I am designing a product for an A-level Design project and I wanted to try use an Arduino to measure the temperature of water and detect if water is present. Im not sure if I have put this is the right category but i'm not sure what it would go in to.
I'd like add 2 buttons into this circuit I am using , one to start/stop the water sensor , and another to start/stop the temperature sensor + LCD. I want to do this to save power on the Arduino as it will be portable and I want to conserve energy from this and I want the water sensor to not be triggered constantly when it's in water. I would like to be able to press the button to stop the function, leave it and then press it again when I need to start it again.
I'd also like to implement an LED that will turn on when water is present like how the buzzer does
Write a do-nothing function that tests your button. If the button is (as you want it) then stay in the do-nothing function, otherwise, leave the do-nothing function. Here is one I wrote:
void simulate()
if (SIMULATOR)
pinMode(A0, INPUT);
while (!analogRead(A0)); // While A0 is HIGH, do not release from this loop
I have tested the code and the temperature sensor works turning it off and on , but the temperature doesn't constantly change when its turned on and only updates when it's been turned off and on again, is there a way to make it update constantly when its turned on as it was doing it with the old code.
The water sensor just doesn't work at all and I have no way of telling if it's on or off. Would it be possible to add an LED that is on when the sensor is off , and make that same LED go on when water is present.
Im Sorry in my last feedback, it seems that i have an error because i did;nt actually compile it in my IDE but can you please try this code now, and tell if it is working or not.
Here is the code.
#include <DallasTemperature.h>
#include <Wire.h>
#define ONE_WIRE_BUS 2
#define WATER_BUTTON_PIN 3 //water button is connected through pin 3
#define TEMPERATURE_BUTTON_PIN 4 //temperature button is connected through pin 4
OneWire oneWire(ONE_WIRE_BUS);
LiquidCrystal_I2C lcd(0x27, 16, 2);
DallasTemperature sensors(&oneWire);
const int waterSens = A0; //define water sensor
int waterVal; // define the water sensor value
int waterButtonState; //defining the water button state
int tempButtonState; //defining the temperature button state
bool waterSensorIsOn = true; //creating a flag if the sensor is off. default value is true.
bool tempSensorIsOn = true;
void setup(void) {
pinMode(11, OUTPUT);
pinMode(waterSens, INPUT);
pinMode(WATER_BUTTON_PIN, INPUT_PULLUP);
pinMode(TEMPERATURE_BUTTON_PIN, INPUT_PULLUP);
sensors.begin();
lcd.begin();
lcd.backlight();
void loop(void) {
sensors.requestTemperatures();
waterButtonState = digitalRead(WATER_BUTTON_PIN); //check whenever the button is pushed or not
tempButtonState = digitalRead(TEMPERATURE_BUTTON_PIN); //check whenever the button is pushed or not
//check if the button is pressed
if (waterButtonState) {
waterSensorIsOn = !waterSensorIsOn; //basically it inverts to true or false
if (tempButtonState) {
tempSensorIsOn = !tempSensorIsOn; //basically it inverts to true or false
//now check if the water sensor is off then...
if (waterSensorIsOn) {
waterVal = analogRead(waterSens); //do the analogRead Function
Serial.println(waterVal);
if (waterVal <= 480) {
noTone(11);
tone(11, 500);
Serial.println("WATER SENSOR SUCCESSFULLY OFF!");
if (tempSensorIsOn) {
lcd.clear();
lcd.setCursor(0, 0);
lcd.print("Temperature:");
lcd.setCursor(0, 1);
lcd.print(sensors.getTempCByIndex(0));
lcd.setCursor(7, 1);
lcd.print("C");
lcd.setCursor(9, 1);
lcd.print((sensors.getTempCByIndex(0) * 9.0) / 5.0 + 32.0);
lcd.setCursor(15, 1);
lcd.print("F");
lcd.clear();
lcd.print("TEMPERATURE SENSOR");
lcd.print("IS OFF");
delay(1000); //you may consider removing this delay function if you want a precise reading of your button
The temperature sensor works perfectly now thank you.
Would it be possible to press the button once for the water sensor and it stop the buzzer going off , and then to press it again when I want it to without having to hold it down?
