Adding Backspace in Keypad
Hi, I'm making an ATM in which we have to enter our **BMI(Body Mass Index)**and I am having some difficulties in working with keypad see I have programmed the Arduino in the way that I can Enter my BMI and I will be give money as BMI * 10 but I want to add backspace when I click the # Key. So can anyone help me with this problem
This is My Code
#include <Keypad.h>
const byte ROWS = 4; //four rows
const byte COLS = 4; //four columns
char keys[ROWS][COLS] = {
  {'1', '2', '3', 'A'},
  {'4', '5', '6', 'B'},
  {'7', '8', '9', 'C'},
  {'*', '0', '#', 'D'}
byte rowPins[ROWS] = {2, 3, 4, 5}; //connect to the row pinouts of the keypad
byte colPins[COLS] = {A0, A1, A2, A3}; //connect to the column pinouts of the keypad
Keypad keypad = Keypad( makeKeymap(keys), rowPins, colPins, ROWS, COLS );
float enteredBMI = 0.0; // Variable to store entered BMI
float totalMoney = 0.0; // Variable to store total money
  char key = keypad.getKey();
  if (key) {
    if (key == 'A') {
      // The user pressed "A," calculate total money and display it
      totalMoney = enteredBMI * 10.0;
      Serial.print("Total Money: $");
      Serial.println(totalMoney);
      enteredBMI = 0.0; // Clear the entered BMI
      Serial.print(key); // Print the entered key
      enteredBMI = enteredBMI * 10.0 + (key - '0'); // Append key to enteredBMI
The first thing to do is to change the else clause so that the total is only updated if a numeric key is pressed
Come back when you have done that
No, see I want the total to be submitted when I click the "A" key. So Else clause is necessary
The else clause is necessary but is currently wrong
What happens to the total if you press the 'A' key, for instance ?
The number will be multiplied by 10 when we press "A"
But what if you press the 'B' key ?
#include <Keypad.h>
const char keys[ROWS][COLS] = {
const byte rowPins[ROWS] = {2, 3, 4, 5}; //connect to the row pinouts of the keypad
const byte colPins[COLS] = {A0, A1, A2, A3}; //connect to the column pinouts of the keypad
Keypad keypad( makeKeymap(keys), rowPins, colPins, ROWS, COLS );
int enteredBMI = 0; // Variable to store entered BMI
//int totalMoney = 0; // Variable to store total money
  if (key != NO_KEY) {
    if (key >= '0' && key <= '9') enteredBMI = enteredBMI * 10 + key - '0';
    if (key == '#') enteredBMI = enteredBMI / 10 ;
    if (key == 'A') {
      //totalMoney = enteredBMI * 10;
      Serial.println(enteredBMI);
      enteredBMI = 0; // Clear the entered BMI
