Adding below void loop causes declaration to fail "Not declared in this scope"
Hey guys,
I'm mashing up some scripts trying to get a few buttons and encoders to work through USB and I've mostly got it sorted using a button matrix but I'm trying to add a couple of extra buttons outside of that defined matrix. When I add in the FOR and IF statement to get the buttons to function it somehow breaks the initialisation of my rotary encoders.
Here is the script and this works great, does everything I want it to.
#include <Key.h>
#include <Keypad.h>
//Uncomment this for HALFSTEP encoder operation
//#define HALF_STEP
#include <Keypad.h>
#include <Joystick.h>
#define ENABLE_PULLUPS
#define NUMROTARIES 3
#define NUMBUTTONS 25
#define NUMROWS 5
#define NUMCOLS 5
//define the symbols on the buttons of the keypads
byte buttons[NUMROWS][NUMCOLS] = {
  {1,2,3,4,5},
  {6,7,8,9,10},
  {11,12,13,14,15},
  {16,17,18,19,20},
  {21,22,23,24,25},
struct rotariesdef {
  byte pin1;
  byte pin2;
  int ccwchar;
  int cwchar;
  volatile unsigned char state;
rotariesdef rotaries[NUMROTARIES] {
  {0,1,26,27,0},
  {2,3,28,29,0},
  {4,5,30,31,0},
#define DIR_CCW 0x10
#define DIR_CW 0x20
#define R_START 0x0
#ifdef HALF_STEP
// Use the half-step state table (emits a code at 00 and 11)
#define R_CCW_BEGIN 0x1
#define R_CW_BEGIN 0x2
#define R_START_M 0x3
#define R_CW_BEGIN_M 0x4
#define R_CCW_BEGIN_M 0x5
const unsigned char ttable[6][4] = {
  // R_START (00)
  {R_START_M,            R_CW_BEGIN,     R_CCW_BEGIN,  R_START},
  // R_CCW_BEGIN
  {R_START_M | DIR_CCW, R_START,        R_CCW_BEGIN,  R_START},
  // R_CW_BEGIN
  {R_START_M | DIR_CW,  R_CW_BEGIN,     R_START,      R_START},
  // R_START_M (11)
  {R_START_M,            R_CCW_BEGIN_M,  R_CW_BEGIN_M, R_START},
  // R_CW_BEGIN_M
  {R_START_M,            R_START_M,      R_CW_BEGIN_M, R_START | DIR_CW},
  // R_CCW_BEGIN_M
  {R_START_M,            R_CCW_BEGIN_M,  R_START_M,    R_START | DIR_CCW},
#else
// Use the full-step state table (emits a code at 00 only)
#define R_CW_FINAL 0x1
#define R_CW_NEXT 0x3
#define R_CCW_BEGIN 0x4
#define R_CCW_FINAL 0x5
#define R_CCW_NEXT 0x6
const unsigned char ttable[7][4] = {
  // R_START
  {R_START,    R_CW_BEGIN,  R_CCW_BEGIN, R_START},
  // R_CW_FINAL
  {R_CW_NEXT,  R_START,     R_CW_FINAL,  R_START | DIR_CW},
  // R_CW_BEGIN
  {R_CW_NEXT,  R_CW_BEGIN,  R_START,     R_START},
  // R_CW_NEXT
  {R_CW_NEXT,  R_CW_BEGIN,  R_CW_FINAL,  R_START},
  // R_CCW_BEGIN
  {R_CCW_NEXT, R_START,     R_CCW_BEGIN, R_START},
  // R_CCW_FINAL
  {R_CCW_NEXT, R_CCW_FINAL, R_START,     R_START | DIR_CCW},
  // R_CCW_NEXT
  {R_CCW_NEXT, R_CCW_FINAL, R_CCW_BEGIN, R_START},
#endif
byte rowPins[NUMROWS] = {22,21,20,19,18}; //connect to the row pinouts of the keypad
byte colPins[NUMCOLS] = {9,10,11,12,13}; //connect to the column pinouts of the keypad
//initialize an instance of class NewKeypad
Keypad buttbx = Keypad( makeKeymap(buttons), rowPins, colPins, NUMROWS, NUMCOLS);
//initialize an Joystick with 34 buttons;
Joystick_ Joystick(JOYSTICK_DEFAULT_REPORT_ID,
  JOYSTICK_TYPE_JOYSTICK, 34, 0,
  false, false, false, false, false, false,
  false, false, false, false, false);
  Joystick.begin();
  rotary_init();
  CheckAllEncoders();
  CheckAllButtons();
void CheckAllButtons(void) {
      if (buttbx.getKeys())
       for (int i=0; i<LIST_MAX; i++)   // Scan the whole key list.
           if ( buttbx.key[i].stateChanged )   // Only find keys that have changed state.
            switch (buttbx.key[i].kstate) {  // Report active key state : IDLE, PRESSED, HOLD, or RELEASED
                    case PRESSED:
                    case HOLD:
                              Joystick.setButton(buttbx.key[i].kchar, 1);
                    case RELEASED:
                    case IDLE:
                              Joystick.setButton(buttbx.key[i].kchar, 0);
/* Call this once in setup(). */
void rotary_init() {
  for (int i=0;i<NUMROTARIES;i++) {
    pinMode(rotaries[i].pin1, INPUT);
    pinMode(rotaries[i].pin2, INPUT);
    #ifdef ENABLE_PULLUPS
      digitalWrite(rotaries[i].pin1, HIGH);
      digitalWrite(rotaries[i].pin2, HIGH);
    #endif
/* Read input pins and process for events. Call this either from a
 * loop or an interrupt (eg pin change or timer).
 * Returns 0 on no event, otherwise 0x80 or 0x40 depending on the direction.
unsigned char rotary_process(int _i) {
   unsigned char pinstate = (digitalRead(rotaries[_i].pin2) << 1) | digitalRead(rotaries[_i].pin1);
  rotaries[_i].state = ttable[rotaries[_i].state & 0xf][pinstate];
  return (rotaries[_i].state & 0x30);
void CheckAllEncoders(void) {
    unsigned char result = rotary_process(i);
    if (result == DIR_CCW) {
      Joystick.setButton(rotaries[i].ccwchar, 1); delay(50); Joystick.setButton(rotaries[i].ccwchar, 0);
    if (result == DIR_CW) {
      Joystick.setButton(rotaries[i].cwchar, 1); delay(50); Joystick.setButton(rotaries[i].cwchar, 0);
I then make the following change
  Joystick.begin();
  rotary_init();
  pinMode(6, INPUT_PULLUP);
const int pinToButtonMap = 6;
int lastButtonState[4] = {0,0,0,0};
  CheckAllEncoders();
  CheckAllButtons();
for (int index = 0; index < 4; index++)
    int currentButtonState = !digitalRead(index + pinToButtonMap);
    if (currentButtonState != lastButtonState[index])
      Joystick.setButton(index, currentButtonState);
      lastButtonState[index] = currentButtonState;
and I get this error message
"exit status 1'rotary_init' was not declared in this scope"
I'm totally lost as to why this breaks it. I'd love someone to help me out here.
Thanks in advance
Where is this function ?
rotary_init();
larryd:
rotary_init();
I'm honestly confused by it, because it's not defined anywhere but it works fine without that extra bit added in. it compiles and the buttons/encoders work great...
