This project will rotate a model railroad coal dumper when the button is pressed. Dump the coal, then rotate it back to home position.
I would like to add the two additional functions to this project:
I need to include two IR sensors to make sure the rotating part is clear prior to rotating. (can I just parallel the two sensors and just use one pin?)
I need to include an additional servo to actuate during the rotation to lock the car down. then release when the platform is back to home position.
any help is much appreciated.
#include <Servo.h>
Servo myservo; // create servo object to control a servo
#define servoPin 3 //~
#define pushButtonPin 2
int angle =10; // initial angle for servo
int angleStep =2;
const int minAngle = 10;
const int maxAngle = 180;
int buttonPushed =0;
// Servo button demo by Robojax.com
Serial.begin(9600); // setup serial
myservo.attach(servoPin); // attaches the servo on pin 3 to the servo object
pinMode(pushButtonPin,INPUT_PULLUP);
Serial.println("Robojax Servo Button ");
if(digitalRead(pushButtonPin) == LOW){
buttonPushed = 1;
if( buttonPushed ){
// change the angle for next time through the loop:
angle = angle + angleStep;
// reverse the direction of the moving at the ends of the angle:
if (angle <= minAngle || angle >= maxAngle) {
angleStep = -angleStep;
buttonPushed = 0;
myservo.write(angle); // move the servo to desired angle
Serial.print("Moved to: ");
Serial.print(angle); // print the angle
Serial.println(" degree");
delay(100); // waits for the servo to get there
yes, two sensors can be wired so that they both must be active or non-active and it sounds like they indicate a condition that needs to be true to operate the dumper
sounds like you need a sequencer
wait for start button and verify IR sensor condition
move locking arm
rotate car to dump
wait a moment (delay())
rotate car to upright position
release locking arm
i suggest a sub-function with servo, state and target position arguments to move the servos to the target positions during various stages of the sequence
the 30 in { 3, 10, 20, 30, "arm" }, is the stepDelay. it and the other values: pin, pos0, pos1 can be changed in that initialization line. same for the "rotate" serv
Can you help with these two LED functions? I was attempting to add 2 LEDs to the code. When the IR sensor is obstructed, send Pin 11 (RED) to low, otherwise send pin 10 (Green) to low. I am wanting to get one of those push buttons that has the LED lights in it so the operator can see the status on the button.
# define PinButton A1
# define PinSensor A2
#include <Servo.h>
struct ServoSt {
int pin;
int pos0;
int pos1;
long stepDelay;
const char * desc;
int pos;
Servo servo;
} servos [] = {
{ 3, 10, 180, 5, "arm" },
{ 4, 10, 180, 25, "rotate" },
#define N_SERVO (sizeof(servos)/sizeof(ServoSt))
enum { S_ARM, S_ROT };
enum { Pos_0, Pos_1 };
void
posServo (
int servoId,
int posId )
ServoSt *s = & servos [servoId];
int pos = s->pos0;
if (Pos_1 == posId)
pos = s->pos1;
Serial.print ("posServo: ");
Serial.print (s->desc);
Serial.print (" ");
Serial.println (pos);
int dir = s->pos < pos ? 1 : -1;
for ( ; s->pos != pos; ) {
s->pos += dir;
s->servo.write (s->pos);
Serial.println (s->pos);
delay (s->stepDelay);
void loop ()
if (LOW == digitalRead (PinButton)) {
if (LOW == digitalRead (PinSensor))
digitalWrite (11, LOW);// IF SENSOR ON TURN ON RED LED
else {
posServo (S_ARM, Pos_1);
delay (2000); //Delay between clamp and rotate
posServo (S_ROT, Pos_1);
delay (3000); //Delay to hold car upside down
posServo (S_ROT, Pos_0);
delay (2000); //Delay between rotate and clamp
posServo (S_ARM, Pos_0);
digitalWrite (11, HIGH); // OTHERWISE TURN ON GREEN LED
void setup () {
Serial.begin (9600); // setup serial
ServoSt *s = & servos [0];
for (unsigned n = 0; n < N_SERVO; n++, s++) {
s->servo.attach (s->pin);
s->pos = s->pos0;
pinMode (PinButton, INPUT_PULLUP);
pinMode (PinSensor, INPUT_PULLUP);
pinMode (10, INPUT_PULLUP); //GREEN LED
pinMode (11, INPUT_PULLUP); //RED LED
Serial.println ("Coal Dumper");
i think what you're you looking for is the red/green led to indicate when the car is in position and to use the sensor to prevent operation if not in position (i don't know how the sensors are wired, when HIGH/LOW is clear)
void loop ()
int sensor = digitalRead (PinSensor);
if (HIGH == sensor) {
digitalWrite (PinLedRed, LOW);
digitalWrite (PinLedGreen, HIGH);
else {
digitalWrite (PinLedRed, HIGH);
digitalWrite (PinLedGreen, LOW);
