Adding a variable to a message sent to Twitter
I'm using the Neocat twitter library.
I wanted to add a variable to the messages I'm sending to Twitter so that Twitter won't reject on the basis that they're not unique.
        Serial.println("connecting to Twitter...");
        if (twitter.post("Button Pressed @")) {
          int status = twitter.wait();
          if (status == 200) {
            Serial.println("Posted!");
          else {
            Serial.print("failed : code ");
            Serial.println(status);
        else {
          Serial.println("connection failed.");
But no matter how many brackets, + signs or quotation marks I use, I can't find the magic combination that'll allow me to do:
Serial.println("connecting to Twitter..."); if (twitter.post("Button 1 pressed @ " RTC.now() )) { int status = twitter.wait(); if (status == 200) { Serial.println("Posted!"); } else { Serial.print("failed : code "); Serial.println(status); } } else { Serial.println("connection failed."); }
Any tips? Thanks!
That's because brackets, + signs, quotation marks or voodoo are not the answer. There is no "glue these two things that are not both strings together as a string" function in C or C++.
There is a sprintf() function that allows you to create a formatted string from strings and non-string variables.
A little time search would have told you this.
PaulS: There is no "glue these two things that are not both strings together as a string" function in C or C++. There is a sprintf() function that allows you to create a formatted string from strings and non-string variables.
hmm..
OK, I've got the following:-
char x = RTC.now();
char button1msg[162];
sprintf(button1msg, "ID%d: tweet message", x);
It almost works, but tells me "error: cannot convert 'DateTime' to 'char' in initialization" on compile. I can't find what type of variable DateTime is anywhere - otherwise I'd know how to declare it. I tried word, unsigned long, char, int, etc - same result.
P.S. I don't know why ID%d inserts x.
It's telling you that RTC.now() returns a DateTime type, which it can't convert to a char.
Are you using RTClib.h? If you are, you might want to use year(), month(), day(), hour(), minute() and second().
The format specifier needs to match the variable type that is to be formatted. %d is the format specifier for int. x is a char. They don't match.
1
int y = now.hour();
int x = now.minute();
sprintf(button1msg, "Button 1 registered @ Hour %d, Minute %d", y, x);
2
DateTime y = RTC.now();
sprintf(button1msg, "Button 1 registered @ %d", y);
1 works but 2 compiles but then hangs the loop.
The variable y is NOT an int.
PaulS: The variable y is NOT an int.
mmm, I got that, but I don't know what type of variable DateTime is? I think it is itself a sprintf from the Ladyada RTClib.h library. So that means I'm should use the below, right?
int v = now.day();
int w = now.month();
int x = now.year();
int y = now.minute();
int z = now.hour();
sprintf(button1msg, "Button 1 registered @ %d/ %d/ %d, %d:%d", v, w, x, y, z);
There is no reason to create a bunch of intermediate variables.
sprintf(button1msg,
   now.day(),
   now.month(),
   now.year(),
   now.hour(),
   now.minute());
This way, it is clear what is going where (you had hour and minute reversed).
DateTime is not a variable. It IS a type. The type of now (the variable) IS DateTime.
DateTime is a class. The variable now holds an instance of that class.
