Adding Array Value to UPPERCASE String
I am having some trouble with extracting data from an array of codes, adding it to a string variable and then making a comparison to the correct code.
I define Check String and then after that loop through all the possible tags, make the result UPPERCASE and then print the result that I will try to make a comparison with later. Here is an excerpt, without the loop.
String CheckString = "TAG=3000";
CheckString += Tag[i];
CheckString.toUpperCase();
Serial.println(CheckString);
When I print CheckString, all I get is "TAG=3000". I do not understand why it is not adding the actual Tag value when it loops through the array. When I print a few of the array items manually Tag[0], Tag[1], Tag*, etc. It appears the array and loop are working just fine as I get the expected values when I test. *
I am lost why I cannot add these to my CheckString. My syntax must be off or the UpperCase is causing me an issue.
Any suggestions to try?
THANKS!
Please post complete code.
Please read the sticky "How to use this forum - please read", specifically point 7 about posting code.
Note that it's not advisable to use String (capital S) if you have limited memory resources; it can result in unexpected behaviour. Use.nul-terminated character arrays instead.
If the tags are already in a char array, why do you want to convert to String (which is never a smart move)? Change to char CheckString[n] = "TAG=3000"; where 'n' is a value large enough to hold the initialized value plus whatever you may want to add later. You need 8+1 (null terminator) for "TAG=3000" so make it 15 or 20. Later, add the tag with strcat(CheckString, tag);
String commands don't work on arrays, if that is what Tag is. You mention Tag[0]...
Guess again. Since that is ALL that that is. The += operator WILL concatenate a string to a String instance.
Though OP should NOT be using Strings...
Thank you all for your time and responses. I had thought I made a simple error somewhere, but it sounds like it is more complex than that and has to do with my choice of array. Here is the draft of the sketch that I am working with as I understand this more has to do with the array/loop.
I am working with 24 HEX characters and then was adding the "TAG=3000" prefix that my inputString came with. I will read up on the difference between string and nul-terminated character arrays.
If you have any more suggestions, I appreciate it. I will read up on types of arrays more in the meantime. Thank you again.
// GLOBAL DECLARATIONS
String inputString = "";         // Holds incoming data
 // Setup Pins
 inputString.reserve(1000);
void validateTag()
 int i = 1;                                  // Array Counter
 // Parse Input
 inputString.trim();
 inputString =  inputString.substring(inputString.length() - 32, inputString.length());         // Parse last 32 CHARS as inputString
   if (inputString.startsWith("TAG=3000"))
         // Build Tag ID Array
         int ArraySize = 7;
         String Tag[] = {
           "9ecfa8e99409f099db5ddc03",
           "0c1b69c80dfd36584ccf7b75",
           "40dff033d211d2fe25f76d27",
           "a0bb8ac8b8fa31136652c9d5",
           "f4ccad4d3a73e7314aa96874",
           "54eb069621328ea51958f7c0",
           "5c832e37199511cb3841db43"
         for (i = 0; i < ArraySize; i++){
             if (inputString == CheckString)
                       Serial.println("ARDUINO: YES, MATCH");
                       Serial.println(inputString);
                       // Invalid tag, access denied, do nothing
                       Serial.println("ARDUINO: NO MATCH FOR:");
            CheckString = "TAG=3000";                       //Reset to start
    inputString = "";                                      // Clear the inputSting
Moving to a CHAR array that allowed for my TAG + NULL seems to have solved my issue. Thanks for the help
