Hi everyone, I am currently working on a timelapse controller / intervalometer.
at present I have it working so that when switched on it first requires input of the number of photos to be taken, then the interval inbetween the photos.
I have been using the code and hardware as shown here
I would make the code to set shutter speed similar to the code to set number of pics.
(I understand this is not code you’ve written. If you can’t follow how the existing code works, your chances of successfully making this change are pretty slim.)
I understand the majority of what's going on this is probably my 4th or 5th reasonably major arduino project, I had started this myself originally but found this code which was pretty much exactly what I was looking for. I was thinking along the lines of how the picture was setup, I've never used changeable parameters prior to the loop so although I can see what it's doing I'm not 100% how I should structure it with another variable.
A pseudo code example from the picture option through to the beginning of the loop would be really helpful
Apparently, you don't, or you would be able to implement PeterH's suggestion.
Post the code that you think is getting the number of pictures to take. If you can do that, and you can identify how/where it is getting the interval between the photos, then adding another section to get delay between pictures is trivial.
The function names that are used, while not what I would have chosen, are a pretty good indication of what the program is doing.
