Adding another relay(s) in rtc relay sketch
Hi guys,
at first excuse my english language and my programming skills.
I have this code for switching 1 relay depending of rtc time. I've tried add another 1 or 2 relays but without success.
#include <DS3231.h>
int Relay = 4;
int temp;
DS3231  rtc(SDA, SCL);
Time t;
const int OnHour = 22;
const int OnMin = 55;
const int OffHour = 23;
const int OffMin = 5;
  rtc.begin();
  pinMode(Relay, OUTPUT);
  digitalWrite(Relay, HIGH);
  temp = rtc.getTemp();
  t = rtc.getTime();
  if(t.hour<10) {
    Serial.print("0");
    Serial.print(t.hour);
  else {
  Serial.print(":");
  if(t.min<10) {
    Serial.print("0");
    Serial.print(t.min);
  else {
  Serial.print(":");
  if(t.sec<10) {
    Serial.print("0");
    Serial.print(t.sec);
  else {
  Serial.println(" ");
  Serial.println(temp);
  Serial.println("°C");
  delay (1000);
  if(t.hour == OnHour && t.min == OnMin){
    digitalWrite(Relay,LOW);
    Serial.println("LIGHT ON ");
    else if(t.hour == OffHour && t.min == OffMin){
      digitalWrite(Relay,HIGH);
      Serial.println("LIGHT OFF");
I've tried this edited code, but causes mess in switching:
#include <DS3231.h>
int Relay = 4;
int Relay2 = 5;
int temp;
Time t;
const int Relay2OnHour = 22;
const int Relay2OnMin = 55;
const int Relay2OffHour = 23;
const int Relay2OffMin = 5;
  rtc.begin();
  t = rtc.getTime();
  if(t.hour<10) {
    Serial.print("0");
  else {
  Serial.print(":");
  if(t.min<10) {
    Serial.print("0");
  else {
  Serial.print(":");
  if(t.sec<10) {
    Serial.print("0");
  else {
  delay (1000);
  if(t.hour == Relay2OnHour && t.min == Relay2OnMin){
    Serial.println("LIGHT2 ON ");
    else if(t.hour == Relay2OffHour && t.min == Relay2OffMin){
      Serial.println("LIGHT2 OFF");
How is correct way to add another 1 or 2 relays?
why do you want to use multiple relays? And which board are you using?
Sorry I forgot nd I missed. Relays should be switched in different time. I use arduino nano board.
For example:
const int OnHour = 6;
const int OnMin = 30;
const int OffHour = 7;
const int OffMin = 30;
const int Relay2OnHour = 8;
const int Relay2OnMin = 0;
Your current code controls the first relay based on the times of relay2. Change the digitalWrites in the second relay timing.
You will also need a pinMode in setup for the second relay.
Mean you this?
  rtc.begin();
  pinMode(Relay2, OUTPUT);
  digitalWrite(Relay2, HIGH);
and
    digitalWrite(Relay2,LOW);
      digitalWrite(Relay2,HIGH);
I will try and I will give feedback.
You haven't put relay2 in setup():
  rtc.begin();
Oops! @aughostino, didn't mean to step on your toes. :confused:
this code is functional
#include <DS3231.h>
int Relay = 4;
int Relay2 = 5;
int temp;
Time t;
const int OnHour = 16;
const int OnMin = 6;
const int OffHour = 16;
const int OffMin = 9;
const int Relay2OnHour = 16;
const int Relay2OnMin = 7;
const int Relay2OffHour = 16;
const int Relay2OffMin = 8;
  rtc.begin();
  t = rtc.getTime();
  if(t.hour<10) {
    Serial.print("0");
  else {
  Serial.print(":");
  if(t.min<10) {
    Serial.print("0");
  else {
  Serial.print(":");
  if(t.sec<10) {
    Serial.print("0");
  else {
  delay (1000);
Thanks very much, guys.
PS: next step will be adding a display nokia 5110 and showing Serial.print on display >:(
problem again, I've tried to show time on Nokia 5110 display.
code:
lcd.GotoXY(0,0);
lcd.LcdString(t.hour);
is not working
here is all sketch
#include <Nokia5110.h>
#include <DS3231.h>
#define RST 8
#define CE 7
#define DC 6
#define DIN 5
#define CLK 4
LCDnokia5110 lcd(RST, CE, DC, DIN, CLK);
int Relay = 11;
int Relay2 = 12;
int temp;
Time t;
const int OnHour = 21;
const int OnMin = 40;
const int OffHour = 21;
const int OffMin = 43;
const int Relay2OnHour = 21;
const int Relay2OnMin = 41;
const int Relay2OffHour = 21;
const int Relay2OffMin = 42;
  rtc.begin();
  lcd.LcdInitialise();
  lcd.LcdClear();
  lcd.CharSpace = 1; // nastavení velikosti mezery mezi písmeny,lze nastavit na 0, 1 či 2 body
  lcd.GotoXY(0,1);
  lcd.LcdString("Relay 1:");
  lcd.GotoXY(55,1);
  lcd.LcdString("OFF");
  lcd.GotoXY(0,2);
  lcd.LcdString("Relay 2:");
  lcd.GotoXY(55,2);
  t = rtc.getTime();
  if(t.hour<10) {
    Serial.print("0");
  else {
  Serial.print(":");
  if(t.min<10) {
    Serial.print("0");
  else {
  Serial.print(":");
  if(t.sec<10) {
    Serial.print("0");
  else {
  delay (1000);
lcd.GotoXY(0,0);
    lcd.GotoXY(55,1);
    lcd.LcdString("ON ");
      lcd.GotoXY(55,1);
    lcd.GotoXY(55,2);
      lcd.GotoXY(55,2);
Static text is OK, but showing time on display case, that are showing some symbols :frowning: where is problem? excluding my skills.
