay);
   if(TurnRequest ==1)                      //see if the North turn button has been pressed
 Turn1();                                  //if it has, go to the turn arrow function
   signalID++;                             //cycle through the signals
   signalID=0;                             //repeat cycling through all the signals
void settogreen(byte i)
 //function to set a signal to green
 Serial.print("Changing signal ");
 Serial.print(i);
 Serial.println(" to green");
 delay(maindelay);
 digitalWrite(signal[i][color=green],HIGH);
 digitalWrite(signal[i][color=red],LOW);
void settored(byte i)
 //function to set a signal to red
 Serial.print(i);
 Serial.println(" to red");
 digitalWrite(signal[i][amber],HIGH);
 digitalWrite(signal[i][color=green],LOW);
 delay(maindelay);
 digitalWrite(signal[i][amber],LOW);
void ArrowButton()
 //function for when North button is pressed
TurnRequest = 1;// now there is a request to turn
 Serial.println( "Turn request received");
void  Turn1()
 // Turn light function
 Serial.println( "Turn light on");
 delay(maindelay);
 Serial.println( "Turn now");
 digitalWrite(Arrow1, HIGH);
 delay(maindelay*2);
 Serial.println( "Turn time is up, flashing green");
 for (int i=1; i<6; i++)
 //run the next code 5 times to flash the green turn arrow
 digitalWrite(Arrow1,LOW);
 delay(200);//Pause
 digitalWrite(Arrow1,HIGH);
 delay(200);//Pause
 digitalWrite(Arrow1, LOW);
 Serial.println( "No Turn");
 delay(maindelay);
 TurnRequest = 0;                                   // clear turn request
void ArrowButton2()
 //function for when turn button is pressed
 TurnRequest = 1;                                  // active turn request
 Serial.println( "turn request received");
(Mod edit)
One suggestion would be to post the error(s).
Your code is in italics because you did not read and follow the instructions in How to use this forum
Please edit your post and add code tags to it and post the full error messages
Looking at your code as it is I see that your make copious use of the delay() function which may cause problems because it halts operation of the code whilst the delay occurs.
You would be advised to read Using millis() for timing. A beginners guide, Several things at the same time and look at the BlinkWithoutDelay example in the IDE.
UKHeliBob:
And parts of it are in seasonal colors.
I did post as that post said, I do not see the italic. And the colors are not from my post, they are edits from karma. Wich by the way did not work in any way, but thanks.
Are you saying that you used code tags ?
There are none in the page source for your code, so I doubt it
I have no idea what that means
It even shows it in the tags to me and separated from my text so I don't see what is wrong, but never mind, I will figure it out.
@CoryC See the very last line in your post.
You get one freebie and that was it.
Bob.
Only the Button on Pin2 is interrupt 0. It's better to use the digitalPintoInterrupt syntax to avoid confusion.
